    The "Duh!" thread (aka the Doh! thread)
    696 Posts 135 Posters 314.1k Views 135 Watching
    • jgbJ Offline
      jgb
      I've had several cases where I had to modify a component which I could not see clearly because of the external surrounding structure. Layering and hiding was not a good solution, as I needed some externals as reference to the edits, and then all that relayering and hiding had to be reversed out.
      Select the component and any reference externals and simply Move/Copy them well into free space.
      Do the edits, using temporary layers and hides only on the copies as needed.
      When done, delete the copies and any temp layers.
      jgb
      • kenK Offline
        ken
        Well I can thank DaveR for the "Duh". In another thread he convinced me that using components was the only way to model. So I made a series of components that I wanted to keep in my template file. So modeling away, I had a nice bunch of components for future use.
        So I cleaned up the screen because I wanted a clean screen when I open the template file. Than I purged the model components because I didn't want any components that I didn't need in the template and saved the file as template to use.
        So, need I say more. The template had no components. "Duh".
        Thanks Dave, you did me a favor, I just forgot how to use Sketchup.
        • cottyC Offline
          cotty
          My Duh! of the day was in this thread: http://forums.sketchucation.com/viewtopic.php?f=22&t=8046
          • Use the eraser tool to select some edges
          • Don't release the left mouse button
          • Click the spacebar
          • Release the left mouse button and the selection still remains without deletion
          my SketchUp gallery
            That does not really deserve a "Duh". Although it is obviously an extremely nifty trick, that is not the intended use of the autoselect function of the Eraser tool.
            So I would have not been ashamed if I had not known about it yet (and I also learned it from the forums of course)
              Charlie__V
              Not sure if this qualify's as a Duh!
              & perhaps mentioned before..........though I do not recall seeing it.
              I have frequently experienced a "slow save" on certain models and not so much on others.
              While working my current model with lots & lots of bolts/nuts/washers..it occured to me that the delay in save may be tied to the "redefine thumbnail on save" option in...........Model info>>>>>File>>>>>Redefine Thumbnail on save.
              Sure enough.......un-ticking the "redefine thumbnail on save" resulted in a 10x faster "save" than with this selected.
              For me the thumbnail being current is no concern......I prefer the quick "save"
              Best,
              Charlie
              PS............wonder if this contributes to the Bugsplat on save/close??
              • Wo3DanW Offline
                Wo3Dan
                Thanks Gaieus, you've sent me here because I've up until now completely missed the "always face camera" component method you provided here:
                http://forums.sketchucation.com/viewtopic.php?f=15&t=43251
                ๐Ÿ˜ฒ
                  That was actually a semi-duh moment to me as well. I had not known it was going to work but had to try, you have to admit. ๐Ÿ˜„
                  • oganocaliO Offline
                    oganocali
                    This thread is one of my favorites, I use it as a guide for really neat tricks which most users will eventually need to find out, except it is a bit disorganized. I think some sort of index would be useful here. I may be setting up myself unwittingly for my d'oh moment like the use of advanced search inside a topic or something.
                    cheers
                    • david_hD Offline
                      david_h
                      Organization of the D'uh Thread would seem to me to be an Oxymoron. (for me its more Moron than Oxi . . ) but I digress. . .
                      the whole purpose of the thread is for people to post whatever epiphany they have or discovery they make when it occurs. Ya never know what you're gonna get. . . That is what makes the the SU Forum so much like a box of um . .. um . .. . what is the expression???? ๐Ÿ’š
                        oganocali
                        I totally agree with you on the spirit of this thread. It is just that finding one post in 20+ page (considering forum pages can be quite long) thread is not easy. I usually remember there was a trick as someone's doh! moment to do what I want, I just can not remember who or where the trick was.
                        • dereiD Offline
                          derei
                          I totally agree with the fact that Duh moments get lost between posts and is really hard to follow them now.
                          DESIGNER AND ARTIST DEREI.UK
                            I had one of those DUH moments regarding the forums as well... ๐Ÿ˜’
                            • dereiD Offline
                              derei
                              Usually searching works when you know exactly what you want... if I want to find "something that was somehow... I don't know exactly, but I can recognize if I see it", I'm sure that search box won't help ๐Ÿ’š
                                Maybe this is yet known but I just discover that today ๐Ÿ˜ณ (Thx Chri)
                                With the follow-me, no need to select only the path, before call the Follow-me!
                                Click the surface is sufficient ! ๐Ÿ˜ฒ
                                I made Double clicks on the surface then Shift + Ctrl for deselect it for have only the path ๐Ÿ’š
                                (Double click Without deselection works also but... ๐Ÿ˜ณ
                                Here just 3 simple clicks ๐Ÿ˜Ž
                                  That's a new Duh! moment for me!!
                                    Is it? ๐Ÿ˜„
                                    Interesting although admittedly I also have duh moments on trivia sometimes.
                                    Note however that is there is a soften edge (say a diagonal) in the face, the follow me will not go completely around - not even when simply double clicking. In this case Pilou's "original" method: Double clicking then deselecting the inner (sur)face will do the job though.
                                    So basically it only woks with single faces. Not even with coplanar but subdivided faces.
                                    • jgbJ Offline
                                      jgb
                                      Another thing with Follow-Me I discovered a while back (and reported) is when you are defining a path that has curves, place the template face somewhere on a straight portion of any line segment, NOT at an endpoint. ๐Ÿ˜ฎ
                                      If follow-me starts on an endpoint, the face template follows one of the subtended angles and royally screws up at the end, with an end face out of alignment. This is especially a major factor with closed loops. ๐Ÿ‘Ž
                                      However, if started on a straight section, it will end perpendicular to the last line of the path, and if the path is a closed loop, it will join properly. ๐Ÿ‘
                                      jgb
                                        Useful to know! ๐Ÿ‘
                                        • broomstickB Offline
                                          broomstick
                                          I've seen this pointed out before, but I just discovered that while orbiting with the middle mouse pressed, if you press the left button, orbit becomes pan.
                                          It's a useful way to orbit/pan without using two hands ๐Ÿ˜„
                                            Mini Doh ๐Ÿ˜ณ (due forgotten function) ๐Ÿ˜’
                                            • Alt gives you the possibility to Move a segment escaping at the X Y plan ๐Ÿ˜‰
                                            • 15
                                            • 16
                                            • 17
                                            • 18
                                            • 19
                                            • 34
                                            • 35
                                            • 17 / 35
