    [Plugin] Architect Tools
    119 Posts 32 Posters 166.8k Views 32 Watching
    • DareDevilD Offline
      DareDevil
      I dont know how the remaining time is computed, but when the Generate Buildings sequence started it was 20 minute ; finally the works take 2 hours and 30 minutes !
      Fortunately, it made what I was waiting 😄
        The estimated remaining time is based on how much time it has taken to process the current set of entities vs the remaining. The problem is that adding geometry to SketchUp gets slower the more geometry there is - which is problematic to estimate. I haven't even tried to account for that.
          Why not use a '% complete' report ?
          It changes to show it's working and the user then knows how much is left to do...
          If THEY assume the second 50% will take as long as the first 50%, then that's their issue not yours.
          All you will have done is told them how much has been processed so far, and that it is actively continuing...
            I was reusing some generic code - which for linear time code works well.
            I am working on a version 2 where I am cleaning up lots of stuff. Everything has so far just been quickly assembled to automate tasks I've been working on.
              DareDevil
              I dont know if it's many or not, the process made 7,000 groups. My computer is a i5 @2.4 GHz with 3 Gb RAM. It's not a race computer but is not a Minitel...
              For this job, the problem was'nt the time but just my wife asking me "when you will be back home ?"... "SU says in fifty minutes..." and half an hour later "SU says in one hour...". SU is a liar !! 😆
                Many or not many - doesn't matter. The time it takes to add geometry in SU slows down every time more geometry is added.
                • guanjinG Offline
                  guanjin
                  Help loading error!
                    That's strange - can't quite pin-point where the error is. "eval" error..
                    Exactly what SketchUp version do you have?
                    And what TT_Lib2 version?
                    Did you just install Plan Tools and got the error on first run? Or did it suddenly appear?
                    Can you open the Ruby Console and type:
                    load 'tt_plan_tools.rb'
                    post back any error-messages.
                    • guanjinG Offline
                      guanjin
                      Starts running, and later has been an error
                      sketchup8M2
                      Latest
                        Can you explain more. It's very hard to debug with so little info.
                        And did you try the Ruby Console command?
                          @hygicell said:
                          after installing "plan tools", "edge tools", "quadface tools" and "additional plugin folders" (I used your installer for that),
                          I get the following error messages:
                          The ones that relate to my plugins appear to be a result of not having TT_Lib2 installed. It's a library listed as a requirement for most of my plugins. You find a link to it in the Requirement section of the description.
                            @Frank
                            Please correctly install thomthom's missing Lib...
                            But a problem persists with my tools [almost certainly with different error messages] then perhaps you have mis-installed the 'flattentoplane' and/or 'workplane' scripts too - so, reread their threads to ensure that you also have everything installed that is needed for those tools too [e.g. the first one needs the second one to make the workplane needed to be flattened too]...
                            It might be that one tools error generates another, but if there are several overlapping errors it is harder to resolve,,,
                            I also see you have '000_AdditionPluginFolder' loading... unless you are specifically expecting files located in folders other than Plugins and Tools to be auto-loaded at startup then you do not really need this... Its error reporting is really specific to itself, but if you have mis-installed another script's files then its messages can also be somewhat confusing, since the replicate much of the normal error reports too, with overlaid info...
                            • H Offline
                              hygicell
                              more:
                              Error Loading File #FlattenToPlane.rb
                              no such file to load -- #WorkPlane.rbError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/close_gaps.rb
                              uninitialized constant TTError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/core.rb
                              uninitialized constant TT::Plugins::EdgeTools::PREF_KEYError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/divider.rb
                              undefined method add_item' for nil:NilClassError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/make_colinear.rb undefined method add_separator' for nil:NilClassError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_EdgeTools/simplify.rb
                              undefined method add_separator' for nil:NilClassError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb uninitialized constant TT::Plugins::QuadFaceTools::PLUGIN_IDError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/bim-tools/clsBtEntity.rb undefined local variable or method ' for main:Object
                              PS I have apparently solved the Bim Tools error thanks to Jan's and your and other's help
                              thanks to all !
                              greetings
                              Frank
                              • H Offline
                                hygicell
                                I have learned how to follow your very adequate instructions, Thom
                                so TT_Lib2 was and still is installed
                                should I delete and renew it ?
                                  Ensure you have the latest version of that Lib.
                                  Otherwise. if you STILL get errors after updating, then it might be [the superfluous] '000_AdditionPluginFolder' throwing up errors, when you have not installed all of the scripts needed for 'my tools' ???
                                  • H Offline
                                    hygicell
                                    @tig said:
                                    @Frank
                                    checked that, Tig, it was installed, should I delete and reinstall?
                                    I am pretty sure it is the latest version, as I installed it the same day
                                    checked that too, both files were missing. Installed them. The errors still keep popping up
                                    [b]although it is obviously loading, I can't find it anywhere (to delete it):[/b]
                                    Frank
                                    PS you guys are fabulously helpful !!!
                                    tell me how to donate !
                                    Thomthom already knows I do
                                      hm... might be that the files have ended up in VirtualStore because you don't have full permissions to the Plugins folder. Here's a way to check for that: http://sketchucation.com/forums/viewtopic.php?f=180&t=48399
                                      It's a but difficult to debug when you've installed so much at the same time and get so many errors spread across multiple plugins. :s
                                      • H Offline
                                        hygicell
                                        downloaded and installed,using your installer
                                        still same errors at startup:
                                        undefined method `add_separator' for nil:NilClassError Loading File C:/Program Files (x86)/Google/Google SketchUp 8/Plugins/TT_QuadFaceTools/core.rb
                                          You do NOT have FULL security permissions 1.PNG aka 'Compatibility Files...'...
                                          Click that link-button to see the mess you have unleashed...
                                          Follow the link thomthom gave which goes a long way to resolving this...
                                          There are several folders in the Sketchup folder - like Plugins, Materials, Components and Styles - that all need FULL permissions to allow you to add files and subfolders to them etc, and also to use some tools that will need to write log files into there etc.
                                          To fix these folders' permissions [as an Admin] right-click each folder's icon and get Properties > Security > Edit - set to be 'FULL' - this needs to apply to all contained files and subfolders...
                                          Simply being an Admin is NOT enough... 😒
                                            Do you still have that AdditionalPlugins folder installed? Or some similar plugin?
                                            It seems something is loading the files in incorrect order.
                                            Did you check the virtual store?
                                            (Please answer to each of the questions we ask. Each are important in order to debug this.)
                                            • 3 / 6
