    ๐Ÿ”Œ Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
    A Chair From a 2 x 6
    23 Posts 8 Posters 2.6k Views 8 Watching
      http://farm8.staticflickr.com/7197/6989579945_3e66eae8a5_z.jpg
      I was poking around on the net and found this chair someone had made from a 10' length of 2 x 6 lumber. That'd be 3.048 m of 150mm x 50mm lumber (what's the metric word for lumber?) Another fellow did a video showing how he drew it in SketchUp so I thought I'd have a go, too.
        These are typically the chairs that break/collapse when I sit on them. ๐Ÿ˜’
          I know what you mean. ๐Ÿ˜†
          • Mike LuceyM Offline
            Mike Lucey
            Nice job Dave ๐Ÿ‘ Maybe the bones of an idea for a competition there! What can be done with ?? of ?? x ??
            • mitcorbM Offline
              mitcorb
              I can see how the wing parts might be splined or dowelled to the main sections. Would that be just an interlocking notch (maybe mortise) joint for the two mains?
                Thanks, Mike.
                Those sorts of competitions come up every once in awhile on the woodworking forums. It is simply amazing what some folks manage to tease out of a single board. The problem around here is that construction lumber is usually so lousy, much of a board would be waste.
                Tim, the wings are indeed attached with dowels and the two main pieces are connected with a "halving joint", the same notch cut in both pieces. I think that joint would be left unglued so the chair can be knocked down for storage.
                • mitcorbM Offline
                  mitcorb
                  Then I would "gild the lily" with some Stanley hardware at that joint, in case Csaba comes over. ๐Ÿ’š
                    This idea uses just under 10' of 6x2" to make a 'stool' for Csaba !
                    Glued and screwed together it'd be pretty indestructible...
                    ๐Ÿ˜‰
                    • brookefoxB Offline
                      brookefox
                      Those are nice, Dave. I would say the design should be for a portable, two or three piece assembly. Where's the video?
                      ~ Brooke
                        TIG, that still might be a bit lightly built for Csaba. ๐Ÿ˜„
                        Brooke, I agree with you. I wouldn't use any hardware to join the seat and backrest.
                        • EscapeArtistE Offline
                          EscapeArtist
                          Used to do Medieval recreation for fun, these chairs were popular. The 2 x 12 chair variant was very similar, and quite portable. Here's an example:
                          http://2.bp.blogspot.com/-6L84mKKeKOM/ToAmGxactWI/AAAAAAAAAJc/X2oq4i6hwG0/s400/IMG_1123.JPG
                            Jeff, I like yours much better.
                              Jonavery16
                              Simple model of the picture. Not exactly accurate but it is made from 1 2x12x8 board
                              Silly Chair.skp
                                brookefox
                                Thanks for the model, Jon. Why not post a pic?
                                ~ Brooke
                                  Jonavery16
                                  honestly, because I don't know how ๐Ÿ˜ฎ
                                    Jonavery16
                                    http://www.flickr.com/photos/78473902@N04/6879488428/
                                    I don't know what I'm doing wrong...
                                      brookefox
                                      Easy enough. Check here.
                                      http://forums.sketchucation.com/viewtopic.php?f=81&t=25217
                                      ~ Brooke
                                        Jonavery16
                                        Indeed that was easy... I was trying to link to Flickr and the image wasn't loading correctly. Thanks
                                          brookefox
                                          The image saves lazy guys from DL'ing a model without seeing it. Yours looks nice; maybe a little thin in the scroll back rest members? You've got the important to me interlock for breakdown / portability that the master's original post lacked. Perhaps we'll hear from him.
                                          ~ Brooke
                                            Are you referring to me as "the master"? Surely you jest. If you are, then, whatchoo talkin' 'bout, Willis? ๐Ÿ˜†
                                            Mine has that interlock you are so infatuated with. ๐Ÿ˜„
                                            http://farm8.staticflickr.com/7204/6844698736_65c1fbb90e_z.jpg
