    Mysterious Bug [followme related]
    30 Posts 4 Posters 2.7k Views 4 Watching
      I tried the code you posted initially. I get no crash. I did however leave out LineA.create_line so that it would not execute when SU loaded.
      I called the method afterwards in SU.
      Sidenote - it seems that you create the profile for your shape (the circle) many times. Many small segments for what is in reality one single tube. As you can see- you end up with gaps where the straight sides meets the arced corners.
      You would avoid that by making the tube as you would in SU. Making one single path, and one profile - then using follow me only once for the whole shape.
      Should make a cleaner geometry, be faster and simplify the code.
        Oh yea - as Dan suggested with his code. several operations should be wrapped in .start_operation - .commit_operation so it produces only one undo step. And if you use the disable_ui argument it should run faster.
        • Dan RathbunD
          Dan Rathbun
          Yea, it's dangerous to do stuff during SU load, as all the Google extensions are not yet loaded like Dynamic Components.
          I'm not here much anymore.
          • Dan RathbunD
            Dan Rathbun
            maybe a wait timer like this is safer...
              # run when file loads
              if Sketchup.active_model &&
              Sketchup.active_model.active_entities
                UI.start_timer(0.0, false){ LineA.create_line }
              else
                LineA;;TIMER = UI.start_timer(2.0, true){
                    UI.stop_timer(LineA;;TIMER)
                    LineA.create_line
                  end #if
            • C
              Chris88
              @Dan: Thank you. Now my code looks like:
              require 'sketchup.rb'
              module Chris88
                module LineA
                  TIMER = nil
                  def self.create_line()
                    # delete lines 1-4 with loop
                     model = Sketchup.active_model
                     entities = model.active_entities
                     # Add the group to the entities in the model
                     group = entities.add_group
                     # Get the entities within the group
                     # alle Objekte die den entities2 zugeordnet werden, werden automatisch zu einer gemeinsamen Gruppe gemacht
                     entities2 = group.entities
                    begin
                      model.start_operation( 'LineA' )
                      @width_small = 55 # 55
                      @depth_small = 45 # 45
                      @height_small = 30 # 30
                      @width_big = 70 # 70
                      @depth_big = 60 # 60
                      @height_big = 70 # 40
                      @height_line = (4/3) * @height_small
                      @radius = 1
                      @arcradius = 3
                      @mat_linie=model.materials.add("Material_Linie")
                      @mat_linie.color=Sketchup;;Color.new(124,252,0)  # => LawnGreen
                      @anzahl_arcs = ((@depth_small-6)/6).to_i
                      @pts =[]
                      @helpvar_depth = 3
                      @helpvar_pts = 1
                      @helpvar_baseline = 1
                      @helpvar_basearc = 1
                     1.upto(@anzahl_arcs) do |x|
                      @helpvar2_pts = @helpvar_pts +1
                     if (x%2 > 0)
                      @pts[@helpvar_pts] = [((@width_big-@width_small)/2)+5.35, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
                      @pts[@helpvar_pts+1] = [@width_small+((@width_big-@width_small)/2)-5.3, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
                      # arc_point
                      @pts[@helpvar_pts+2] = [@width_small+((@width_big-@width_small)/2)-5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+3), @height_line]
                      arc_circle_odd = entities2.add_circle @pts[@helpvar_pts+1], X_AXIS, @radius, 42
                      arc_circle_face_odd = entities2.add_face arc_circle_odd
                      arc_circle_face_odd.material = @mat_linie
                      arc_circle_face_odd.back_material = @mat_linie
                      line_circle_odd = entities2.add_circle @pts[@helpvar_pts], X_AXIS, @radius, 42
                      line_circle_face_odd = entities2.add_face line_circle_odd
                      line_circle_face_odd.material = @mat_linie
                      line_circle_face_odd.back_material = @mat_linie
                      @helpvar_baseline_odd = entities2.add_line @pts[@helpvar_pts], @pts[@helpvar_pts+1]
                      @helpvar_basearc_odd = entities2.add_arc @pts[@helpvar_pts+2],[0,-1,0],[0,0,1],@arcradius,-5.degrees,185.degrees
                      arc_circle_face_odd.followme @helpvar_basearc_odd
                      line_circle_face_odd.followme @helpvar_baseline_odd
                    elsif (x%2 == 0)
                      @pts[@helpvar2_pts-1] = [((@width_big-@width_small)/2)+5.3, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
                      @pts[@helpvar2_pts] = [@width_small+((@width_big-@width_small)/2)-5.35, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
                      # arc_point
                      @pts[@helpvar2_pts+1] = [((@width_big-@width_small)/2)+5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+3), @height_line]
                      arc_circle_even = entities2.add_circle @pts[@helpvar2_pts-1], X_AXIS, @radius, 42
                      arc_circle_face_even = entities2.add_face arc_circle_even
                      arc_circle_face_even.material = @mat_linie
                      arc_circle_face_even.back_material = @mat_linie
                      line_circle_even = entities2.add_circle @pts[@helpvar2_pts], X_AXIS, @radius, 42
                      line_circle_face_even = entities2.add_face line_circle_even
                      line_circle_face_even.material = @mat_linie
                      line_circle_face_even.back_material = @mat_linie
                      @helpvar_baseline_even = entities2.add_line @pts[@helpvar2_pts], @pts[@helpvar2_pts-1]
                      @helpvar_basearc_even = entities2.add_arc @pts[@helpvar2_pts+1],[0,1,0],[0,0,1],@arcradius,-5.degrees,185.degrees
                      arc_circle_face_even.followme @helpvar_basearc_even
                      line_circle_face_even.followme @helpvar_baseline_even
                    end # if
                    if (x == @anzahl_arcs)
                      @pts[@helpvar_pts] = [((@width_big-@width_small)/2)+5.35, ((@depth_big-@depth_small)/2)+(@helpvar_depth+6), @height_line]
                      @pts[@helpvar_pts+1] = [@width_small+((@width_big-@width_small)/2)-5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+6), @height_line]
                      @helpvar_baseline_ende = entities2.add_line @pts[@helpvar_pts], @pts[@helpvar_pts+1]
                      line_circle_face_odd.followme @helpvar_baseline_ende
                    end # if
                    @helpvar_depth = @helpvar_depth + 6
                    @helpvar_pts = @helpvar_pts + 3
                  end # upto - do
                    rescue => e
                      model.abort_operation
                      puts("#{Module.nesting[0].name} Error #<#{e.class.name}; #{e.message}>")
                      puts(e.backtrace)
                    else
                      model.commit_operation
                  end # def
                end # module LineA
                  LineA.create_line
                else
                      LineA.create_line
                    end #if
              end # module Chris88
              Is this what do you mean?
