    [Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20
    54 Posts 28 Posters 112.9k Views 28 Watching
    • fredo6F Offline
      @boilingsnow said:
      Could you make them separate to install?
      What do you mean?
        tak2hata
        This is nice tool!
        Thanks FREDO! 😍
        by TAK2HATA
          boilingsnow
          What do you mean?
          I mean you are providing a set of tools and I have to install them all at one time. But I have already installed some of them and made my own icons for them.
          Actually I am using sutool of Wikii as a manager of all my plugins. And this set of combined tools doesn't support that.
          I konw I can also control display of the icons through your LibFredo6, but it would still be wonderful if you could continue providing these tools als seperate plugins at the same time.
          • fredo6F Offline
            I understand.
            I am not a user of Wikii's SUTool. Can you tell me how you bind the icon / command to the Plugin.
            I can try to offer an interface which is compliant so that you keep seeing the plugins as standalone.
            PS: I regrouped the plugins to minimize the footprint in SU, (i.e. have a single menu item). I also provides a Quick Launcher.
              boilingsnow
              I understand.
              Thank you very much for your answer.
              • I Offline
                I.Aleks.S
                [size=150]NEW RELEASE: [color=#400000]**ReportLabelArea 2.0a - 19 Dec 11....
                [/bFredo
                Hello [b]Fredo6**.
                Forgive for my bad English.
                I use many yours Plugins. I give an appreciation on these workings out.
                I address to you with the request, to make calculation function on length;
                Millimetres running
                Centimetres running
                Metres running.
                Probably to execute it?
                I thank you.
                  jorge2011
                  fredo excellent tool. thank you very much.
                  A query. You can add a tool to measure length of vectors, curves, polylines etc ...?
                    cyb
                    Fredo. Great Tool.
                    One question. The sorting is by either Material or by Layer.
                    Any chance to add By Layer then by Material?
                    Something like this?
                    Layer1
                    Material 1
                    Material 2
                    Material 3
                    Layer2
                    Material 1
                    Material 2
                    Material 3
                    Regards.
                      castaway
                      NEW RELEASE: ReportLabelArea 2.0a - 19 Dec 11
                      ReportLabelArea is a rework of the previous ReportArea standalone plugin. It provides:
                      • More visual features for Reporting and Browsing for Areas
                      • Creation, update and Edition of labels with Areas
                      • Area formatting (choice of unit and decimals) for all functions
                      There are two videos to give an idea of the main features of the plugin
                      ReportLabelArea is now published as part of the FredoTools suite of Plugins
                      See main post of this thread for more information.
                      Is there any way to automatically update existing labels if the area has changed? I could not find a way to do so, but perhaps I am missing something
                      Thanks for such an amazing plugin btw.
                      • fredo6F Offline
                        I thought about it and there is a way. I hesitated because it obliges to store some information as attribute of faces and use an observer (notably not very stable in Sketchup). This latter issue made me hesitate as the plugin could have bad side-effects even if you do not use it at all.
                        One possibility is that I introduce a "refresh" option to update all labels. Maybe I'll do it in a next release.
                        Thanks for the suggestion
                          castaway
                          You are most welcome. A refresh button but be ideal in my opinion.
                          I never expected the labels to be updated automatically anyway since that would probably have a negative impact on performance (just wild gessing).
                          • creaformC Offline
                            creaform
                            Once again we thank you Fredo,
                            for what you bring to the community of SketchUp that is unique.
                            From France
                            Souvent cela dépends du point de vue choisi...
                            Often it depends of the chosen point of view ...
                              caronte01
                              Hi Fredo,
                              I downloaded this tool as part of Fredo6 tools pack. Makes Sketchup one of the most useful tools for architectural design. I constantly use it to report areas and update area schedules of projects. I now use sketchup as a 2d tool more and more. Bye autocad!!!
                              Thanks a lot!!!
                              • fredo6F Offline
                                @caronte01 said:
                                Hi Fredo,
                                Thanks a lot!!!
                                Thanks for the comment. If you think there is additional functionality that could be useful, do not hesitate. This is not an area where I am myself familiar.
                                • vaprossV Offline
                                  vapross
                                  Hello, guys.
                                  Finally I've a first post.
                                  Fredo, thanks a lot for your tooling! It really helps!
                                  My question is on exReportArea principle, that I'd like to turn to my needs. I used ReportArea (now ReportLabelArea) for the interior design. It works great. And I just checked this new one.
                                  I'm not a Ruby pro, and maybe you should send me to the Ruby forum section. Now I'd like use SU as a mass-modeling tool, and it seems to me there's no simple plugin to do it (if there is one, please, post a link!). Revit or ArchiCAD methods sometimes are a bit clumsy in mass-modeling. And the cost isn't nice for a such simple task.
                                  What I'd like to get a data structure in csv from SU model is as follows:
                                  • group
                                    -- name
                                    -- material area (e.g. 3 mats = 3 area values)
                                    -- layer
                                    -- volume
                                    -- etc
                                  The data structure appears to be an hierarchical one, because I'd like to get the parameters of each group/component from my model. Materials and naming are the core of the way of information mgmt I use within SU.
                                  Almost the same for a Component. Actually if I get a long unformatted list of data, I could sort it in Excel.
                                  Now I have no idea which code pattern to use -could you guide here? Any advices, links? I bought last week a brand-new book by Alex Schreyer, but it didn't help me.
                                  Thanks in advance!
                                  SketchUp 2015 Pro
                                  • brookefoxB Offline
                                    brookefox
                                    Just a note of thanks, Fredo, for a typically powerful multifaceted, super-documented and pleasing to behold tool-set. If I could master your tools alone, I would consider that quite a worthwhile accomplishment.
                                    ~ Brooke
                                    • fredo6F Offline
                                      Thanks very much for the encouraging appreciation. This one came from a user request some time ago. It's a little bit complex because there are many options and situations where only the user can decide (like selecting a face, a surface or a component). So I have to leave the options open and provide some documentation.
                                      • JQLJ Offline
                                        JQL
                                        Hello everyone,
                                        I was trying to generate my first report on areas from a project I have and I came across this question.
                                        Is it possible to report the area of a face minus the hole cutting component's areas attached to the face?
                                        http://www.casca.pt/varios/reportonareas.jpg
                                        The entity info window reports them but I didn't find a way to do that on this tool.
                                        Thank you fredo for all the unbelieveable tools... box stretching... perfect!
                                        www.casca.pt
                                        Visit us on facebook!
                                        • H Offline
                                          hking
                                          Report on Areas:
                                          trying to "Export CSV" I get the error code: "Error in generation of CSV file: //filename.csv
                                          please help
                                          Helmut Karger
                                          • fredo6F Offline
                                            NEW RELEASE: ReportLabelArea 2.1a - 09 Jul 15
                                            ReportLabelArea 2.1a fixes a problem related to glued components on faces. Now, for glued components in Cut opening mode, the contact area of theopening is deducted from the area of the face.
                                            • 3 / 3
