    [Plugin] CleanUp
    974 Posts 217 Posters 834.1k Views 217 Watching
    • Y Offline
      yanakhokho
      Thank you very much! You are doing an excellent job!
      and a special thank you for your patience and quick responses! I will try next time do not be silly!
        It is working now?
          AlainBo
          Hello,
          When I export my model with LumenRT, it fails because it finds a zero length vector !?!
          It seems Cleanup cannot find such problem.
          How to find it?
          Is it possible to improve cleanUp to take it in account?
          Alain
            Hello,
            How to find it?
            Alain
            Can you provide a sample model?
            This zero length vector - is that from an error you get? Can you post the whole error?
            It could be that it is a bug in LumenRT's exporter - and not a model problem.
              AlainBo
              I found the problem, not precisely but it was related to a scene and not to the model.
              I did't really understand what caused the bug but it's sure it's not a geometry issue.
              Thanks a lot.
                tspco
                What did I do wrong? I just downloaded and installed cleanup 3.1.9 and latest ttlib 2.6 I open the model and run the plugin, The screen goes gray, and a long gray box appears with no options to select from. The ttlib file goes into the compatibility files folder, I think that is the problem. I cannot move in back into the regular plugins folder
                SU make 2017, /Twilight Render Hobby
                Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                  tspco
                  I read back a few pages and found the issue, I now have the tt simple installer, and all "appears" as it was.
                    Ensure that you have 'full access rights' to the Plugins folder [select its icon Properties > Security ...].
                    Also do the same for Components, Materials and Styles...
                    This will stop 'Compatibility Files' issues - where Vista stops you moving files/folders into certain 'program' folders to protect you from yourself if you have limited access rights... With full-rights it should behave...
                      tspco
                      I apparently already set permissions for everyone but the creator owner will not change, I am sure it is a windows thing I really don't need to know.
                        Why mess with that just give yourself 'full-permissions'...
                        • genma saotomeG Offline
                          genma saotome
                          Dunno if this has been mentioned before (40 pages is a lot to go thru) but the statistics presented afterwards are off. I'll run cleanup and be told it cleaned out quantities a, b, and c of types x, y, and z... do nothing, run cleanup again and be told it cleaned out quantities a, b, and c of types x, y, and z... and... rinse and repeat forever. Version 3.1.9.
                          I like the results... but I do wish it would tell the the straight story when it was done.
                            It's because SU some times doesn't heal broken edges after all - probably some accuracy issue. To rework it to be 100% accurate might slow it down significantly. I figured that the stats being in the ball park would be good enough.
                              genma saotome
                              Edges... that was one... ok, I understand. One of the others I recall now was a count of deleted components. Would delete 13, then another 13, etc., etc.
                              In truth, the numbers are a nice thing but not essential. I figure if you're aware and later happen to notice something the two might click and something gets fixed. Otherwise, oh well.
                                ?!? Got a sample model for that?
                                • john2J Offline
                                  john2
                                  how can i make cleanup not delete coplanar lines (like imported drawings from cad) which are locked?
                                  Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                    I have that in the list of bugs: https://bitbucket.org/thomthom/cleanup/issue/2/locked-groups-components-are-cleaned-up
                                    • john2J Offline
                                      john2
                                      so when do we see this "don't delete the lockd objects version?" πŸ˜‰
                                      • kingsiK Offline
                                        kingsi
                                        Already said thanks for this plugin before, but felt had to say Tusen Takk!! when it just cleaned out 3million lines lol. Bloody genius
                                        Noobtastic
                                          πŸ‘ πŸ˜„
                                            kandehalux
                                            dang it....sorry for bothering, love your plugins!
                                            now a problem occured with the installation of cleanup:
                                            the TT_Lib2 is in the Plugins folder, the cleanup.rb is in the plugins folder.
                                            but when starting up sketchup i get this message:
                                            Error Loading File tt_cleanup.rb
                                            uninitialized constant TT::GUI
                                            in the forum i found suggestions with missing dlls on various windows, but no change. other plugins work fine.
                                            I'm on Win7 x64 using Sketchup 8.0.3117
                                            in addition i have to say,
                                            previously i resetted my pc and of course installed sketchup. before that, cleanup worked like a charme. i still have a backup of the old installation, so i tried using the older version of cleanup and ttlib, but i got the same message.
                                            any idea?
                                            • 48
                                            • 49
                                            • 7 / 49
