    [Plugin Library] LibFredo6 - v15.8b - 12 Jan 26
    2.2k Posts 571 Posters 4.1m Views 573 Watching
      supercylon
      @supercylon
      Just in case, can you type ENV["TEMP"] in the Ruby Console and tell me what you see.
      Hello Fredo,
      Thanks for your assistance. I did what you asked and here is a screenshot of the result.
      ![Results of ENV["TEMP"] in Ruby Console](/uploads/imported_attachments/iUOu_Picture2.png "Results of ENV["TEMP"] in Ruby Console")
      Thanks Supercylon
        supercylon
        @tig said:
        I use
        tempdir=ENV["TEMP"] ### it's a PC == 'TEMP' or 'TMP' tempdir=ENV["TMPDIR"] if not tempdir ### it's a Mac
        πŸ˜•
        TIG,
        Actually, my mistake. Yes indeed, I use TMPDIR for Mac environment (or /tmp which may be more secure)
        @supercylon
        Can you type ENV["TMPDIR"] in the Ruby console
        Fred
        I didn't notice this message, here is the screen shot of the result of your second request.
        Thanks,
        Supercylon
          And ENV['TMP'] ?
            supercylon
            @supercylon
            Can you try withe attached file to see if your error disappear and SU starts OK.
            [attachment=0:2f69w8lx]<!-- ia0 -->LibFredo6.rb<!-- ia0 -->[/attachment:2f69w8lx]
            Fredo,
            Thank you!Thank you! It works!
            Supercylon
            • fredo6F Offline
              Supercylon
              I will release the change tomorrow as v4.3c
              It is strange however that on your Mac, the TMPDIR Environment variable is not defined.
              @TIG, Thomthom: I just use /tmp when TMPDIR is not defined.
              • fredo6F Offline
                @supercylon
                EDIT: file removed. Now part of the release 4.3c, 31 Jan 12
                  baranya
                  Under Ubuntu makes SU to crach on startup
                  • fredo6F Offline
                    It's difficult for me to diagnose on this platform which I don't have.
                    I think there are a few users running Sketchup on Linux flavors, and they may help you to troubleshoot.
                    • Y Offline
                      yogaseeker
                      I ran into some trouble when I placed this plugin in the SU plugin folder. I thought this solution might help others.
                      "LibFredo6 4.3c - 31 Jan 12" is the name of the folder that I unzipped and I placed in my plugins folder. But that didn't work. You have to drag the contents of the "LibFredo6 4.3c - 31 Jan 12" folder (LIBFREDO6_Dir_43 and LibFredo6) out of that folder and put it in the plugins folder.
                      THanks so much for this wonderful plugin!!!
                        mingjae
                        Hello Mr.LibFredo..
                        I have a diifficulty to install curviloft using libfredo in my SU8,
                        it wont load and something wrong with the fredo, this is the picture :
                        http://img594.imageshack.us/img594/7065/99471562.jpg
                        I dont have lib tranductor.rb in Libfredo6 package neither on curviloft,
                        how to solve this Mr?
                        I also trying to copy the lib_tranductor.rb in my SU7 to SU8 plugins folder but it always crash after copying it... 😒
                        • fredo6F Offline
                          I would suggest you redo a clean installation and make sure you overwrite all existing files.
                          Just in case, can you type in the Ruby Console and report what you get:
                          Sketchup.find_support_file('LibTraductor.rb', "Plugins")
                            mingjae
                            Hi, thank for your reply
                            my SU8 in plugin folder have not installed by LibFredo and curviloft before,
                            so I just put all unzipped libfredo and curviloft in my plugins folder,
                            after I redo to overwrite it, it result the same, it not load "lib traductor.rb
                            and here is I copy paste after I enter it on ruby console:
                            "Sketchup.find_support_file('LibTraductor.rb', "Plugins")
                            C:/Program Files/Google/Plugins/LibTraductor.rb"
                            edit: perhaps the lib traductor.rb crashes in the Google/Plugins folder?
                            I copy the "Plugins" folder from my friend notebooks and place it there.
                            I cut the lib traductor there and place it in SU8 plugins folder and the curviloft success to load...
                            but, where can I get "lib traductor.rb", there's no in lib fredo zip and curviloft zipped file installer right?
                            • fredo6F Offline
                              Actually you do not need LibTraductor.rb for Curviloft (it's only for backward compatibility that it is checked).
                                mingjae
                                really?? 😳
                                lol..i'm sorry, but thanks my SU8 now loading without any error notification..
                                • fredo6F Offline
                                  By the way, you seem to have a non-standard installation of SU8.
                                  Normally, Sketchup folders are located in C:/Program Files/Google/**Google SketchUp 8**.
                                  • ElibjrE Offline
                                    Elibjr
                                    Wow, Thank you very much. All of these plugins are truly a life saver. They bring Sketchup to a completely different level. I love them. And the more I use them the more I appreciate what they do. This had made Sketchup more than just a modeling toy to play with, these plugins (and others listed on the forum) allow the software to truly and indisputably become more of a productive too hands down! Thank you (and all of the other people who write rubies for this Software) again! WE should NEVER take ANY plugin listed here for granted! πŸ˜„
                                      cquinn
                                      Pardon my ignorance, but where can I find the latest LibFredo version file to download? I have an old version and recall finding it buried in a forum discussion but no such luck this time.
                                      THanks!
                                        in the first post of this topic.
                                        • fredo6F Offline
                                          NEW RELEASE: LibFredo6 v4.4j - 11 Apr 12
                                          LibFredo6 4.4 is a new release which essentially support the publishing of ThruPaint and ReverseOrientFaces as part of FredoTools
                                          I also updated the strategy for online documentation. All PDF will now be grouped in a single sub-directory DOCUMENTATION_Dir. The move of file is done automatically for existing plugins. This will allow to keep the documentation regardless of the version of plugins (as I do not update the doc for every release). Also, The Plugin zip files won't include these PDF files any longer (this will make them lighter). Users will have to download the doc from the forum and put it in DOCUMENTATION_Dir folder if they wish.
                                          • Didier BurD Offline
                                            Didier Bur
                                            Hi Fredo,
                                            Thanks for all your huge work and for sharing it with the community.
                                            I'll just warn users of this library NOT to install it with a Ctrl-A and then drag-drop the files in their Plugins folder. Doing the extraction this way DOESN't create any folder structure and obiously generates errors when loading the library and plugin.
                                            The safer (and only) way is to select "Extract" in Winzip, point to the correct folder and tick "use folder structure" checkbox.
                                            Now back to removing my 148 wrongly located files 🀣
                                            DB
                                            • 26
                                            • 27
                                            • 28
                                            • 29
                                            • 30
                                            • 108
                                            • 109
                                            • 28 / 109
