    Holes in engineering drawing
    7 Posts 4 Posters 289 Views 4 Watching
    • cottyC Offline
      cotty
      Is there a way to show holes in a geometry (a) like shown in (e)? this illustration would be helpful for engineering drawings...
      I tried these ways but they didn't lead to the desired illustration:
      (b) show back edges
      (c) back edges and hidden lines
      (d) x-ray mode
      Thank you for helpful hints!
      hole illustration
      my SketchUp gallery
        I think (C) is about as good as you'll get.
        You could perhaps set it up in Layout, using overlaid scenes of the same view ,with different Styles etc BUT no easy way πŸ˜•
        • gillesG Offline
          gilles
          #1 hidden geometry on
          #2 select this two edges
          #3 in entity info, uncheck soften and smoothed
          #4 back edges on
          Does the job only for one point of view.
          • cottyC Offline
            cotty
            Another way ist to unsmooth some of the hole lines (see picture), but this only works for one of the standard views naturally...
            EDIT: OK, some minutes to late πŸ˜‰
            my SketchUp gallery
            • cottyC Offline
              cotty
              Is this a task which can be solved by a ruby-plugin?
              loop through all geometry
              for all circles
              copy (viewdependent) the two hole lines which are furthermost
              paste on a new layer
              (...arcs?)
              my SketchUp gallery
              • oganocaliO Offline
                oganocali
                Actually you can get it almost right in all views if you do
                view
                edges
                back edges
                profiles
                set the transparency of the material around 70 %
                set the profile width from styles to 1
                Ogan
                • cottyC Offline
                  cotty
                  view
                  edges
                  back edges
                  profiles
                  With your technique and the face style "Hidden Line" the illustration is getting better (the vertical hole lines are not dashed...)
                  my SketchUp gallery
