    [Plugin] Solid Inspector
    303 Posts 99 Posters 342.4k Views 98 Watching
    • V Offline
      VeniVidiVici
      OMG, THANK YOU THANK YOU THANK YOU!
      I cant wait to use this too...combined with Artisan...OMG...FINALLY, I can do 3D
      modeling without countless hours of error fixing (even when working large scale).
      This is going to save days of my life...lol. 😄
      CHEERS!
      <---swigs a brewski in your honor!
        PapaBear60
        OK, I'm having the same problem as another user, Solid Inspector doesn't show up in the menu. I'm using Sketchup 8 (7 is gone), put the .rb in the plugins folder and also the library2 folder in the plugins folder. (In fact, now that I look at it, several plugins don't show up?) What am I doing wrong:
          You ain't looking at the description of the plugin. 😉 Not all plugins add menus to the Plugins menu. Check the info in the first post for how to use.
            As TT said... not all scripts appear in the Plugins Menu - this one is set to load in the Tools Menu as explained on the tool's download page Capture.PNG that is UNLESS the " ThomThom's Plugins" menu is loaded by the script tt_0000_menu.rb - then that submenu is added in Plugins and TT's tools all collect there ! [but that's academic as you don't appear to have file that in Plugins folder, or the submenu it would make...]
            So look in the Tools Menu...
            If it's still not there come back to us...
              FWIW, you don't have the current cutlist plugin either.
                PapaBear60
                OK, that worked ... as did the Solid Inspector, when I first clicked on the tool then used the controls. My bad. Still learning this great product. This tool solves a big problem that I've encountered creating solids - and will save me hours of time spent recreating solids that aren't really solids.
                Thank you both.
                Dave
                  PapaBear60
                  OK, thanks for the heads-up on Cut List, but how could you tell from the picture I sent?
                    By the name. The current version would show as "cutlist.rb".
                    • E Offline
                      eraeya
                      Just wanted to say: this plugin is the biggest thing to happen since hotdogs. Hurray for workflow!
                        KJGC
                        Very, VERY impressive application! Thom you've made my work so much easier, and for that I am truly grateful. This "Error GPS" is remarkable, thank you so much for the amount of time and effort you've put into this plugin, in order of making everyone elses life T-H-A-T M-U-C-H easier. Merci mon amis !
                        Sincerely,
                        Kyle James
                            Now thatwas a proper "thank you". 😉
                            • I Offline
                              ik2012
                              Hi, kind of a sketchup newbie here. I am using this plugin to check my model for water tightness, but I am having trouble understanding the output. Would anyone mind looking at these screen shots and giving me some tips? Thanks!
                              bottle base top.skp
                                In order to build a solid object, there cannot be inner faces (amopng other conditions). You have some - and that's still not the only reason as deleting the face in the screenshot below still does not fix it.
                                (Note that I have reversed some faces and smoothed the group generally...)
                                As it turns out, it was all inner faces. Did not take too long to fix: when you have some time, send ThomThom a cookie.
                                bottle base top.skp
                                • voljankoV Offline
                                  voljanko
                                  There are also some ungrouped lines that can prevent your model to be solid.That means that they are outside the group or inside the group with the solid subgroup.In your case they are outside the group.See picture.
                                  SuSolid.com - solid check - solid repair- solid intersection check - weight plugin
                                  • I Offline
                                    ik2012
                                    Thanks so much Gaieus and voljanko! Also a big thanks to thomthom for the awesome plugin!
                                      Hi jean-françois and welcome!
                                      The file is a simple ruby plugin (a text file) that you have to copy into this folder:
                                      C:\Program Files\Google\Google SketchUp 8\Plugins
                                      Also, there is a plugin library you will need (linked from the first post, above the attached plugin). It is a zipped library of several files. Unzip the archive onto your desktop, go into the folder that is created there and copy everything as you see there into the same plugin directory as above.
                                      Restart SU and find the plugin under the Tools menu.
                                        @jean-françois said:
                                        I would like to install the solid inspector plugin on my computer.
                                        Can you explain me how to do it?
                                        Thanks in advance
                                        I've written a tutorial on how to install plugins: http://www.thomthom.net/thoughts/2012/01/installing-plugins-for-google-sketchup/
                                        Even includes link to an installer utility that will make it easier to install them.
                                          jean-françois
                                          Subject: [Plugin] Solid Inspector (1.1.0) — 30 June 2011
                                          Thanks in advance
                                          Hi Guys, thanks for your answers. I am still facing some problems.
                                          I copied and unzip the file TT_lib2 into the folder "c/...sketchup8/plugins"
                                          I also copied the file TT_solid_inspector.rb in the same folder.
                                          I closed and restared SU but I get a window with "load error messages" everytime I open SU.
                                          Moreover, when I click on the tools Bar, I see "solid tools (pro only)->" but I can't click on it.
                                          I do not use SU pro, is it the reason of the problem?
                                          Thanks in advance
                                          Jean-François
                                            archzag
                                            Geniale!
                                            • 15
                                            • 16
                                            • 5 / 16
