    Joining arcs
    5 Posts 4 Posters 363 Views 4 Watching
      motoxy
      How can I join 2 arcs to make a continuous curvy line? I have seen about 'glue' but assume it is only on pro.
      Bruce
        Search for Weld on smustard.com
          As Rich said 'Weld' joins selected [connected] lines/curves/arcs into one bound 'curve'...
          It is an invaluable tool [works for all versions] !
          The 'Glue' ['Reglue'?] tools you suggest are to do with attaching component instances onto faces - like windows that might cut a hole in the faces that they are 'glued' to - there are several other scripts tools to do this [pretty-much for all version]...
          • gillesG
            gilles
            Have a look at this one too.
            http://forums.sketchucation.com/viewtopic.php?t=36822#p324196
              motoxy
              Thanks for all the advice. I will go off and investigate.
              Bruce