              However it doesn't solve the bug.
              @thomthom: Thanks, that could help me. I know this, what you wrote in your sidenode, but it didn't work: When i draw a circle and a path, which starts at the central point of the cricle, Sketchup draw only the lines, but not the curves. This is why i decided alternatively to draw the lines and the curves seperately. Do you think the gaps could be the reason for the bug?
              • C
                Chris88
                Dan, i have to correct myself: It works, when i load the script from the Ruby Console = step forward! πŸ˜„ [Edit:] i just noticed, this is what thomthom meant. 😒 [/Edit]
                But it doesn't work yet, when i want to load the script from the plugin-folder by starting SU normally and the script is located in the plugin-folder.
                  Don't think so. Just a sidenote. It is possible to create that shape in one operation.
                  • Dan RathbunD
                    Dan Rathbun
                    Alright replace the load loop with this ...
                      prevdir = Dir.getwd
                      Dir.chdir Sketchup.find_support_file("Tools")
                      tools = Dir["*.rb"]
                      Dir.chdir(prevdir)
                      if ( tools & $LOADED_FEATURES == tools ) &&
                        UI.start_timer(2.0, false){ LineA.create_line }
                      else
                        timer_LineA = UI.start_timer(2.0, true){
                            UI.stop_timer(timer_LineA)
                            LineA.create_line
                          end #if
                      tools = nil
                    • Dan RathbunD
                      Dan Rathbun
                      And here's a version that makes sure the Tool Stack is ready ...
                        prevdir = Dir.getwd
                        tools = Dir["*.rb"]
                        Dir.chdir(prevdir)
                        Sketchup.active_model.active_entities &&
                        Sketchup.active_model.tools.active_tool_id != 0
                        else
                              LineA.create_line
                            end #if
                        tools = nil
                        Let's step back to the very beginning...
                        Do you need this script to run automatically EVERY time EVERY SKP opens?
                        A. Yes.
                        Why for goodness sake ???
                        A. No.
                        Then what's the problem?
                        If it runs from a menu/toolbar then everything will be loaded by the time you think about using it anyway. Just do NOT include the code that runs it as it loads and everything is cushty!
                        πŸ˜•
                        • Dan RathbunD
                          Dan Rathbun
                          Because he's generating ruby scripts (that build geometry,) from a C# program, which reads XML data.
                          A batch mode use of Sketchup.
                          He's not that good with Ruby, or else he could use Ruby's XML libraries directly.
                          And I do have an API request in for an AppObserver "onReadyState" callback method.
                            Well, I tried the snippet - installed in my Plugins folder - now executing the command. It splatted. But wrapping the command in a timer that delay the operation with two seconds - no splat.
                            • Dan RathbunD
                              Dan Rathbun
                              The processing of the Tools dir must complete, so that the menus and toolbars can all be built and displayed.
                                Isn't he doing it arse-before-face as we say in the UK ?
                                Open Sketchup.
                                Start_operation.
                                Run the external 'tool'...
                                Load the objects in turn, each one as an individual component.
                                When all objects are done Export those objects in turn as separate SKPs.
                                Abort_operation.
                                Close Sketchup [no save].
                                That way nothing relies on something else 'opening in time' ?
                                • Dan RathbunD
                                  Dan Rathbun
                                  We'll, he knows C#, and not much of Ruby.
                                  Instead of using Sketchup in a hacked batchmode... he or someone needs to wrap the C++ Interfaces for SKPWriter.DLL for C#. (Likely someone has already done it.) Any way it would be better to directly create skps.
                                  • C
                                    Chris88
                                    THANKS to all for your efforts!
                                    Now it works!!! it's slower than before, but it runs and that's the main thing!
                                    @Dan: Thank you, you're the best! ^^
                                    • Dan RathbunD
                                      Dan Rathbun
                                      No problem...
                                      Just a note that the disposal of the tools filename array needs to be inside the conditional true blocks. (Otherwise we might get an error with the & method if tools gets set to nil, prematurely.)
                                        prevdir = Dir.getwd
                                        tools = Dir["*.rb"]
                                        Dir.chdir(prevdir)
                                        prevdir = nil
                                          tools = nil
                                        else
                                              tools = nil
                                              LineA.create_line
                                            end #if
                                      • 2 / 2
