    [Plugin] Simple Plugin Installer
    83 Posts 29 Posters 189.0k Views 29 Watching
      @guanjin said:
      @thomthom said:
      Hmm.... IE10 might not come until Windows8 is out... I hope it comes earlier - as I think Windows 8 comes late this year.
      Really good, but can not load the RB file, tried many, will not work!
      As Dave said, you need to be more spesific. How did you try to "load" the plugin? And what "doesn't work"? Unexpected behaviour? Errors? Menu items not found?
      • guanjinG
        guanjin
        RB can not import files??Thank you!
          Guanjin
          Read what it says about non-ASCII characters in file-paths...
          Ruby's 'File' tools [in Sketchup's v1.8~] can't accept UTF-8 characters... like in your Chinese!
          • guanjinG
            guanjin
            @tig said:
            Guanjin
            Most use UTF - 8 characters! ! πŸ˜’
            TIG welcomes you to China, I will entertain you
              Unfortunately this is a limitation due to the Ruby version SketchUp use. There is nothing we(plugin developers) can do. It needs to be addressed by Google
              • T
                tomasz
                It can be done through a C/C++ extension. I have it in mind to create such a 'library', but I am currently too busy to invest my time in it.
                SU2Thea can save/read files containing non-ASCII characters in their paths/filenames.
                  Ditto.
                  I tried to make Google add such helper methods.
                  It is only an issue under Windows though. So only a Windows C Extension is required. OSX works fine.
                  • N
                    newrui
                    Hello. Any chance for something for us mac users?
                      Version 1.0.2
                      • Fixed: Installed RB files are now loaded after installation - avoiding restart.
                        ? This plugin should be usable for OSX users... Are you getting errors?
                          Thomas, it works fine on Mac for me.
                            Thanks Dave. I'd be surprised if it didn't. Now we can only ponder what the question was related to...
                              Version 1.0.3
                              • Added: RBS support.
                              • guanjinG
                                guanjin
                                @thomthom said:
                                Version 1.0.3
                                Load error version SU8M2
                                  @guanjin said:
                                  @thomthom said:
                                  Version 1.0.3
                                  [attachment=0:2a3xs702]<!-- ia0 -->ζœͺ命名.jpg<!-- ia0 -->[/attachment:2a3xs702]
                                  That doesn't seem to be related to this plugin. It refer to a "window style.rb" plugin that tries to load "windows/api.rb".
                                    Probably the plugin by dukejazz.
                                    • guanjinG
                                      guanjin
                                      Thank you, problem solved! Windows plug-in is not clean, delete
                                      • I
                                        Iceonfire
                                        I keep getting the message windows cannot open this file. When I try to have it select from a list of programs, it takes me to a bunch of PC cleaner sites. Any further direction?
                                        • GaieusG
                                          Hi Katie,
                                          You do not need to open or run these rb files (but if you are interested, open them with notepad as they are simple text files).
                                          Simply copy the file into your plugins folder:
                                          C:\Program Files\Google\Google SketchUp 8\Plugins
                                          or
                                          C:\Program Files (x86)\Google\Google SketchUp 8\Plugins
                                          on a 64 bit Windows, restart SketchUp and you are done.
                                          Some more complex plugins consist of several files so they are usually distributed zipped in an archive. See this topic how to deal with them:
                                          http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
                                          Cheers and welcome!
                                            Changed the download to be a RBZ file only - and with screenshot description of how to install from within SketchUp.
                                            • 2 / 5
