    How to make a Solid Component from a Solid Group?
    20 Posts 5 Posters 1.6k Views 5 Watching
      tomot
      I have a Ruby (rb), what draws the Yellow ruby joists as Solid Components, which I can edit at once as demonstrated by the rebate, in the joist.
      The other Ruby (.rbs), draws the Red rafters as a Solid Group, I can't make any changes to the file since it is obfuscated.
      Question: How can I make the Red rafters into a Solid Component that allows me to change all the rafter tails? TIA!
      [my plugins](http://thingsvirtual.blogspot.ca/)
      tomot
        This plugin would allow you to convert all instances of the same group definition into instances of a component definition. (I believe).
        http://forums.sketchucation.com/viewtopic.php?t=14975
          tomot
          Thanks Gaieus, the definitive word is I believe πŸ˜„ http://forums.sketchucation.com/viewtopic.php?f=323&t=23307&start=15
          ..... what a mess!, I appreciate all the stuff ThomThom does for SU users, unfortunately trying to keep with all this updating can and does become a full time job, with each new release of SU, I really feel sorry for ThomThom and any Ruby programmers, I have found some of my own Rubies no longer perform as expected prior installing the latest and greatest versions of SU.
          Makes one wonder why all this constant upgrading is really worth it, in the long term, for the serious SU user?
          I cut and pasted my existing plugins folder to a new location, Since I always keep a copy of the original SU install Plugins folder on hand I pasted a copy to the same location, un-rared ThomThom files to the new Plugins menu. I don't see a new Toolbar in the Toolbar menu? 😞
          What else am I missing?
          tomot
            @tomot said:
            I believe πŸ˜„ viewtopic.php?f=323&t=23307&start=15
            That is TT_Lib version 1 - only used by Selection Toys. And by itself it does nothing.
            • EdsonE Offline
              Edson
              csaba,
              how does one go about converting groups into components with Selection Toys? I did not find any command (icon or menu item) to do that.
              edit: I have just found how to do it: first select the groups then right-click and select Group Copies>Convert into Components.
              http://www.mahfuz.arq.br
                This, of course, only works until you modify any f the group instances (and that group instance will be unique this way). Here it goes (it's in the right click / context menu of a selected group)
                  Some simple code will take ALL selected groups, make a component of the first selected group and replaces all the selected groups with instances of that component...EDIT:
                  CODE REMOVED AS NEW VERSION IN A LATER POST IS MORE EFFECTIVE...
                    tomot
                    TIG! I made an .rb file out of your code. Yes your script creates what I'm looking for, BUT, why do you erase the component group it just created? I want to leave all the rafters in place so I can edit one of the rafter tails which will influence the other 5. πŸŽ‰
                    RafterJoist.skp
                    tomot
                      OK.
                      I doesn't erase the rafters - as Entity Info shows there are 6 - all overlaid...
                      The issue is that the groups don't seem to be 'equivalent'.
                      Their 'insertion points' are different, so when they get made into a component the new instances become 'coincident'.
                      How are you making these groups initially ?
                      Is there a way of giving them a consistent 'origin' ?
                      The code I posted only works if all of the groups are 'equivalent'.
                      Of course in your case you can move the instances back into their correct locations, and then notching one will notch all...
                        Why not use the equivalent RafterTool ? http://rhin.crai.archi.fr/rld/plugin_details.php?id=319 it automatically makes components except for the last infill 'group'. It's easy enough to tweak the settings to make mono-pitched rafters... πŸ˜• [you made it!]
                        IF you really have to do this, in this way... then I COULD code something to give every selected rafter-group a consistent 'origin' and then make them into single component instances...
                        Let me know... πŸ˜•
                          tomot
                          That brings us full circle, back to my opening thread. The Rafters are created by an (.rbs) ruby, while the joists in yellow are created by JoistTool.rb
                          There is something else I have noted about this .rbs file, it appears to me that the author mirrored the rafters about a center hence those at the middle are not equally spaced, as shown in the pic and the .skp file.
