Zen garden
Hey guys,
i want to build a zen garden but i dont know how to draw the lines on the ground! Please help me!
Thank you
Best regards
lamandrion -
Probably the best way would be to use a texture instead of using geometry to create that pattern.
I guess it also depends on if it's to be rendered or straight SU output.
If you need it 3d in SU maybe you can also try this plugin. You need a well contrasted zenithal image or you can draw it by yourself in an image editor and then save it as BMP as I did in the very quick and rough example below. Be careful use a low resolution bitmap and also the generated model will be a bit high poly.
Thank you all! You really helped me!
@ massimo
Great plugin! i should be able to work with it!
Thank you very very much!
You're welcome and post your results.
