    Layout wishlist
    Scheduled Pinned Locked Moved LayOut Feature Requests
    layout
    84 Posts 24 Posters 46.3k Views 24 Watching
    • fouronethirtyF
      fouronethirty
      can layout work on layer management, like on autocad, where you can hide the lineweights, ive noticed that layout starts slowing down when i start adding new lines and so on,
      • fouronethirtyF
        fouronethirty
        i wish layout adds a little more zooming in capabilities, and the layers managing system, if that happens, i,ll be very happy then
        • fouronethirtyF
          fouronethirty
          yes, i agree, hope layout make its improvement, its a great software though, but its a little bit of a slow mo when i start adding ines and changes,
            Show us an example of hiding line weights.
            • fouronethirtyF
              fouronethirty
              i dont have a sample of hiding lineweights., i was jst wishing layout wud be able to have a tools like that,
                Perhaps you could explain it more, then? I don't find any performance issues with LO when I add draw in lines of different weights.
                • fouronethirtyF
                  fouronethirty
                  well, you can find some if your working with lots of lines or large drafting works, i guess hiding lineweights would make LO works faster
                    I work with large LO files all the time. i've never had any slow down because of line weights.
                    • fouronethirtyF
                      fouronethirty
                      i see, maybe i have to work on it to fix it, i appreciate your time, tnx,
                        samyell77
                        Better compatibility with excel / spreadsheets / table. Its a very long winded process at the moment (export csv, copy to excel, reformat, copy to word, final format, insert to LO with varying results!)
                        SU Pro 2016
                        Dell Precision M4800
                        PC Windows 10
                        Intel Core i7-4900MQ @ 2.80ghz
                        Nvidia Quadro K2100M
                        16gb RAM
                          I agree about better text handling for data in tables although I do get dependable results going from CSV>Excel>Word>RTF>Insert into LO. It would be nice to be able skip some steps.
                          • pbacotP
                            Yes, more integration. They gave us something now we want more of the same! 🎉
                            Is a short cut Excel—> print pdf—> insert to LO? When you re-save the pdf LO can update. I guess you are getting some editable text your way? I used to concern myself with that in Excel to CAD but now find it better just to go back to Excel for changes.
                            I try to avoid Word where possible, but can't give up Excel yet (although it also drives me nuts at times). For drawing work I might try using Apple "Numbers".
                              Right clicking on the text box in LO brings up "Open in text Editor" which on my PC opens Word. I can then quite easily edit the text. the tables I use don't have a grid like the table has when copied from Excel into Word. I convert the table to tab separated text in Word.
                                samyell77
                                Thanks Dave R - this is what I do too but I need to display cells / spreadsheet borders and what ever way Ive tried seems problematic. Better compatibility with tables and spreadsheets would be great - it would save a lot of time reformatting for a lot of people and just cuts down on margin for error. The PDF method could work but the ideal would be to be able to link to an excel table or effectively display a table (with borders) in LO. The mac version allows you to copy and paste a block of cells into LO but the PC version doesn't allow this.
                                SU Pro 2016
                                PC Windows 10
                                16gb RAM
                                • pbacotP
                                  The print to pdf method displays whatever you want of the excel file.
                                  Would be nice to have the
                                    samyell77
                                    Print to PDF but its another file to have to store, update etc. Direct referencing of an excel file would be great!
                                    SU Pro 2016
                                    PC Windows 10
                                    16gb RAM
                                    • fouronethirtyF
                                      fouronethirty
                                      more zooom
                                      cant edit small detail when you have big drafting project, wish nxt version of l.o has that. it would be awsome
                                        samyell77
                                        More zoom and better snapping in raster mode so dims can be added accurately without switching to vector as it slows the drawing down considerably.
                                        SU Pro 2016
                                        PC Windows 10
                                        16gb RAM
                                        • EdsonE
                                          Edson
                                          one feature I do wish LO had is the capability to export to dwg/dxf the same layer structure present in the reference SU file.
                                          dwg/dxf files exported from LO are not of much use to the consultants architects keep sending files to all the time because the layers they contain are LO layers not the ones used to model the original SU file.
                                          http://www.mahfuz.arq.br
                                          • utilerU
                                            utiler
                                            dwg/dxf files exported from LO are not of much use to the consultants architects keep sending files all the time because the layers they contain are LO layers not the ones used to model the original SU file.
                                            I couldn't agree more, Edson!!!
                                            Just Curious...
                                            • 1 / 5
