    [Plugin] Generate Ceiling Grid (Updated 27-Mar-2014)
    99 Posts 23 Posters 110.7k Views 23 Watching
      SUFractal
      @gullfo said:
      seems to work perfect. including complex ceilings. but... if you have the face @ zero on the z-axis, you do see the inverted faces which are flush with the grid and not dropping through. so just make sure your ceiling face is above the zero plane... then again i may have spoke too soon... a complex ceiling definitely exhibits some strange results even when sitting above the 0 on z-axis...
      Each time I've tried (and just did again), my ceiling plane was 'elevated'. The plugin worked perfectly until this last tweak ... I'm no programmer or ruby person, but it would appear something occurred w/in the last effort?
      I've also tried both 2 x 2 and 2 x 4 grids.
      • T
        tomot
        @sdmitch said:
        tomat, check the case of the "x" in the options. It looks like lower case which will not match the "X" in the case statement.
        YES! YES!...... I forgot to read my own Sticky note "Watch the use of case" 😳
        (if the SU API Ruby Console was more inclusive by incorporating the entire Ruby reference perhaps this error would have been properly flagged when a script is run)
        my plugins
        tomot
        • sdmitchS
          sdmitch
          Apparently all my test shapes have been at Z=0. Elevation does matter. Sorry about that.
          Well at least I thought elevation mattered. I did a move/copy on a shape and elevated it. When I ran the plugin, I got the pulled down faces without texture, but when I created a elevated shape, it didn't have the problem. I then tried to duplicate the create at Z=0 and move/copy to an elevation and results were normal! What a lovely thing an intermittent problem is!!!
          http://sdmitch.blogspot.com/
          • Z
            ZFRPS
            first,I need to speak sorry,and i get carried away for this plugin,because i believe this plugin is one of "BIM" plugins,BIM need details ,if this can done , I hope !
            However,i must thanks sdmitch and everyone again,this plugin is great.
            sketchup is bim
            • gullfoG
              gullfo
              yea, being its occurring over several runs, it may be a variable scope issue where something is persisting which causes the subsequent run to make incorrect assumptions...
              Glenn
              http://www.runnel.com
              • B
                Ben Ritter
                Sam, thank you. Good stuff!
                  SUFractal
                  Sam, I had tried both methods you described, but still had the same issues.
                  • sdmitchS
                    sdmitch
                    Ok, I have done about all I can do with this plugin. I have tested numerous shapes including gullfo's and the plugin produced the expected results, with minor exceptions, without fail using all size,origin,rotation options while creating tiles.
                    zfrps, I fixed that "gap" thing for you.
                      SUFractal
                      Working OK from what I can see. Thanks so much sdmitch!
                      • guanjinG
                        guanjin
                        Create a surface option is not valid, how the choices that are surface
                        Choose, or have surface
                        • T
                          tomot
                          You do have a surface now, you can place a texture on the entire surface, unfortunately I would have preferred to see the use of individual tiles as we had previously. I inadvertently over wrote and did not save the last script. Perhaps if sdsmith is not getting tired of this yet πŸ˜„ he could introduce 3 choices: none, tiles, surface.
                          my plugins
                          tomot
                          • sdmitchS
                            sdmitch
                            You get the "surface" if you say "No" to Make Tiles. If you don't want the surface, simply delete it.
                            • guanjinG
                              guanjin
                              We asking for too much, thank you for the great plug πŸ˜‰
                              • RonSR
                                RonS
                                Works like a charm for me. Thank You Sam for all of your hard work.
                                Design is not just what it looks like and feels like. Design is how it works.
                                Steve Jobs
                                RonS
                                • guanjinG
                                  guanjin
                                  No matter how select all the options are in the middle, invalid!!! πŸ˜’
                                  • T
                                    tomot
                                    I was mistakenly concerned that I would not be able to remove individual panels in order to create light panels. But that is not the case, the Surface can be intersected with the model (namely the Grid), by right-clicking the context menu. Now that the Surface and the Grid have been intersected, individual panels can be be removed as required, for lights. thanks again sdmith
                                    my plugins
                                    tomot
                                    • sdmitchS
                                      sdmitch
                                      The "Origin Pt:" selection controls the position. If "Corner" gives you the same
                                      results as "Center" then you appear to be the only one.
                                      • guanjinG
                                        guanjin
                                        The same surface option, is invalid, only the first option is effective!
                                        πŸ˜’
                                        • sdmitchS
                                          sdmitch
                                          πŸ˜’
                                          If Make Tiles = Yes, you get a group of tiles, one for each "cell", which are painted with the current material. If Make Tiles = No, the original selected shape is painted with the current material . If you don't want a ceiling, simply delete the "Ceiling" group.
                                          If you seperate the Ceiling from the Grid, you will see this difference more clearly.
                                            SUFractal
                                            Thanks for all the hard work and updates sdmitch!
                                            • 4 / 5
