    πŸ«› Lightbeans Update | Metallic and Roughness auto-applied in SketchUp 2025+ Download
    [Plugin] Layer Zero Fixup Tools
    12 Posts 9 Posters 11.9k Views 9 Watching
      slbaumgartner
      The attached ruby adds two context menu items when you select a Group or ComponentInstance. These are intended as quick fixups for when you accidentally get Faces and Edges onto layers other than Layer0 and cause confusing visibility issues with the Groups and Components that use them. A prime culprit in creating this situation is the default explode command, which puts all the exploded parts onto the layer of the container, even if they were originally on Layer0. The first added context menu item, Explode to Layer0, modifies this behavior to put Faces and Edges onto Layer0. The second added context menu item, Primitives to Layer0, recursively descends through all nested contents of the selection and puts all Faces and Edges on Layer0 without exploding anything. This is the quick fixup when you can't remember what you did to create the mess.
      tozero.rb
        dtrarch
        Hi slbaumgartner
        We the messy thank you
        Great idea πŸ‘ β˜€
        Cheers
        dtr
        • kenK Offline
          ken
          Well I could move this to the "DUH" thread. I did not realize that happen when I exploded a named group. It explains a lot of the mystery to me on how some primitive got to another layer besides "O".
          Thanks for the Plugin.
          Ken
          • Bob JamesB Offline
            Bob James
            That'a a "duh" for me too, Ken.
            Thanks for the tool, slbaumgartner, it'll get a lot of use.
            • TIGT Online
              Thanks, good idea.
              Tip: you can avoid all of the 'Layer0' coding/tests by using
              ent.layer=nil
              which gives 'ent' the default-layer, irrespective of the default-layer's name or where it is in the model.layers list...
                Ben Ritter
                Thank you for sharing.
                  slbaumgartner
                  @tig said:
                  Thanks, good idea.
                  ent.layer=nil
                  Absolutely right! I discovered that reading other threads here after I posted the original. The version here uses that fix.
                  Steve
                  tozero.rb
                  • irwanwrI Offline
                    irwanwr
                    quite similar with the Default Layer Geometry main purpose then?
                      Matt666
                      I wrote a plugin some time ago that do the same thing, and you can choose entities you want to "normalize", and if the script has to analyze nested entities.
                      i post it here, if someone finds it useful.
                      πŸ˜‰
                      Matt_Normalize.zip
                      Frenglish at its best !
                      My scripts
                      • irwanwrI Offline
                        irwanwr
                        [attachment=0:x79lxjjg]<!-- ia0 -->Sans titre 1.jpg<!-- ia0 -->[/attachment:x79lxjjg]
                        πŸ˜‰
                        it looks like TT CleanUp
                        interesting. thank you πŸ‘
                        • JClementsJ Offline
                          JClements
                          Here are links to PutOnLayer
                          http://rhin.crai.archi.fr/rld/plugin_details.php?id=315
                          And PutOnCurrentLayer
                          http://rhin.crai.archi.fr/rld/plugin_details.php?id=312
                          Both were originated by Chris Grant.
                          I combined the two into one.
                          I use them religiously when importing components or cutting and pasting geometry from other models or when importing DWG files.
                            Bob James
                            Where ❓
