    [Plugin] 2D Tools
    785 Posts 178 Posters 462.6k Views 177 Watching
    • O Offline
      osage
      I have the "Delete Guides" shortcut command set to "D" on my keyboard...takes a split sec to delete all of 'em when you're done
      😲 good grief. I guess I should spend more time exploring the default tools in Sketchup. Never saw that. 😳 AND setting up some shortcuts too.
      Thanks a mill!
      There are even specialist script-tools to erase cpoints
      Hmmmm, "cpoints". So that's what you call them huh. Cool. I searched for "tic" marks. Should have known they'd be called something related to Cartesian space ...or something to that effect. Ok, thanks for the info guys. I know all these solutions are probably in the thread, and I hate asking you to spend more of your time to explain something that you've already explained somewhere. So, I mucho appreciate it!
        In the 'early days' they were always called 'cpoints' and 'clines' [they still are in the API code!] but some Google genius a few versions ago decided to rename then 'guide-points' and 'guide-lines'... so watch for oldies/codies using the old names... πŸ˜‰
        • O Offline
          osage
          Ok, now I get it. And thanks for sharing your knowledge Tig.
          fitZ
          oh, btw, here's the reason I was looking for a solution. There were so many filets in this group all the cpoints were distracting. And this is only one of many sets of cables.
          http://httpics.com/is.php?i=1755&img=8874Studio_Wiring_D.jpg
          What's odd..is the cpoints disappear sometimes. Can't figure that one out either.
          And btw, I would never done this had it not been for your filet tool, and the "Line into Tube" plugin. They work great together. πŸ‘ Thanks again for the info. Every little bit helps.
          ooops. I completely forgot. Your 2d text works sublime. The only thing I was wondering is editing a copy of a 2d text. They act like components. If I change one..it changes the original. Can you "make unique" them somehow? That would be phenomenal. Then I could drag a copy along an axis..and edit it. Sure would save a bunch of time. Anyway, thanks a million for this one too!!
            You should be able to copy any 2dText Component Instance and then Select it and right-click context-menu > 'Make-Unique'... Thereafter it should '2dText Edit' as a separate thing...
            It can also be useful to have several Instances, because you can Edit one to affect all; it depends on what you want.
            The 'Entity Info' window will show the number of Instances of a Selected Component - useful in case you are unsure about its 'uniqueness'...
            • O Offline
              osage
              😲 OMG! I could have sworn I tried that. Ok cool, I'll check that out immediately!
              I LIKE IT!
              Dang I wish there was a "facepalm" smiley. πŸ’š (note to self: file under.. "more reasons to spend some time looking at default Sketchup tools) πŸ˜†
              Ok Tig, you made my day. No more questions for at least a week. πŸ˜„
              oh, btw
              er...isn't that an oxymoron? πŸ’š
              • EdsonE Offline
                Edson
                hi TIG,
                forgive me if this question has been asked before but the only problem I have with 2D Tools is the win/mac equivalence (or lack of it) between some keystrokes. to be more precise, what keys should i press on my mac to get the same result as when pressing control and alt in windows?
                best regards.
                http://www.mahfuz.arq.br
                  @edson said:
                  hi TIG,
                  best regards.
                  There IS a MAC compliant set of tools posted by Michaelv- http://forums.sketchucation.com/viewtopic.php?p=377902#p377902
                  It's NOT PC friendly... one day I will combine them both, but meanwhile his set is the best for you MAC users... It's currently identical to the PC version, BUT with different key-bindings...
                  • EdsonE Offline
                    Edson
                    @tig said:
                    @edson said:
                    hi TIG,
                    best regards.
                    tig,
                    many thanks to you for the tool and michaelv for the mac fix. it works beautifully now! 😍
                      I must around to merging them... one day πŸ˜’
                      • Y Offline
                        ygcl
                        THANKS TIG,DOWNLOAD IT.
                          jowers125
                          Great plugin! I am having trouble with the fillet tool though. Every time I click on the second line, it deletes the 2 lines and any objects connected to them. Can anybody help??
                            Every time ??? πŸ˜•
                            Can you try it with the Ruby Console open and report any errors.
                            What have you set the fillet radius to ?
                            Do the lines meet at a corner as an L or a T or have a gap?
                            Are the lines Coplanar?
                            Are the lines forming a Face?
                            etc
                            Without details it's difficult to say what's up.
                            Can you post a simple SKP where you are having this issue, and explain exactly the steps you take to get this disastrous result...
                            It works fine for me - see this rectangular 'donut' - the only extra step I needed to sort this were on the 'hole' - erasing the inner face that was made automatically as those corners were filleted...Capture.PNG
                            • O Offline
                              osage
                              I'm not sure, but it seems to me the first time I tried using the plugin, I didn't realize the "radius" input was defaulted to ZERO, and if memory serves me, my lines disappeared too. Might check it out.
                                With a zero radius the lines should trim or extend Γ  la ACAD...
                                Nothing should disappear [except the unwanted lines parts] !
                                • H Offline
                                  huckrorick
                                  Wow! This is really a great set of tools. Just now testing them out. I'm trying to think of some way to tell you how neat these are.
                                  Thanks. Congratulations.
                                  Huck
                                  • guanjinG Offline
                                    guanjin
                                    Hello!2D tool V5.1 is not continuous picture fill! You can not select another picture!
                                      When the 2dHatching tool is active right mouse-click in open space [away from any objects] and the dialog should pop-up to let you change the PATTern...
                                      • H Offline
                                        horst_horst_horst
                                        This is really great! thanx so much!
                                        • guanjinG Offline
                                          guanjin
                                          TIG Thank you, I see!
                                            Here's v5.2 http://forums.sketchucation.com/viewtopic.php?p=185760#p185760
                                            The 2dFillet tool has its segment range adjusted, >=2 <=999.
                                            • 19
                                            • 20
                                            • 21
                                            • 22
                                            • 23
                                            • 39
                                            • 40
                                            • 21 / 40
