    I'VE ALMOST HAD IT WITH TRYING TO UNDERSTAND DC's!!!!
    Scheduled Pinned Locked Moved Dynamic Components
    41 Posts 17 Posters 4.9k Views 17 Watching
    • jim smithJ Offline
      jim smith
      Many,many, many of the plug-ins make modeling so much easier and I am thankfull to all the Ruby experts that have created them. πŸ˜„
      Then there is DC. 😞
      I felt somehow I was at fault because DC would never work right for me. Like Solo, I found it easier to spend a few more minutes working on the model "conventionally" than spending hours trying to make the thing work. The concept is GREAT however and I hope it eventually gets tweaked into someting workable.
      By the way, had a thought... did AutoDesk have anything to do with developing it? Just asking. πŸ˜• πŸ˜‰
      "Out of clutter find simplicity,
      from discord find harmony,
      In the middle of difficulty lies opportunity"
      Albert Einstein
      • pbacotP Offline
        Even of the pre-made DC's by those who understand them... who uses DC's? I haven't seen an example yet of a DC that I thought would really do exactly what I wanted, or which I would use repeatedly for different permutations.
        I think a poll might be interesting (as far as these limited-participation polls go). I've wondered how widespread the use is. It's an ingenious concept, but has it caught on?
        • gullfoG Offline
          gullfo
          i've been struggling because the intricate 3D models then need to be translated into 2D plans or exported as DWG in 2D to interact with other people in the process of getting things built... so having the ability to use parameters, scale, and switch between 3D and 2D views easily is important to my work flow. scripts only take it so far, so the DC components (like framed walls, doors, windows, etc) all help with the modeling, drafting and material lists more than the scripting or individual modeling does (at least for me). so i try to invest at least 5 hours per project creating re-usable DC components so the next project is somewhat reduced in time and the quality is the same or better even.
          i think the biggest win for pre-built is the kitchen components - there seems to be quite a few nice ones out there plus Pella and Marvin both have some nice windows and doors.
          Glenn
          http://www.runnel.com
          • pbacotP Offline
            Those are good examples, gullfo. Cabinets especially. I have had some reservations about Manufacturer models (some are heavy while not looking very good--and lacking the options).
            • david_hD Offline
              david_h
              @solo said:
              I realized very early that DC's and me would never be friends, after I spent a day trying to figure out a DC way of saving me ten minutes if it actually worked I came to the conclusion that ten minutes more modeling isn't such a bad thing.
              At First I thought you guys were talking aboutWASHINGTON D.C. which we will never understand either πŸ’š . . .but going to Pete's point. . . if it takes 14 hours to figure how to make a DC to save 10 minutes what's the gain? Short of some animation things (doors opening or something) I don't see what all the fuss is about. Stairs and fences can be re-modeled ususally a lot faster than it takes to input in all the data to make it DYNAMIC. SO i don't use them either.
              Just my 2c
              • jeff hammondJ Offline
                Just my 2c
                all minutes aren't created equally.
                Ive made 4 DCs that I use occasionally. . one of them took me two days to build and it saves around 20 minutes of drawing time. (the others took less time to make but they still knock off minutes when the minute$ count)
                the thing is, those 20 minutes are much more valuable to me because they occur on site where as the 2 days making the DC was done in leisure time.
                ..if any of that makes sense πŸ˜„
                • soloS Offline
                  That's the thing Jeff, if I had a product that I used often and it made sense for it to be a DC then I'd probably have tried harder, longer or asked for help. Now my wife on the other hand is a CKD kitchen designer and she uses 20/20 daily, she is talking of using Sketchup in the future and this may be when DC's will come in very handy or even necessary.
                  I guess it comes down to when or how you will use them or even need them.
                  • david_hD Offline
                    david_h
                    Ditto.
                      Ditto.
                      oh. I totally understand what you guys are saying and for the most part, I'm the same way.
                      it's just that I happened to find a use for them in which it made sense for me to spend the time creating the DC.. so I was just adding my own experience.
                      I do wish the sketchup team developed them much further beyond the initial release.
                      a DC GUI of sorts would probably do wonders as far as getting more people to use them.
                      the current implementation is far too codey(?) for most people. we generally want to SHOW the computer what to do instead of TELL it what to do.
