    [Plugin] Boolean--OSCoolean (Dec 2013) for SU 8 up free ver
    301 Posts 123 Posters 306.8k Views 123 Watching
      Schorhr
      Hello,
      the plugin does not appear in tools nor in the rightclick menu ❓
      As I frequently install plugins and use them regulary- without problems.
      I do not know what could possibly cause this problem. Help! 😎
      To make sure it's no conflict with an installed plugin, I just installed a "clean" Sketchup 8.0.4811 (most recent version). Still, I can not get it to work.
      • mitcorbM
        mitcorb
        A few posts up I had this reply:
        Back in Sketchup Version6, this plugin has a presence in Tools. Also, right click context menu will reveal the tools in the flyout. It may be similar in version 8.
        Maybe this does not apply. Just trying to help.
        The responsiveness of the author leaves a bit to be desired.
          Schorhr
          Thanks 😄 But as I wrote, it's neither in the menu nor right-clicking the groups does show the plugin...
          Is there perhaps a version older then 8.0.4811 that's known to work?
          I am using XP Home 32 Bit SP 3,
            Jakob Hovman
            You have to: View/Toolbars/ and select OSCoolean
            It works when "things" are: make group, not make components.
            Jakob.
            • H
              HuglyPolo
              Hi everybody.
              I got some problem when trying to use these very interesting plug in : after choosing one of the buttons, nothing more happens, no more pointer, impossible to select the solids ... and I get this error message from the Ruby console :
              Error: #<NoMethodError: protected method `onMouseMove' called for #<OSCoolean:0xdfe87e0 @coolean="T">>
              (eval):1298
              What made I wrong or forgot to install ??
              Thank's for any help.
              Paul
              • P
                penumbradesign
                I'd love to try this plugin ( iam still on v 7.1) but it does not appear wise to install this as it might not work on ver 7?
                  Seems it's writed for SU 8 no ? 😉
                    sattapong
                    good thank
                      AcesHigh
                      @Oscarlok:
                      can you make OSCoolean work with faces/meshes? Like subtract a cube from a mesh/face?
                      • irwanwrI
                        irwanwr
                        is this plugin has been updated recently? does it still work with the recent SU 8? not the M2 one.
                          donz
                          I did download this Plugin today, and tried to put it in the PLUGIN folder, but nothing happening after i restart my SketchIp. Im working on SU 8 PRO
                          • falkF
                            falk
                            Hi: just wanted to say this is a great plugin. I'm going to use it a lot.
                            Donz, if you have SU8 Pro, do you even need this plugin?
                              I believe not 😉
                                J-pags
                                I figured it out. OSCoolean does not work when sketchyphysics is enabled. At least on my computer. I disabled it, and now it's working fine.
                                • U
                                  unisev
                                  Not working for me :
                                  Error; #<NoMethodError; undefined method `best_picked' for nil;NilClass>
                                  (eval);98;in `set_current_point'
                                  (eval);73;in `onLButtonUp'
                                  (eval);98
                                  My U version (non-Pro) :
                                  8.0.11752
                                  I'm using XP "up-to-date" as it can be 😕
                                  Sev
                                  • X
                                    xudaweibest
                                    thank you very much
                                    • sicksickisckS
                                      sicksickisck
                                      not work at all 😒
                                        @sicksickisck said:
                                        not work at all 😒
                                        No explanation at all to what "doesn't work"... 😒
                                          @thomthom said:
                                          @sicksickisck said:
                                          not work at all 😒
                                          Looks like the poster is just making a statement but not asking for help. I guess they don't want any assistance. 😒
                                          • robertWanR
                                            robertWan
                                            SketchyPhysics must be disabled.
                                            Robert
                                            • 15
                                            • 16
                                            • 6 / 16
