    OS compatibility issue
    15 Posts 4 Posters 745 Views 4 Watching
    • tridemT Offline
      tridem
      Thanks to all for the responses πŸ‘ , so there's actually a pc/mac issue, it's a good start to me having checked this.
      I don't think the problem is related to the compression, I've zipped it only to post here the file, originally we copied the whole unzipped folder.
      This one is the PC version, I cannot take the MAC copies yet, for a few days.
      Yes, the starting texture is the same for all, while the material colors change. Perhaps I'll rebuild the material with the MAC in order to compare the two SKM files
        driven
        I didn't realise you can open the .skm 'folder' with archive utility...
        when I check against any random SU or Arroways .skm the differences are
        1: yours use http://sketchup.google.com/schemas/
        all others use http://www.sketchup.com/schemas/
        2: yours uses the same 'uncloloured' Ref PelleBump_1.jpg
        all others use coloured Ref jpgs
        I can /Applications/Google SketchUp 8/SketchUp.app/Contents/Resources/Textures/Sketchy_Straight_Siding.jpg
        but it's an odd format I can't open, maybe compiled??
        I can't find any of Arroway's textureFilename="plaster-006_d100.jpg"that relates to <mat:image id="1" path="plaster-006_d100_1.jpg"/> yet [just doing a unix search which will find it if it's on my computer]
        maybe you can make more sense of all this.
          driven
          @tig said:
          If you copy the SKM over from PC to MAC, without it ever being inside a ZIP file is there any difference ?
          Is a .skm more than a renamed zip file?
          If it is a zip in disguise, would you need to gzip the source files on mac to avoid .DS_Store?, which .skm's don't have [until you unzip and open the folder].
          • tridemT Offline
            tridem
            not at all πŸ˜†
            at this point I'm quite sure it's something related to the uncoloured texture, I've seen the material management is the most different part between mac and pc, maybe they codify the colour overlay in a different manner...?
            • tridemT Offline
              tridem
              mmm...I've noticed a strange thing
              <mat;material colorBlue="40" colorGreen="40" colorRed="183" colorizeType="0" hasTexture="1" name="Pelle Rosso"
              perhaps colorizeType should be "1", seems it makes no difference in my pc, how about mac?
              • tridemT Offline
                tridem
                How do you see them now on mac?
                Pelle Rivestimento.zip
                  driven
                  it's the same grey in SU,
                  heres a standard mac SU.skm is it different than the standard PC
                  Stone_Marble.skm
                  • tridemT Offline
                    tridem
                    as I can see is exactly the same πŸ˜’
                      driven
                      and this Al Hart arroway one?
                      it's a single download for both platforms and it works...
                      metal-plate-005_Arroway-lo-res-Arroway-low-res.skm
                        driven
                        this works,
                        1 added the color to the PelleBump_1.jpg then re-zipped using YemuZip, should be PC friendly.
                        but there's something else blocking doing the same to the others...
                        can you do a dif on this file and see what else I or SU have changed, because I think it did...
                        Pelle Rosso.skm
                        • tridemT Offline
                          tridem
                          no differences, except your reference image is colored
