๐Ÿค‘ SketchPlus 1.3 | 44 Tools for $15 until June 20th Buy Now
Holes in engineering drawing
7 Posts 4 Posters 224 Views 4 Watching
    cotty
    Is there a way to show holes in a geometry (a) like shown in (e)? this illustration would be helpful for engineering drawings...
    I tried these ways but they didn't lead to the desired illustration:
    (b) show back edges
    (c) back edges and hidden lines
    (d) x-ray mode
    Thank you for helpful hints!
    hole illustration
    my SketchUp gallery
      I think (C) is about as good as you'll get.
      You could perhaps set it up in Layout, using overlaid scenes of the same view ,with different Styles etc BUT no easy way ๐Ÿ˜•
        gilles
        #1 hidden geometry on
        #2 select this two edges
        #3 in entity info, uncheck soften and smoothed
        #4 back edges on
        Does the job only for one point of view.
          cotty
          Another way ist to unsmooth some of the hole lines (see picture), but this only works for one of the standard views naturally...
          EDIT: OK, some minutes to late ๐Ÿ˜‰
          my SketchUp gallery
            cotty
            Is this a task which can be solved by a ruby-plugin?
            loop through all geometry
            for all circles
            copy (viewdependent) the two hole lines which are furthermost
            paste on a new layer
            (...arcs?)
            my SketchUp gallery
            • O Offline
              oganocali
              Actually you can get it almost right in all views if you do
              view
              edges
              back edges
              profiles
              set the transparency of the material around 70 %
              set the profile width from styles to 1
              Ogan
                cotty
                view
                edges
                back edges
                profiles
                With your technique and the face style "Hidden Line" the illustration is getting better (the vertical hole lines are not dashed...)
                my SketchUp gallery