                      (the show vs tell is probably the wrong choice of words here.. replace them with whatever works better πŸ˜„ )
                      • soloS Offline
                        I agree, it should be easier, It feels like I need to learn a new program almost. I'd like presets with configurable options, drop windows maybe with options, easy building UI, etc.
                        or even as you suggest something like a macro, where I can record the action.
                          I was actually thinking something along the lines of grasshopper (maybe not as intense though πŸ˜‰ )
                          maybe:
                          [in DC design mode or whatever]
                          select a face
                          assign a push/pull modifier to the face.
                          the modifier could then be controlled via a slider or numerical input etc
                          or select a component
                          assign a move modifier to it
                          show the direction you like
                          check yes/no for copymove
                          etc
                          itd be a lot more user friendly like that
                            Hoppefully this possibility of programming don't exist in the free version! πŸ˜„
                            Maybe in the V9, so we can help you! πŸ˜‰
                            Try Scratch or Byob (Hyper Scratch) for your kids or you and DC will seem more easy! πŸ˜‰
                            • KrisidiousK Offline
                              Krisidious
                              DC's are half the reason I bought Pro 7 and gave up very soon after the purchase. I figured I was just too dense to get it.
                              By: Kristoff Rand
                              • utilerU Offline
                                utiler
                                phew... now I feel much better that you guys are of the same opinion....
                                I like that idea about selection a face and applying a group of settings to come up with what's require: Goh's 1001bit tools does a similar thing and it works well for me.
                                Maybe I just drop the DC thing all together.
                                Just Curious...
                                  Trogluddite
                                  I concur with ArCAD's experience - the way DC's are deployed completely hampers their usefulness.
                                  I have plenty of programming experience, so found the maths side not too bad and managed to create several DC's that I thought would be useful....
                                  ....until I looked in my Components toolbox - "Part#1", "Part#2", "Part#3",..etc...
                                  ...which I then rename as "Part Small", "Part Big", "Part Huge" etc. and then try to remember to drag the right one into the model so that I don't then end up with another new series of #1,#2,#3... (except that I will anyway if I alter any parameters "on site").
                                  I think, at best, they can be used as a kind of templates for quick construction of regular "non-DC" components. But as has been pointed out already, SU is so fast to model with, that I may as well have just built "Part Small", "Part Big"... as separate components in the first place.
                                  To be more useful, I would like to see something like...
                                  • Only ever one definition (visible?) in the component toolbox.
                                  • A new native component attribute "Suffix", visible in the Outliner - e.g. for a component called "Nut", we could add "M3","M4" etc. according to parameter values - purely as "aliases" to help us see what is what and for use in reports, but not changing the DC definition in any way.
                                  • "Variants" itemised according to their parent definition and sorted by parameter values in reports. So I can quickly see that I have used 25 M3 Nuts, rather than having to check each "Nut#x" component individually to see see what parameters it has.
                                  In principle, DC's have a lot of potential - but I doubt it can ever be realised unless the implementation is thoroughly overhauled.
                                    ArCAD-UK
                                    Well this turned into a surprising thread. I hadn't expected so many experienced users to be having issues with DCs. I guess someone needs to grab hold of this aspect of SU and give it a real good shake to give us a more useable format.
                                    I did have another play yesterday to create an inclined beam and realised that DCs are really lacking some basic shape modelling commands such as add and subtract, but with SU's solid modelling this must now be a realistic prospect?
                                    • gullfoG Offline
                                      gullfo
                                      yeah, naming your parts and using materials (i use colors named as needed "lumber_stud", "machine_bolt" etc then replace if used for rendering later) is key to making the reporting work well. then i import to excel and run some macros to remove extraneous values and summarize (DSUM DCOUNT etc) to create the materials list. it would be nice to have the reporting take families of groups and report directly though...
                                      it would be cool if DC had a "record macro" function. but some more functions (like % (mod)) would be nice plus parent's parent referencing (as well as inserting of Ruby code πŸ˜„)
                                      Glenn
                                      • utilerU Offline
                                        utiler
                                        Let's hope..... πŸ‘
                                        Just Curious...
                                          ArCAD-UK
                                          Glenn, I'm no Exel wiz but could you achieve what you need with a pivot table?
                                          • gullfoG Offline
                                            gullfo
                                            I do use Excel currently but i'm thinking a built-in solution for SU would be nice
                                            Glenn
                                            • 1 / 3
