    Help needed with organic modelling
    Scheduled Pinned Locked Moved Organic Modelling
    31 Posts 9 Posters 21.9k Views 9 Watching
    • O
      o0rico0o
      Thanks guys, Thom's Solid Inspector did the trick, and managed to slice up the shape. Now comes the tricky part....
      for each of the layers im going to have to model window mullions of some sort, is there an easy way to do this?
      I would also need to give the skin some thickness, is there any sort of offset plugin that works with curved walls?
      Cheers
      Rico
      • mitcorbM
        mitcorb
        Theoretically, any form can be offset by a tool like Fredo6's JointPushPull set. However, based on the images above, you may have some difficulty because of the complexity. With a little bit of planning for setting up central reference points you may want to use either the Scale Tool or FredoScale--both act similarly but Fredo's enhances certain steps. If you group and scale down a percentage that would represent the "wall" thickness, keep in mind you are "offsetting" the top and bottom by the same factor. You will probably have to do some knitting.
        All that said, there may be some jaw dropping tool out there that I am not aware of.
        • HieruH
          Hieru
          If you used the Artisan method then you could use Joint Push Pull on the proxy to add thickness before subdividing.
          Using the Curviloft method you can offset each segment to create two sets of profiles that will give you thickness.
          www.davidhier.co.uk
          • O
            o0rico0o
            ok sweet, thanks alot guys, anyone got ideas about how to cut out holes for the windows?
            • HieruH
              Hieru
              There are so many options, it's difficult to offer advice without seeing exactly what you have in mind.
              www.davidhier.co.uk
              • HieruH
                Hieru
                That's a really elegant solution 👍
                The only downside is that I have feeling that Windowizer will only work on single planes (I might be wrong).
                www.davidhier.co.uk
                  Maybe like this ?
                  "Multiple Face Offset" By Remus 😎
                  Windowizer(3 free or 4) By Rick Wilson @Smustard ("Frame Inset")
                  Windowizer take any form of windows in multiple selection! 😲
                  Selection Only faces by Selection Toys by Thomthom ☀
                  Invert Selection by TIG ☀
                  geodesic domes! 😉
                  http://www.polyloop.net/attachment.php?attachmentid=31242&d=1265075841
                  • O
                    o0rico0o
                    Just tried to use windowizer but no luck, thing it might have something to do with the insane amount of geometry in the thing.....
                    The windows id like to achieve would ideally like to be something like this http://www.archiscene.net/wp-content/uploads/2012/01/Garden-Ribbons-by-ShaGa-Studio02.jpg or thisScreen Shot 2012-03-15 at 20.57.32.png
                    Thanks again guys!
                    • HieruH
                      Hieru
                      For that kind of thing I would create a window component and then try using Component Stringer to add them to each floor.
                      www.davidhier.co.uk
                      • O
                        o0rico0o
                        ok thats great, im trying that now. I've intersected the overall form manually then grouped the shape and left the intersection lines which i then welded. When I apply the component stringer the components are scattered randomly due to the geometry of the line, is there any way to smooth the line and then divide it into equal lengths of geometry so that the components get scattered equally?
                        • HieruH
                          Hieru
                          I've only used the plugin for basic stuff so I'm not sure. I'll have a look when I'm back in the office tomorrow.
                          www.davidhier.co.uk
                          • O
                            o0rico0o
                            great stuff, thanks alot
                              rspierenburg
                              I'm not sure what your intended final output of this model is, but could you just use texturing for the windows. I'm just thinking with the number of components you need for windows its going to make the model hard to work with.
                              • O
                                o0rico0o
                                I did think about texturing, but i will be later using the model to generate floorplans, elevations and sections so really need all of the geometry to be there and to be accurate.
                                • HieruH
                                  Hieru
                                  The only suggestion I can come up with is redrawing each floor profile with a set number of evenly sized segments. You should then be able to do something like this:
                                  StringerWindows.skp
                                  www.davidhier.co.uk
                                  • L
                                    ledisnomad
                                    This might not be the best answer, since we are on SketchUcation and all, but have you considered another software package? What you are doing would be much easier in Rhino with Grasshopper, Revit, Bentley GC, or something like that. You could always create the mass and populate it with windows, then bring it back into SketchUp for your other drawings and adding other stuff.
                                    • DareDevilD
                                      DareDevil
                                      Bad idea... If you want a total architectural model, you have to use an architectural CAD or BIM tool. Sketchup is not. SU is a geometrical modeler, so you can imagine use it for elevations but not for complete sections or floorplans in this kind of complex project... Ok, you can do it, but it's not the easiest tool and not the most flexible, as you can make an total architectural model sculpting in a bloc of wood but is better make it with cardboard.
                                      So, my opinion, use SU to make the external model with floors (and with this kind of shape, you better use a NURBS tool like free 123D), use it for elevations, and extract sections and plans and draw all details in a 2D CAD if you don't want to use BIM tool.
                                      • masterpaulM
                                        masterpaul
                                        I found this thread to be a really usefull tutorial.
                                        • O
                                          o0rico0o
                                          Hi Guys, just a little update/ cry for help....
                                          I'm Just working on the facade for this tower in particular the little slats and window details. In doing this I've just realised that I've made a rookie error. I forgot to orient all the faces so that they will render correctly, theres are so many individualfaces that selecting them all or even using front face tool and rolling the mouse over them all will take too long. Is there a plugin that will allow me to select all the faces and then select an face as a basis to orient all the faces in the same direction? heres a little screen dump of what im working with....Screen Shot 2012-04-24 at 19.43.43.png
                                            No problem if all that is copy of components ?
                                            Just edit one instance or a little more complex
                                            Create a new component, select all goto the Components Menu / In Model
                                            RightClick on the icone of the new Component: Replace Selected
                                            If all that is copy of groups Thomthom plug Selection Toy can save you!
                                            Convert into Components - Converts all the group copies into components. Transformation and materials will be transferred.
                                            Useful for when you have a model where groups where used instead of components.
                                            So you will can modify one component as above 😉
                                            If not that is another "rookie error" 😄
                                            If all that is not components or groups
                                            if you are very lucky maybe right click on a white face / Oriente faces do the trick in one time
                                            That will say that you have made a curious modeling 😉
                                            (but I doubt)
                                            In last chance Fredo 6 has made a plugin Reverse orient face who can maybe help you
                                            in a hand workflow
                                            At the end maybe some TIG plug can make something like fix reverse side Material ?
                                            If all that don't make the trick, your last chance is a persannal plug cooks by TIG with
                                            maybe a special selection of a similar face ?
                                            Bu we must wait more details of the situation 😄
                                            or maybe a file skp
                                            • 2 / 2
