    Layout wishlist
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    84 Posts 24 Posters 47.7k Views 24 Watching
      samyell77
      Better compatibility with excel / spreadsheets / table. Its a very long winded process at the moment (export csv, copy to excel, reformat, copy to word, final format, insert to LO with varying results!)
      SU Pro 2016
      Dell Precision M4800
      PC Windows 10
      Intel Core i7-4900MQ @ 2.80ghz
      Nvidia Quadro K2100M
      16gb RAM
        I agree about better text handling for data in tables although I do get dependable results going from CSV>Excel>Word>RTF>Insert into LO. It would be nice to be able skip some steps.
        • pbacotP
          Yes, more integration. They gave us something now we want more of the same! ๐ŸŽ‰
          Is a short cut Excelโ€”> print pdfโ€”> insert to LO? When you re-save the pdf LO can update. I guess you are getting some editable text your way? I used to concern myself with that in Excel to CAD but now find it better just to go back to Excel for changes.
          I try to avoid Word where possible, but can't give up Excel yet (although it also drives me nuts at times). For drawing work I might try using Apple "Numbers".
            Right clicking on the text box in LO brings up "Open in text Editor" which on my PC opens Word. I can then quite easily edit the text. the tables I use don't have a grid like the table has when copied from Excel into Word. I convert the table to tab separated text in Word.
              samyell77
              Thanks Dave R - this is what I do too but I need to display cells / spreadsheet borders and what ever way Ive tried seems problematic. Better compatibility with tables and spreadsheets would be great - it would save a lot of time reformatting for a lot of people and just cuts down on margin for error. The PDF method could work but the ideal would be to be able to link to an excel table or effectively display a table (with borders) in LO. The mac version allows you to copy and paste a block of cells into LO but the PC version doesn't allow this.
              SU Pro 2016
              PC Windows 10
              16gb RAM
              • pbacotP
                The print to pdf method displays whatever you want of the excel file.
                Would be nice to have the
                  samyell77
                  Print to PDF but its another file to have to store, update etc. Direct referencing of an excel file would be great!
                  SU Pro 2016
                  PC Windows 10
                  16gb RAM
                  • fouronethirtyF
                    fouronethirty
                    more zooom
                    cant edit small detail when you have big drafting project, wish nxt version of l.o has that. it would be awsome
                      samyell77
                      More zoom and better snapping in raster mode so dims can be added accurately without switching to vector as it slows the drawing down considerably.
                      SU Pro 2016
                      PC Windows 10
                      16gb RAM
                      • EdsonE
                        Edson
                        one feature I do wish LO had is the capability to export to dwg/dxf the same layer structure present in the reference SU file.
                        dwg/dxf files exported from LO are not of much use to the consultants architects keep sending files to all the time because the layers they contain are LO layers not the ones used to model the original SU file.
                        edson mahfuz, architect| porto alegre โ€ข brasil
                        http://www.mahfuz.arq.br
                        • utilerU
                          utiler
                          dwg/dxf files exported from LO are not of much use to the consultants architects keep sending files all the time because the layers they contain are LO layers not the ones used to model the original SU file.
                          I couldn't agree more, Edson!!!
                          Just Curious...
                            samyell77
                            Agreed again - layer structures in DWG/DXF exports would be great. Perhaps as a tick box option if you are happy to increase the size / complexity of the file?
                            SU Pro 2016
                            PC Windows 10
                            16gb RAM
                            • fouronethirtyF
                              fouronethirty
                              i bet their doing something about this layout wishes:)
                              i wud wait for that to come out, new layout, dat wud be very nice ,
                                seven.sides
                                More fully featured text editing tools allowing control over tab sizes.
                                Capability to make tables within layout.
                                Retain Excel cell border formatting on copy and paste to Layout.
                                  samyell77
                                  So when is the next release????? ๐Ÿ˜‰
                                  SU Pro 2016
                                  PC Windows 10
                                  16gb RAM
                                  • GaieusG
                                    Next time ๐Ÿ˜‰
                                      samyell77
                                      Damn - worth a try, thought I might catch you sleeping! ๐Ÿ˜„
                                      SU Pro 2016
                                      PC Windows 10
                                      16gb RAM
                                      • C
                                        Catalyst
                                        My Wishes are:
                                        Spell Check.
                                        Find and replace text string.
                                        • bmikeB
                                          bmike
                                          LO on a Mac catches spelling errors as you go. Pretty nice surprise coming from Vista.
                                          Overall spellcheck would be nice, but then I'd have lots of additions to my dictionary for construction abbreviations.
                                          I'd love it if it had 'editing' mode, or something similar to scene states, but applied globally.
                                          I want global control to put it into a fast vector based linework only mode so I can dimension and annotate, then switch it back to 'rendered' mode with line weights, sketchy edges, scenes, shadows, etc.
                                          • C
                                            caronte01
                                            This, from working a lot with layout lately:
                                            Find and replace text. (same as on any word processor)
                                            Make unique copy of a viewport (allow a copy of a viewport to link to an alternate version of the sketchup model)
                                            More options for the style tool (match properties). In addition to styles, match layers.
                                            An option to input measurements in different scales 1:1, 1:5, etc. Useful for drafting on top of ortho views.
                                            Components!!!!
                                            Improvements in snapping (object snapping and grid snapping do not always cooperate, layout will not snap to section cuts at times.)
                                            A fix for the bug where a view is slightly shifted horizontally,but it's snapping points remain on the original location
                                            A fix for vector pdf's becoming raster after updating some references. I can live with pdf, instead of linkable xls or doc files, as long as it works correctly.
                                            Improvements to dwg export (all the ones previously mentioned)
                                            Great tool, love working with it!!
                                            • 1 / 5
