    [Plugin] Layer Zero Fixup Tools
    12 Posts 9 Posters 12.6k Views 9 Watching
      dtrarch
      Hi slbaumgartner
      We the messy thank you
      Great idea πŸ‘ β˜€
      Cheers
      dtr
      • kenK Offline
        ken
        Well I could move this to the "DUH" thread. I did not realize that happen when I exploded a named group. It explains a lot of the mystery to me on how some primitive got to another layer besides "O".
        Thanks for the Plugin.
        Ken
        • Bob JamesB Offline
          Bob James
          That'a a "duh" for me too, Ken.
          Thanks for the tool, slbaumgartner, it'll get a lot of use.
            Thanks, good idea.
            Tip: you can avoid all of the 'Layer0' coding/tests by using
            ent.layer=nil
            which gives 'ent' the default-layer, irrespective of the default-layer's name or where it is in the model.layers list...
              Ben Ritter
              Thank you for sharing.
                slbaumgartner
                @tig said:
                Thanks, good idea.
                ent.layer=nil
                Absolutely right! I discovered that reading other threads here after I posted the original. The version here uses that fix.
                Steve
                tozero.rb
                • irwanwrI Offline
                  irwanwr
                  quite similar with the Default Layer Geometry main purpose then?
                    Matt666
                    I wrote a plugin some time ago that do the same thing, and you can choose entities you want to "normalize", and if the script has to analyze nested entities.
                    i post it here, if someone finds it useful.
                    πŸ˜‰
                    Matt_Normalize.zip
                    Frenglish at its best !
                    My scripts
                    • irwanwrI Offline
                      irwanwr
                      [attachment=0:x79lxjjg]<!-- ia0 -->Sans titre 1.jpg<!-- ia0 -->[/attachment:x79lxjjg]
                      πŸ˜‰
                      it looks like TT CleanUp
                      interesting. thank you πŸ‘
                      • JClementsJ Offline
                        JClements
                        Here are links to PutOnLayer
                        http://rhin.crai.archi.fr/rld/plugin_details.php?id=315
                        And PutOnCurrentLayer
                        http://rhin.crai.archi.fr/rld/plugin_details.php?id=312
                        Both were originated by Chris Grant.
                        I combined the two into one.
                        I use them religiously when importing components or cutting and pasting geometry from other models or when importing DWG files.
                          Bob James
                          Where ❓
