    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 306.8k Views 123 Watching
    • liquid98L
      liquid98
      This is great work Thanks so much, nice tool-icons too.
      Things that flourish fall into decay. This is not-Tao, And what is not-Tao soon ends ~ Lao tse
        Michaelv
        Great plugin thanks.
        Could you please include a line with UI::Toolbar.restore (check and match syntax), so it keeps the status of the toolbar (displayed or not), thanks. I'd do it but since you plug in is rbs I can't.
        SU8 OS 10.5.8
        • P
          pankaj_tamore
          Hi oscarlok!
          thank u for developing such great plugin may we all see some more interesting plugins from you in near future keep it up dude take care bi
            alexdobras
            i have installed the plugin, and when i click on union or any other button, SU8 simply does't work anymore well, i cannot even select the solids anymore with left click , only with right click.
            and Coolean didn't complete his job either 😐
            does it work for you in SU8 ?
            • T
              trailmax
              Hi- I'm a relative newbie to Sketchup...but I have had experience with Booleans in Form Z. I'm on a Mac using SU 8 and cannot seem to get this plug in working. I have the entire contents of the unzipped file in the plugin folder (and restarted). I don't see an OSCoolean toolbar to enable in the menus, nor do I see anything in the contextual menus. Does anyone know if this awesome sounding tool is working for SU 8 on the Mac? Is there something else I need to install as well? Thanks
              • mitcorbM
                mitcorb
                Back in Sketchup Version6, this plugin has a presence in Tools. Also, right click context menu will reveal the tools in the flyout. It may be similar in version 8.
                I have pretty much abandoned this plugin for a perceived lack of response. But, what should I expect for free?
                  all that is very curious because it works fine in SU8 free with Pc ☀
                    Schorhr
                    Hello,
                    the plugin does not appear in tools nor in the rightclick menu ❓
                    As I frequently install plugins and use them regulary- without problems.
                    I do not know what could possibly cause this problem. Help! 😎
                    To make sure it's no conflict with an installed plugin, I just installed a "clean" Sketchup 8.0.4811 (most recent version). Still, I can not get it to work.
                    • mitcorbM
                      mitcorb
                      A few posts up I had this reply:
                      Maybe this does not apply. Just trying to help.
                      The responsiveness of the author leaves a bit to be desired.
                        Schorhr
                        Thanks 😄 But as I wrote, it's neither in the menu nor right-clicking the groups does show the plugin...
                        Is there perhaps a version older then 8.0.4811 that's known to work?
                        I am using XP Home 32 Bit SP 3,
                          Jakob Hovman
                          You have to: View/Toolbars/ and select OSCoolean
                          It works when "things" are: make group, not make components.
                          Jakob.
                          • H
                            HuglyPolo
                            Hi everybody.
                            I got some problem when trying to use these very interesting plug in : after choosing one of the buttons, nothing more happens, no more pointer, impossible to select the solids ... and I get this error message from the Ruby console :
                            Error: #<NoMethodError: protected method `onMouseMove' called for #<OSCoolean:0xdfe87e0 @coolean="T">>
                            (eval):1298
                            What made I wrong or forgot to install ??
                            Thank's for any help.
                            Paul
                            • P
                              penumbradesign
                              I'd love to try this plugin ( iam still on v 7.1) but it does not appear wise to install this as it might not work on ver 7?
                                Seems it's writed for SU 8 no ? 😉
                                  sattapong
                                  good thank
                                    AcesHigh
                                    @Oscarlok:
                                    can you make OSCoolean work with faces/meshes? Like subtract a cube from a mesh/face?
                                    • irwanwrI
                                      irwanwr
                                      is this plugin has been updated recently? does it still work with the recent SU 8? not the M2 one.
                                        donz
                                        I did download this Plugin today, and tried to put it in the PLUGIN folder, but nothing happening after i restart my SketchIp. Im working on SU 8 PRO
                                        • falkF
                                          falk
                                          Hi: just wanted to say this is a great plugin. I'm going to use it a lot.
                                          Donz, if you have SU8 Pro, do you even need this plugin?
                                            I believe not 😉
                                            • 15
                                            • 16
                                            • 6 / 16
