    Zen garden
    6 Posts 4 Posters 1.1k Views 4 Watching
      lamandrion
      Hey guys,
      i want to build a zen garden but i dont know how to draw the lines on the ground! Please help me!
      http://fusionclothing.files.wordpress.com/2011/01/zengarden.jpg
      Thank you
      Best regards
      lamandrion
        Probably the best way would be to use a texture instead of using geometry to create that pattern.
        • soloS Offline
          I guess it also depends on if it's to be rendered or straight SU output.
          • massimoM Offline
            massimo Moderator
            If you need it 3d in SU maybe you can also try this plugin. You need a well contrasted zenithal image or you can draw it by yourself in an image editor and then save it as BMP as I did in the very quick and rough example below. Be careful use a low resolution bitmap and also the generated model will be a bit high poly.
              lamandrion
              Thank you all! You really helped me!
              @ massimo
              Great plugin! i should be able to work with it!
              Thank you very very much!
              • massimoM Offline
                massimo Moderator
                You're welcome and post your results. πŸ˜‰
