    [Plugin] FredoTools::ReportLabelArea - v3.2a - 05 Feb 20
    55 Posts 29 Posters 123.9k Views 29 Watching
    • B
      boilingsnow
      @boilingsnow said:
      Actually I am using sutool of Wikii as a manager of all my plugins. And this set of combined tools doesn't support that.
      I understand.
      I am not a user of Wikii's SUTool. Can you tell me how you bind the icon / command to the Plugin.
      I can try to offer an interface which is compliant so that you keep seeing the plugins as standalone.
      PS: I regrouped the plugins to minimize the footprint in SU, (i.e. have a single menu item). I also provides a Quick Launcher.
      Thank you very much for your answer.
      • I
        I.Aleks.S
        [size=150]NEW RELEASE: [color=#400000]**ReportLabelArea 2.0a - 19 Dec 11....
        [/bFredo
        Hello [b]Fredo6**.
        Forgive for my bad English.
        I use many yours Plugins. I give an appreciation on these workings out.
        I address to you with the request, to make calculation function on length;
        Millimetres running
        Centimetres running
        Metres running.
        Probably to execute it?
        I thank you.
        1 Reply Last reply 👍
          jorge2011
          fredo excellent tool. thank you very much.
          A query. You can add a tool to measure length of vectors, curves, polylines etc ...?
          • C
            cyb
            Fredo. Great Tool.
            One question. The sorting is by either Material or by Layer.
            Any chance to add By Layer then by Material?
            Something like this?
            Layer1
            Material 1
            Material 2
            Material 3
            Layer2
            Material 1
            Material 2
            Material 3
            Regards.
            • C
              castaway
              NEW RELEASE: ReportLabelArea 2.0a - 19 Dec 11
              ReportLabelArea is a rework of the previous ReportArea standalone plugin. It provides:
              • More visual features for Reporting and Browsing for Areas
              • Creation, update and Edition of labels with Areas
              • Area formatting (choice of unit and decimals) for all functions
              There are two videos to give an idea of the main features of the plugin
              ReportLabelArea is now published as part of the FredoTools suite of Plugins
              See main post of this thread for more information.
              Is there any way to automatically update existing labels if the area has changed? I could not find a way to do so, but perhaps I am missing something
              Thanks for such an amazing plugin btw.
              • fredo6F
                I thought about it and there is a way. I hesitated because it obliges to store some information as attribute of faces and use an observer (notably not very stable in Sketchup). This latter issue made me hesitate as the plugin could have bad side-effects even if you do not use it at all.
                One possibility is that I introduce a "refresh" option to update all labels. Maybe I'll do it in a next release.
                Thanks for the suggestion
                • C
                  castaway
                  You are most welcome. A refresh button but be ideal in my opinion.
                  I never expected the labels to be updated automatically anyway since that would probably have a negative impact on performance (just wild gessing).
                  • creaformC
                    creaform
                    Once again we thank you Fredo,
                    for what you bring to the community of SketchUp that is unique.
                    From France
                    Souvent cela dépends du point de vue choisi...
                    Often it depends of the chosen point of view ...
                    • C
                      caronte01
                      Hi Fredo,
                      I downloaded this tool as part of Fredo6 tools pack. Makes Sketchup one of the most useful tools for architectural design. I constantly use it to report areas and update area schedules of projects. I now use sketchup as a 2d tool more and more. Bye autocad!!!
                      Thanks a lot!!!
                      • fredo6F
                        @caronte01 said:
                        Hi Fredo,
                        Thanks a lot!!!
                        Thanks for the comment. If you think there is additional functionality that could be useful, do not hesitate. This is not an area where I am myself familiar.
                        • vaprossV
                          vapross
                          Hello, guys.
                          Finally I've a first post.
                          Fredo, thanks a lot for your tooling! It really helps!
                          My question is on exReportArea principle, that I'd like to turn to my needs. I used ReportArea (now ReportLabelArea) for the interior design. It works great. And I just checked this new one.
                          I'm not a Ruby pro, and maybe you should send me to the Ruby forum section. Now I'd like use SU as a mass-modeling tool, and it seems to me there's no simple plugin to do it (if there is one, please, post a link!). Revit or ArchiCAD methods sometimes are a bit clumsy in mass-modeling. And the cost isn't nice for a such simple task.
                          What I'd like to get a data structure in csv from SU model is as follows:
                          • group
                            -- name
                            -- material area (e.g. 3 mats = 3 area values)
                            -- layer
                            -- volume
                            -- etc
                          The data structure appears to be an hierarchical one, because I'd like to get the parameters of each group/component from my model. Materials and naming are the core of the way of information mgmt I use within SU.
                          Almost the same for a Component. Actually if I get a long unformatted list of data, I could sort it in Excel.
                          Now I have no idea which code pattern to use -could you guide here? Any advices, links? I bought last week a brand-new book by Alex Schreyer, but it didn't help me.
                          Thanks in advance!
                          SketchUp 2015 Pro
                          • brookefoxB
                            brookefox
                            Just a note of thanks, Fredo, for a typically powerful multifaceted, super-documented and pleasing to behold tool-set. If I could master your tools alone, I would consider that quite a worthwhile accomplishment.
                            ~ Brooke
                            • fredo6F
                              Thanks very much for the encouraging appreciation. This one came from a user request some time ago. It's a little bit complex because there are many options and situations where only the user can decide (like selecting a face, a surface or a component). So I have to leave the options open and provide some documentation.
                              • JQLJ
                                JQL
                                Hello everyone,
                                I was trying to generate my first report on areas from a project I have and I came across this question.
                                Is it possible to report the area of a face minus the hole cutting component's areas attached to the face?
                                http://www.casca.pt/varios/reportonareas.jpg
                                The entity info window reports them but I didn't find a way to do that on this tool.
                                Thank you fredo for all the unbelieveable tools... box stretching... perfect!
                                www.casca.pt
                                Visit us on facebook!
                                • H
                                  hking
                                  Report on Areas:
                                  trying to "Export CSV" I get the error code: "Error in generation of CSV file: //filename.csv
                                  please help
                                  Helmut Karger
                                  • fredo6F
                                    NEW RELEASE: ReportLabelArea 2.1a - 09 Jul 15
                                    ReportLabelArea 2.1a fixes a problem related to glued components on faces. Now, for glued components in Cut opening mode, the contact area of theopening is deducted from the area of the face.
                                    • JQLJ
                                      JQL
                                      This update is fantastic Fredo. This issue with glued components was the only thing keeping me from using it! Thank you very much!
                                      www.casca.pt
                                        ak-sam
                                        HI Fredo,
                                        Great tool concept! - this really improves things for those of us who create Site Plans in Sketchup.
                                        But I'm having trouble using the Label Areas function.
                                        I have selected a number of faces, and the areas are being reported when I hover over each one, as well as the total area of all faces. However, the area labels (text tags?) are not appearing when I click "Label Areas".
                                        I checked layer visibility. Is there something else I can try?
                                        If you can sort this out for me I will give you a nice big donation 😄
                                        • fredo6F
                                          You need to:
                                          • Click and drag to place the label
                                          • or double-click to have the label appears without lead line
                                          • noitacN
                                            noitac
                                            Dear Fredo,
                                            your tools are fantastic, as you probably know. They are like the knifes from Switzerland.
                                            One small question:
                                            Trying to export an CSV file, I get a message: "Error in generation of CSV file".
                                            Any idea ?
                                            Best
                                            Carotis
                                            • 2 / 3
