    Transition from oval to round?
    18 Posts 10 Posters 5.3k Views 10 Watching
    • Wo3DanW
      Wo3Dan
      Here's a simple method:
      • draw a circle, correct radius, with an even number of segments
      • draw a centerline (preferably one that runs parallel to a drawing axis)
      • pull up one half of the circular face to desired height
      • move that extruded half circular top face to the side, perpendicular to the centerline's axis (that's way axes constraining makes it so easy)
      • repeate "pulling up and shifting to the side"-process for the other half circular face. The shifting however is in opposite direction.
      • fill in the two missing 'lozenge' segments, to comple the lozenge.
      • GaieusG
        Maybe another method.
        • Alan FraserA
          Alan Fraser
          Transitioning from a true oval (not a lozenge) to a circle couldn't be easier. Simply draw a circle, extrude it, then scale to top face in one direction while holding down Ctrl.
          3D Figures
          • GaieusG
            Ah yes, Alan, but according to the image in the first post, it's indeed a lozenge... (Otherwise Fredoscale could be used to "scale" it to a lozenge, too)
            • Alan FraserA
              Alan Fraser
              Yes, I noticed that. I also noticed that it's a negative shape...unlike your's, mine or anybody else's examples. 😉
              Not that that would make any difference if you were merely going to stitch the nodes together.
              3D Figures
              • GaieusG
                Well, often simply stitching is the fastest and easiest way actually. 😉
                  One more way. No plugins needed.
                  Draw a circle. Drag radius out on axis.
                  Rotate circle so edges are on axis. If you use a default 24-sided circle, rotate the circle 7.5 degrees.
                  Use Push/Pull to create cylinder.
                  Select top edge, right click, choose Explode Curve.
                  Use a left to right selection box to select half of circle*.
                  Use Move tool to move the selection the required distance.
                  Repeat for the other side.
                  It's not really half of the circle. It's half minus the two edges that will be the long edges of the lozenge.
                  • Jean LemireJ
                    Jean Lemire
                    Hi folks.
                    See this SU file for ideas.
                    Circle to rounded rectangle transition.skp
                    • dereiD
                      derei
                      @tig said:
                      What was originally show isn't an 'oval', it's a 'lozenge' - a rectangle with rounded ends.
                      This means that the suggested method of scaling a circular top of a cylinder into an 'oval' [ellipse] won't work.
                      The lozenge has at least two extra segments around its perimeter compared to the simple circle [4 as drawn!], that is assuming that the two semi-circular ends have the same number of segments as half of the full-circle.
                      Sorry for off-topic, as I'm not a native english speaker, I'm always interested in learning.
                      I always thought that "lozenge" is something else, and Wikipedia says the same http://en.wikipedia.org/wiki/Lozenge
                      Also, there seems to be a slight difference between oval and ellipse as they show it here http://en.wikipedia.org/wiki/Oval
                      So, what's the name of this shape formed by two half of circle joined by segments?
                      DESIGNER AND ARTIST DEREI.UK
                        An ellipse is a geometrical figure - a circle is a special case of an ellipse, where both axes are the same length.
                        An oval is a more general term meaning 'egg-shaped'; so it could refer to an ellipse OR to a non-elliptical egg form.
                        A lozenge can indeed be a 'diamond-shape' - this comes from 'heraldry' [many rhomboid shapes with two axes of symmetry [that are not 'oblongs'] can be thought of as 'lozenges']... but today most English speakers will hear the word 'lozenge' and think of something that is a rectangular shape with rounded [rather than pointed] ends - like a throat-lozenge candy/sweet made that shape so it is easier to suck/swallow - this kind of 'lozenge' usually has two ends that are are semi-circular, although four rounded corners can also make a 'lozenge-like' shape... See here http://www.google.co.uk/search?q=lozenge+shape&hl=en&prmd=imvns&source=lnms&tbm=isch&ei=dy89T4idC8Sg8QOgxLmnCA&sa=X&oi=mode_link&ct=mode&cd=2&ved=0CBEQ_AUoAQ&biw=1440&bih=779#hl=en&tbm=isch&sa=1&q=lozenge+shaped&pbx=1&oq=lozenge+shaped&aq=f&aqi=&aql=&gs_sm=3&gs_upl=6128l6128l0l6339l1l1l0l0l0l0l0l0ll0l0&bav=on.2,or.r_gc.r_pw.r_qf.,cf.osb&fp=d35ae3f6e2e6993b&biw=1440&bih=779
                        • dereiD
                          derei
                          @ TIG
                          Thank you very much! I always cherished your help and explanations.
                          • mitcorbM
                            mitcorb
                            I am glad that TIG was able to help you.
                            • GaieusG
                              This is what our beloved SU (pro) companion, LayOut draws as a lozenge.
