    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 96.7k Views 23 Watching
      SUFractal
      @tomot said:
      It should be noted that not all ceiling tiles are designed to simply drop into the metal grid, some manufacturers also provide Ceiling tiles that do indeed project below the metal grid hence providing a nice rebated look to the entire ceiling.
      Regardless its great to see the option of adding real tiles or using a texture map. πŸŽ‰
      Good point tomot ... I agree with you.
      One benefit of the individual tiles being created is the ability to switch them out with a lighting fixture.
      • gullfoG Offline
        gullfo
        @tomot said:
        Hi:
        Dear sdmitch,your plugin nice,maybe have little need to change:
        Please lets not get carried away here! whats ... next a request for the actual supporting hanger holes and hanger wires? πŸ‘Ž
        next thing people will want an algorithm to place light and vent openings πŸ‘Ώ πŸ‘Š
        Glenn
        http://www.runnel.com
        • sdmitchS Offline
          sdmitch
          @sufractal said:
          Sdmitch ... I was getting an odd result when I tried your latest update. Some of the tiles were positioned low, and some were high ... and faces were flipped too?
          Was this a one time thing or have you had this result on other occasions. I have never seen this.
          Anyone else having this problem?
          http://sdmitch.blogspot.com/
            SUFractal
            I tried a handful of times and kept getting the same result unfortunately. And it was a simple rectangular ceiling shape.
              tomot
              FYI: In several previous version I was able to add tiles sizes, see attached pic, when I do the same with the current version I get a ruby console error Ceiling Grid.rb:95:in `max'
              [my plugins](http://thingsvirtual.blogspot.ca/)
              tomot
              • sdmitchS Offline
                sdmitch
                tomat, check the case of the "x" in the options. It looks like lower case which will not match the "X" in the case statement.
                • gullfoG Offline
                  gullfo
                  seems to work perfect. including complex ceilings. but... if you have the face @ zero on the z-axis, you do see the inverted faces which are flush with the grid and not dropping through. so just make sure your ceiling face is above the zero plane... then again i may have spoke too soon... a complex ceiling definitely exhibits some strange results even when sitting above the 0 on z-axis...
                  ceiling tile example
                  result from face @ zero on z-axis
                  complex ceiling.skp
                  Glenn
                    SUFractal
                    Each time I've tried (and just did again), my ceiling plane was 'elevated'. The plugin worked perfectly until this last tweak ... I'm no programmer or ruby person, but it would appear something occurred w/in the last effort?
                    I've also tried both 2 x 2 and 2 x 4 grids.
                      tomot
                      YES! YES!...... I forgot to read my own Sticky note "Watch the use of case" 😳
                      (if the SU API Ruby Console was more inclusive by incorporating the entire Ruby reference perhaps this error would have been properly flagged when a script is run)
                      tomot
                      • sdmitchS Offline
                        sdmitch
                        Apparently all my test shapes have been at Z=0. Elevation does matter. Sorry about that.
                        Well at least I thought elevation mattered. I did a move/copy on a shape and elevated it. When I ran the plugin, I got the pulled down faces without texture, but when I created a elevated shape, it didn't have the problem. I then tried to duplicate the create at Z=0 and move/copy to an elevation and results were normal! What a lovely thing an intermittent problem is!!!
                        • Z Offline
                          ZFRPS
                          first,I need to speak sorry,and i get carried away for this plugin,because i believe this plugin is one of "BIM" plugins,BIM need details ,if this can done , I hope !
                          However,i must thanks sdmitch and everyone again,this plugin is great.
                          sketchup is bim
                          • gullfoG Offline
                            gullfo
                            yea, being its occurring over several runs, it may be a variable scope issue where something is persisting which causes the subsequent run to make incorrect assumptions...
                            Glenn
                              Ben Ritter
                              Sam, thank you. Good stuff!
                                SUFractal
                                Sam, I had tried both methods you described, but still had the same issues.
                                • sdmitchS Offline
                                  sdmitch
                                  Ok, I have done about all I can do with this plugin. I have tested numerous shapes including gullfo's and the plugin produced the expected results, with minor exceptions, without fail using all size,origin,rotation options while creating tiles.
                                  zfrps, I fixed that "gap" thing for you.
                                    SUFractal
                                    Working OK from what I can see. Thanks so much sdmitch!
                                    • guanjinG Offline
                                      guanjin
                                      Create a surface option is not valid, how the choices that are surface
                                      Choose, or have surface
                                        tomot
                                        You do have a surface now, you can place a texture on the entire surface, unfortunately I would have preferred to see the use of individual tiles as we had previously. I inadvertently over wrote and did not save the last script. Perhaps if sdsmith is not getting tired of this yet πŸ˜„ he could introduce 3 choices: none, tiles, surface.
                                        tomot
                                        • sdmitchS Offline
                                          sdmitch
                                          You get the "surface" if you say "No" to Make Tiles. If you don't want the surface, simply delete it.
                                          • guanjinG Offline
                                            guanjin
                                            We asking for too much, thank you for the great plug πŸ˜‰
                                            • 2 / 5