                          tomot
                            tomot
                            I gather that ss=model.selection is not robust enough to able to register the co-ordinate location of each existing rafter, so that this information can be used again to reinstall the new component group to their original location?
                            tomot
                              tomot
                              πŸ˜•
                              I know that guy! its the other me. LOL! But actually the rafter tool from 10001bit are more practical for most complex roof framing, particularly when it comes to hip and valley framing, unfortunately this human need to preserve ones code gets in the way of going forward ......sigh!
                              tomot
                                It can... so I will code some convoluted transformation stuff for you tomorrow - it's late here right now... 😐
                                  (c) TIG 2012
                                  Permission to use, copy, modify, and distribute this software for
                                  any purpose and without fee is hereby granted, provided that the above
                                  copyright notice appear in all copies.
                                  THIS SOFTWARE IS PROVIDED "AS IS" AND WITHOUT ANY EXPRESS OR
                                  IMPLIED WARRANTIES, INCLUDING, WITHOUT LIMITATION, THE IMPLIED
                                  WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE.
                                  TIG-groups2components.rb
                                  Usage: Preselect the 'equivalent' groups to convert.
                                  Type [copy/paste] this into the Ruby Console
                                  TIG.groups2components
                                  This takes the selection of groups and turns them all into
                                  instances of one component that is made from the first group in the
                                  selection. The insertion points of the selected groups is rationalized
                                  so that groups that are effectively the same form [e.g. rafters made
                                  using 1001-tools] but with varying insertion points are accommodated.
                                  Only use it on groups that are either copies of the same group, or
                                  groups that are 'equivalent' in 'form' to each other, because it will
                                  affect all groups selected. Each group's layer and material is
                                  duplicated in the new instance that replaces it.
                                  It is one step undoable in case of disasters !
                                  Donations: Paypal.com = info @ revitrev . org
                                  Version: 1.0 20120208 First proper release.
                                  Place into the Plugins folder and restart Sketchup. Follow the Usage Notes...
                                    tomot
                                    Well done TIG! the components are indeed editable, except for one small problem, when using a hip roof the rafters are all the same length, the attached file explains further.
                                    Rafter.skp
                                    tomot
                                      You can't make a single simple component to serve as a series of different length hipped-rafter groups.
                                      The best you can hope for is to use symmetry and have pairs of mirrored components at opposite ends of the roof...
                                      You couldn't expect to make a component manually that would serve for all the hipped rafters, so how could a simple tool that converts groups to components do any better ?
                                      Also if you make a copy of a group and don't edit it then Sketchup can [incorrectly] have two instances of that group's definition. That seems what's happening there...
                                      Here's a version of the tool that makes every group unique before processing it...
                                      try it again and see what happens...
                                        tomot
                                        I understand the problem! which now takes on a whole new perspective. The solution for editing the rafter tails, of the entire perimeter of a roof the rafters, would appear to lie in producing a secondary set of coincident rafters that only serve as editable tails and that would not interfered with the original rafters at all.
                                        tomot
                                          How about somehow combining all of the rafter groups that share a common 'wall-plate' into a single group and exploding them inside this 'rafters-group'.
                                          You then [hopefully] have a 'solid' rafters-group.
                                          Then we make another solid group [copy] representing the 'wall-plate' and use the 'Solid' boolean tools to subtract the wall-plate from the rafters' ends, making the required notches in one go, and then we rework the rafters-group contents, so all-connected-geometry was once again made into individual grouped rafters [if that's whats needed] and then explode the temporary rafters-group at the end [if that's whats needed] πŸ˜•
                                          What's the workflow here ?
                                            tomot
                                            Actually your roof.rb is a good starting point for an editable rafter tails addition, where the editable rafter tail components only extend from the exterior building envelope to the width of the roof overhang. Is spring in the air yet?
                                            tomot
