    A Chair From a 2 x 6
    23 Posts 8 Posters 3.8k Views 8 Watching
      I know what you mean. 😆
      • Mike LuceyM
        Mike Lucey
        Nice job Dave 👍 Maybe the bones of an idea for a competition there! What can be done with ?? of ?? x ??
        • mitcorbM
          mitcorb
          I can see how the wing parts might be splined or dowelled to the main sections. Would that be just an interlocking notch (maybe mortise) joint for the two mains?
            Thanks, Mike.
            Those sorts of competitions come up every once in awhile on the woodworking forums. It is simply amazing what some folks manage to tease out of a single board. The problem around here is that construction lumber is usually so lousy, much of a board would be waste.
            Tim, the wings are indeed attached with dowels and the two main pieces are connected with a "halving joint", the same notch cut in both pieces. I think that joint would be left unglued so the chair can be knocked down for storage.
            • mitcorbM
              mitcorb
              Then I would "gild the lily" with some Stanley hardware at that joint, in case Csaba comes over. 💚
                This idea uses just under 10' of 6x2" to make a 'stool' for Csaba !
                Glued and screwed together it'd be pretty indestructible...
                • brookefoxB
                  brookefox
                  Those are nice, Dave. I would say the design should be for a portable, two or three piece assembly. Where's the video?
                  ~ Brooke
                    TIG, that still might be a bit lightly built for Csaba. 😄
                    Brooke, I agree with you. I wouldn't use any hardware to join the seat and backrest.
                    • EscapeArtistE
                      EscapeArtist
                      Used to do Medieval recreation for fun, these chairs were popular. The 2 x 12 chair variant was very similar, and quite portable. Here's an example:
                      http://2.bp.blogspot.com/-6L84mKKeKOM/ToAmGxactWI/AAAAAAAAAJc/X2oq4i6hwG0/s400/IMG_1123.JPG
                        Jeff, I like yours much better.
                          Jonavery16
                          Simple model of the picture. Not exactly accurate but it is made from 1 2x12x8 board
                          Silly Chair.skp
                          • brookefoxB
                            brookefox
                            Thanks for the model, Jon. Why not post a pic?
                            ~ Brooke
                              Jonavery16
                              honestly, because I don't know how 😮
                                Jonavery16
                                http://www.flickr.com/photos/78473902@N04/6879488428/
                                I don't know what I'm doing wrong...
                                • brookefoxB
                                  brookefox
                                  Easy enough. Check here.
                                  404 Not Found
                                  (forums.sketchucation.com)
                                  ~ Brooke
                                    Jonavery16
                                    Indeed that was easy... I was trying to link to Flickr and the image wasn't loading correctly. Thanks
                                    • brookefoxB
                                      brookefox
                                      The image saves lazy guys from DL'ing a model without seeing it. Yours looks nice; maybe a little thin in the scroll back rest members? You've got the important to me interlock for breakdown / portability that the master's original post lacked. Perhaps we'll hear from him.
                                      ~ Brooke
                                        Are you referring to me as "the master"? Surely you jest. If you are, then, whatchoo talkin' 'bout, Willis? 😆
                                        Mine has that interlock you are so infatuated with. 😄
                                        http://farm8.staticflickr.com/7204/6844698736_65c1fbb90e_z.jpg
                                          Jonavery16
                                          Yea, you're probably correct. It is only 1" as drawn.
                                          • brookefoxB
                                            brookefox
                                            Ah, there it is, probably from one of his lackeys. Still, thanks be to him. That kind of side interlock, though, might be subject to more twist/torque wear. I dunno, ain't got sperienze wot u gize got.
                                            ~ Brooke
