    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 306.8k Views 123 Watching
    • H
      HuglyPolo
      Hi everybody.
      I got some problem when trying to use these very interesting plug in : after choosing one of the buttons, nothing more happens, no more pointer, impossible to select the solids ... and I get this error message from the Ruby console :
      Error: #<NoMethodError: protected method `onMouseMove' called for #<OSCoolean:0xdfe87e0 @coolean="T">>
      (eval):1298
      What made I wrong or forgot to install ??
      Thank's for any help.
      Paul
      • P
        penumbradesign
        I'd love to try this plugin ( iam still on v 7.1) but it does not appear wise to install this as it might not work on ver 7?
          Seems it's writed for SU 8 no ? 😉
            sattapong
            good thank
              AcesHigh
              @Oscarlok:
              can you make OSCoolean work with faces/meshes? Like subtract a cube from a mesh/face?
              • irwanwrI
                irwanwr
                is this plugin has been updated recently? does it still work with the recent SU 8? not the M2 one.
                  donz
                  I did download this Plugin today, and tried to put it in the PLUGIN folder, but nothing happening after i restart my SketchIp. Im working on SU 8 PRO
                  • falkF
                    falk
                    Hi: just wanted to say this is a great plugin. I'm going to use it a lot.
                    Donz, if you have SU8 Pro, do you even need this plugin?
                      I believe not 😉
                        J-pags
                        I figured it out. OSCoolean does not work when sketchyphysics is enabled. At least on my computer. I disabled it, and now it's working fine.
                        • U
                          unisev
                          Not working for me :
                          Error; #<NoMethodError; undefined method `best_picked' for nil;NilClass>
                          (eval);98;in `set_current_point'
                          (eval);73;in `onLButtonUp'
                          (eval);98
                          My U version (non-Pro) :
                          8.0.11752
                          I'm using XP "up-to-date" as it can be 😕
                          Sev
                          • X
                            xudaweibest
                            thank you very much
                            • sicksickisckS
                              sicksickisck
                              not work at all 😒
                                @sicksickisck said:
                                not work at all 😒
                                No explanation at all to what "doesn't work"... 😒
                                  @thomthom said:
                                  @sicksickisck said:
                                  not work at all 😒
                                  Looks like the poster is just making a statement but not asking for help. I guess they don't want any assistance. 😒
                                  • robertWanR
                                    robertWan
                                    SketchyPhysics must be disabled.
                                    Robert
                                      antonnazarov2
                                      I've got non trivial combination of 2 groups:
                                      http://farm8.staticflickr.com/7110/6915362206_676330870d.jpg
                                      When I'm trying to intersect them, I can see the console output (see below).
                                      It looks like sort a NullPointer exception.
                                      I use SketchUp 8 and latest version of the OSCoolean script. I noticed that the script is delivered in binary form. if author of that script is busy with something else, could it be possible to get that script as Ruby- source? I'm pretty sure that I could find the bug and fix it.
                                      regards,
                                      Anton
                                      WARNING; make_unique is a deprecated methodof Sketchup;Group
                                      Error; #<NoMethodError; undefined method `name=' for nil;NilClass>
                                      (eval);311;in `Intersect_outer'
                                      (eval);491;in `Split'
                                      (eval);120;in `set_current_point'
                                      (eval);311
                                        ramdelgp
                                        very nice plugin thank you very much. but it dosent work for me and my skp7 :S
                                          @ramdelgp said:
                                          Sorry but it dosent work at all for me in sk7 pro :S
                                          As the title says - it's for SU8.
                                            ramdelgp
                                            Any tips for what i can do?
                                            • 15
                                            • 16
                                            • 6 / 16
