    Help needed with organic modelling
    Scheduled Pinned Locked Moved Organic Modelling
    31 Posts 9 Posters 21.9k Views 9 Watching
    • O
      o0rico0o
      Thank you so much, you guys are literally legends! ill have a play around now and let you know how I get on.
      I'm normally quite confident with sketchUp, but this has stumped me. I managed to draw up a gridshell for my last project which was a challenge, have a look here if you fancy seeing a sample of my work http://ricocacciatore.co.uk/sports-centre.html , let me know what you think
      Thanks again guys!!
      • HieruH
        Hieru
        Nice project and judging by the roof you should have no problem with this shape now 😉
        www.davidhier.co.uk
        • O
          o0rico0o
          Hi again guys, still struggling....
          I'm still playing around with shapes but I think I have one that's almost there. I have just downloaded slicer5 but when I attempt to slice it up its telling me that it is not a manifold solid and hence will not slice. Any ideas how to get around this problem, or even what it means?
          Thanks Again
          Rico
            Non manifold means it has internal geometry. Use Thom's Solid Inspector plugin to track it down.
            • mitcorbM
              mitcorb
              Hi, Rico:
              I can tell you what I think it means, and maybe you can figure out how to get around it.
              In modeling, and/or 3d printing, manifold means a fully closed volume. "Absolutely" no gaps, even tiny ones. People use the analogy of "watertight".
              • O
                o0rico0o
                Thanks guys, Thom's Solid Inspector did the trick, and managed to slice up the shape. Now comes the tricky part....
                for each of the layers im going to have to model window mullions of some sort, is there an easy way to do this?
                I would also need to give the skin some thickness, is there any sort of offset plugin that works with curved walls?
                Cheers
                Rico
                • mitcorbM
                  mitcorb
                  Theoretically, any form can be offset by a tool like Fredo6's JointPushPull set. However, based on the images above, you may have some difficulty because of the complexity. With a little bit of planning for setting up central reference points you may want to use either the Scale Tool or FredoScale--both act similarly but Fredo's enhances certain steps. If you group and scale down a percentage that would represent the "wall" thickness, keep in mind you are "offsetting" the top and bottom by the same factor. You will probably have to do some knitting.
                  All that said, there may be some jaw dropping tool out there that I am not aware of.
                  • HieruH
                    Hieru
                    If you used the Artisan method then you could use Joint Push Pull on the proxy to add thickness before subdividing.
                    Using the Curviloft method you can offset each segment to create two sets of profiles that will give you thickness.
                    www.davidhier.co.uk
                    • O
                      o0rico0o
                      ok sweet, thanks alot guys, anyone got ideas about how to cut out holes for the windows?
                      • HieruH
                        Hieru
                        There are so many options, it's difficult to offer advice without seeing exactly what you have in mind.
                        www.davidhier.co.uk
                        • HieruH
                          Hieru
                          That's a really elegant solution 👍
                          The only downside is that I have feeling that Windowizer will only work on single planes (I might be wrong).
                          www.davidhier.co.uk
                            Maybe like this ?
                            "Multiple Face Offset" By Remus 😎
                            Windowizer(3 free or 4) By Rick Wilson @Smustard ("Frame Inset")
                            Windowizer take any form of windows in multiple selection! 😲
                            Selection Only faces by Selection Toys by Thomthom ☀
                            Invert Selection by TIG ☀
                            geodesic domes! 😉
                            http://www.polyloop.net/attachment.php?attachmentid=31242&d=1265075841
                            • O
                              o0rico0o
                              Just tried to use windowizer but no luck, thing it might have something to do with the insane amount of geometry in the thing.....
                              The windows id like to achieve would ideally like to be something like this http://www.archiscene.net/wp-content/uploads/2012/01/Garden-Ribbons-by-ShaGa-Studio02.jpg or thisScreen Shot 2012-03-15 at 20.57.32.png
                              Thanks again guys!
                              • HieruH
                                Hieru
                                For that kind of thing I would create a window component and then try using Component Stringer to add them to each floor.
                                www.davidhier.co.uk
                                • O
                                  o0rico0o
                                  ok thats great, im trying that now. I've intersected the overall form manually then grouped the shape and left the intersection lines which i then welded. When I apply the component stringer the components are scattered randomly due to the geometry of the line, is there any way to smooth the line and then divide it into equal lengths of geometry so that the components get scattered equally?
                                  • HieruH
                                    Hieru
                                    I've only used the plugin for basic stuff so I'm not sure. I'll have a look when I'm back in the office tomorrow.
                                    www.davidhier.co.uk
                                    • O
                                      o0rico0o
                                      great stuff, thanks alot
                                        rspierenburg
                                        I'm not sure what your intended final output of this model is, but could you just use texturing for the windows. I'm just thinking with the number of components you need for windows its going to make the model hard to work with.
                                        • O
                                          o0rico0o
                                          I did think about texturing, but i will be later using the model to generate floorplans, elevations and sections so really need all of the geometry to be there and to be accurate.
                                          • HieruH
                                            Hieru
                                            The only suggestion I can come up with is redrawing each floor profile with a set number of evenly sized segments. You should then be able to do something like this:
                                            StringerWindows.skp
                                            www.davidhier.co.uk
