    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 306.8k Views 123 Watching
    • mitcorbM
      mitcorb
      A few posts up I had this reply:
      Back in Sketchup Version6, this plugin has a presence in Tools. Also, right click context menu will reveal the tools in the flyout. It may be similar in version 8.
      Maybe this does not apply. Just trying to help.
      The responsiveness of the author leaves a bit to be desired.
        Schorhr
        Thanks 😄 But as I wrote, it's neither in the menu nor right-clicking the groups does show the plugin...
        Is there perhaps a version older then 8.0.4811 that's known to work?
        I am using XP Home 32 Bit SP 3,
          Jakob Hovman
          You have to: View/Toolbars/ and select OSCoolean
          It works when "things" are: make group, not make components.
          Jakob.
          • H
            HuglyPolo
            Hi everybody.
            I got some problem when trying to use these very interesting plug in : after choosing one of the buttons, nothing more happens, no more pointer, impossible to select the solids ... and I get this error message from the Ruby console :
            Error: #<NoMethodError: protected method `onMouseMove' called for #<OSCoolean:0xdfe87e0 @coolean="T">>
            (eval):1298
            What made I wrong or forgot to install ??
            Thank's for any help.
            Paul
            • P
              penumbradesign
              I'd love to try this plugin ( iam still on v 7.1) but it does not appear wise to install this as it might not work on ver 7?
                Seems it's writed for SU 8 no ? 😉
                  sattapong
                  good thank
                    AcesHigh
                    @Oscarlok:
                    can you make OSCoolean work with faces/meshes? Like subtract a cube from a mesh/face?
                    • irwanwrI
                      irwanwr
                      is this plugin has been updated recently? does it still work with the recent SU 8? not the M2 one.
                        donz
                        I did download this Plugin today, and tried to put it in the PLUGIN folder, but nothing happening after i restart my SketchIp. Im working on SU 8 PRO
                        • falkF
                          falk
                          Hi: just wanted to say this is a great plugin. I'm going to use it a lot.
                          Donz, if you have SU8 Pro, do you even need this plugin?
                            I believe not 😉
                              J-pags
                              I figured it out. OSCoolean does not work when sketchyphysics is enabled. At least on my computer. I disabled it, and now it's working fine.
                              • U
                                unisev
                                Not working for me :
                                Error; #<NoMethodError; undefined method `best_picked' for nil;NilClass>
                                (eval);98;in `set_current_point'
                                (eval);73;in `onLButtonUp'
                                (eval);98
                                My U version (non-Pro) :
                                8.0.11752
                                I'm using XP "up-to-date" as it can be 😕
                                Sev
                                • X
                                  xudaweibest
                                  thank you very much
                                  • sicksickisckS
                                    sicksickisck
                                    not work at all 😒
                                      @sicksickisck said:
                                      not work at all 😒
                                      No explanation at all to what "doesn't work"... 😒
                                        @thomthom said:
                                        @sicksickisck said:
                                        not work at all 😒
                                        Looks like the poster is just making a statement but not asking for help. I guess they don't want any assistance. 😒
                                        • robertWanR
                                          robertWan
                                          SketchyPhysics must be disabled.
                                          Robert
                                            antonnazarov2
                                            I've got non trivial combination of 2 groups:
                                            http://farm8.staticflickr.com/7110/6915362206_676330870d.jpg
                                            When I'm trying to intersect them, I can see the console output (see below).
                                            It looks like sort a NullPointer exception.
                                            I use SketchUp 8 and latest version of the OSCoolean script. I noticed that the script is delivered in binary form. if author of that script is busy with something else, could it be possible to get that script as Ruby- source? I'm pretty sure that I could find the bug and fix it.
                                            regards,
                                            Anton
                                            WARNING; make_unique is a deprecated methodof Sketchup;Group
                                            Error; #<NoMethodError; undefined method `name=' for nil;NilClass>
                                            (eval);311;in `Intersect_outer'
                                            (eval);491;in `Split'
                                            (eval);120;in `set_current_point'
                                            (eval);311
                                            • 15
                                            • 16
                                            • 6 / 16
