    Mysterious Bug [followme related]
    30 Posts 4 Posters 1.9k Views 4 Watching
      Chris88
      @Dan: Thank you. Now my code looks like:
      require 'sketchup.rb'
      module Chris88
        module LineA
          TIMER = nil
          def self.create_line()
            # delete lines 1-4 with loop
             model = Sketchup.active_model
             entities = model.active_entities
             # Add the group to the entities in the model
             group = entities.add_group
             # Get the entities within the group
             # alle Objekte die den entities2 zugeordnet werden, werden automatisch zu einer gemeinsamen Gruppe gemacht
             entities2 = group.entities
            begin
              model.start_operation( 'LineA' )
              @width_small = 55 # 55
              @depth_small = 45 # 45
              @height_small = 30 # 30
              @width_big = 70 # 70
              @depth_big = 60 # 60
              @height_big = 70 # 40
              @height_line = (4/3) * @height_small
              @radius = 1
              @arcradius = 3
              @mat_linie=model.materials.add("Material_Linie")
              @mat_linie.color=Sketchup;;Color.new(124,252,0)  # => LawnGreen
              @anzahl_arcs = ((@depth_small-6)/6).to_i
              @pts =[]
              @helpvar_depth = 3
              @helpvar_pts = 1
              @helpvar_baseline = 1
              @helpvar_basearc = 1
             1.upto(@anzahl_arcs) do |x|
              @helpvar2_pts = @helpvar_pts +1
             if (x%2 > 0)
              @pts[@helpvar_pts] = [((@width_big-@width_small)/2)+5.35, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
              @pts[@helpvar_pts+1] = [@width_small+((@width_big-@width_small)/2)-5.3, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
              # arc_point
              @pts[@helpvar_pts+2] = [@width_small+((@width_big-@width_small)/2)-5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+3), @height_line]
              arc_circle_odd = entities2.add_circle @pts[@helpvar_pts+1], X_AXIS, @radius, 42
              arc_circle_face_odd = entities2.add_face arc_circle_odd
              arc_circle_face_odd.material = @mat_linie
              arc_circle_face_odd.back_material = @mat_linie
              line_circle_odd = entities2.add_circle @pts[@helpvar_pts], X_AXIS, @radius, 42
              line_circle_face_odd = entities2.add_face line_circle_odd
              line_circle_face_odd.material = @mat_linie
              line_circle_face_odd.back_material = @mat_linie
              @helpvar_baseline_odd = entities2.add_line @pts[@helpvar_pts], @pts[@helpvar_pts+1]
              @helpvar_basearc_odd = entities2.add_arc @pts[@helpvar_pts+2],[0,-1,0],[0,0,1],@arcradius,-5.degrees,185.degrees
              arc_circle_face_odd.followme @helpvar_basearc_odd
              line_circle_face_odd.followme @helpvar_baseline_odd
            elsif (x%2 == 0)
              @pts[@helpvar2_pts-1] = [((@width_big-@width_small)/2)+5.3, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
              @pts[@helpvar2_pts] = [@width_small+((@width_big-@width_small)/2)-5.35, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
              # arc_point
              @pts[@helpvar2_pts+1] = [((@width_big-@width_small)/2)+5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+3), @height_line]
              arc_circle_even = entities2.add_circle @pts[@helpvar2_pts-1], X_AXIS, @radius, 42
              arc_circle_face_even = entities2.add_face arc_circle_even
              arc_circle_face_even.material = @mat_linie
              arc_circle_face_even.back_material = @mat_linie
              line_circle_even = entities2.add_circle @pts[@helpvar2_pts], X_AXIS, @radius, 42
              line_circle_face_even = entities2.add_face line_circle_even
              line_circle_face_even.material = @mat_linie
              line_circle_face_even.back_material = @mat_linie
              @helpvar_baseline_even = entities2.add_line @pts[@helpvar2_pts], @pts[@helpvar2_pts-1]
              @helpvar_basearc_even = entities2.add_arc @pts[@helpvar2_pts+1],[0,1,0],[0,0,1],@arcradius,-5.degrees,185.degrees
              arc_circle_face_even.followme @helpvar_basearc_even
              line_circle_face_even.followme @helpvar_baseline_even
            end # if
            if (x == @anzahl_arcs)
              @pts[@helpvar_pts] = [((@width_big-@width_small)/2)+5.35, ((@depth_big-@depth_small)/2)+(@helpvar_depth+6), @height_line]
              @pts[@helpvar_pts+1] = [@width_small+((@width_big-@width_small)/2)-5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+6), @height_line]
              @helpvar_baseline_ende = entities2.add_line @pts[@helpvar_pts], @pts[@helpvar_pts+1]
              line_circle_face_odd.followme @helpvar_baseline_ende
            end # if
            @helpvar_depth = @helpvar_depth + 6
            @helpvar_pts = @helpvar_pts + 3
          end # upto - do
            rescue => e
              model.abort_operation
              puts("#{Module.nesting[0].name} Error #<#{e.class.name}; #{e.message}>")
              puts(e.backtrace)
            else
              model.commit_operation
          end # def
        end # module LineA
        # run when file loads
        if Sketchup.active_model &&
        Sketchup.active_model.active_entities
          LineA.create_line
        else
          LineA;;TIMER = UI.start_timer(2.0, true){
              UI.stop_timer(LineA;;TIMER)
              LineA.create_line
            end #if
      end # module Chris88
      Is this what do you mean?
      However it doesn't solve the bug.
      @thomthom: Thanks, that could help me. I know this, what you wrote in your sidenode, but it didn't work: When i draw a circle and a path, which starts at the central point of the cricle, Sketchup draw only the lines, but not the curves. This is why i decided alternatively to draw the lines and the curves seperately. Do you think the gaps could be the reason for the bug?
        Chris88
        Dan, i have to correct myself: It works, when i load the script from the Ruby Console = step forward! πŸ˜„ [Edit:] i just noticed, this is what thomthom meant. 😒 [/Edit]
        But it doesn't work yet, when i want to load the script from the plugin-folder by starting SU normally and the script is located in the plugin-folder.
          Don't think so. Just a sidenote. It is possible to create that shape in one operation.
          • Dan RathbunD Offline
            Dan Rathbun
            Alright replace the load loop with this ...
              prevdir = Dir.getwd
              Dir.chdir Sketchup.find_support_file("Tools")
              tools = Dir["*.rb"]
              Dir.chdir(prevdir)
              if ( tools & $LOADED_FEATURES == tools ) &&
                UI.start_timer(2.0, false){ LineA.create_line }
              else
                timer_LineA = UI.start_timer(2.0, true){
                    UI.stop_timer(timer_LineA)
                    LineA.create_line
                  end #if
              tools = nil
            I'm not here much anymore.
              Dan Rathbun
              And here's a version that makes sure the Tool Stack is ready ...
                prevdir = Dir.getwd
                tools = Dir["*.rb"]
                Dir.chdir(prevdir)
                Sketchup.active_model.active_entities &&
                Sketchup.active_model.tools.active_tool_id != 0
                else
                      LineA.create_line
                    end #if
                tools = nil
                Let's step back to the very beginning...
                Do you need this script to run automatically EVERY time EVERY SKP opens?
                A. Yes.
                Why for goodness sake ???
                A. No.
                Then what's the problem?
                If it runs from a menu/toolbar then everything will be loaded by the time you think about using it anyway. Just do NOT include the code that runs it as it loads and everything is cushty!
                πŸ˜•
                  Dan Rathbun
                  Because he's generating ruby scripts (that build geometry,) from a C# program, which reads XML data.
                  A batch mode use of Sketchup.
                  He's not that good with Ruby, or else he could use Ruby's XML libraries directly.
                  And I do have an API request in for an AppObserver "onReadyState" callback method.
                    Well, I tried the snippet - installed in my Plugins folder - now executing the command. It splatted. But wrapping the command in a timer that delay the operation with two seconds - no splat.
                      Dan Rathbun
                      The processing of the Tools dir must complete, so that the menus and toolbars can all be built and displayed.
                        Isn't he doing it arse-before-face as we say in the UK ?
                        Open Sketchup.
                        Start_operation.
                        Run the external 'tool'...
                        Load the objects in turn, each one as an individual component.
                        When all objects are done Export those objects in turn as separate SKPs.
                        Abort_operation.
                        Close Sketchup [no save].
                        That way nothing relies on something else 'opening in time' ?
                          Dan Rathbun
                          We'll, he knows C#, and not much of Ruby.
                          Instead of using Sketchup in a hacked batchmode... he or someone needs to wrap the C++ Interfaces for SKPWriter.DLL for C#. (Likely someone has already done it.) Any way it would be better to directly create skps.
                            Chris88
                            THANKS to all for your efforts!
                            Now it works!!! it's slower than before, but it runs and that's the main thing!
                            @Dan: Thank you, you're the best! ^^
                              Dan Rathbun
                              No problem...
                              Just a note that the disposal of the tools filename array needs to be inside the conditional true blocks. (Otherwise we might get an error with the & method if tools gets set to nil, prematurely.)
                                prevdir = Dir.getwd
                                tools = Dir["*.rb"]
                                Dir.chdir(prevdir)
                                prevdir = nil
                                  tools = nil
                                else
                                      tools = nil
                                      LineA.create_line
                                    end #if
                              • 2 / 2
