    Mysterious Bug [followme related]
    30 Posts 4 Posters 2.2k Views 4 Watching
    • Dan RathbunD Offline
      Dan Rathbun
      @thomthom said:
      I tried the code you posted initially. I get no crash. I did however leave out LineA.create_line so that it would not execute when SU loaded.
      Yea, it's dangerous to do stuff during SU load, as all the Google extensions are not yet loaded like Dynamic Components.
      I'm not here much anymore.
        Dan Rathbun
        maybe a wait timer like this is safer...
          # run when file loads
          if Sketchup.active_model &&
          Sketchup.active_model.active_entities
            UI.start_timer(0.0, false){ LineA.create_line }
          else
            LineA;;TIMER = UI.start_timer(2.0, true){
                UI.stop_timer(LineA;;TIMER)
                LineA.create_line
              end #if
          Chris88
          @Dan: Thank you. Now my code looks like:
          require 'sketchup.rb'
          module Chris88
            module LineA
              TIMER = nil
              def self.create_line()
                # delete lines 1-4 with loop
                 model = Sketchup.active_model
                 entities = model.active_entities
                 # Add the group to the entities in the model
                 group = entities.add_group
                 # Get the entities within the group
                 # alle Objekte die den entities2 zugeordnet werden, werden automatisch zu einer gemeinsamen Gruppe gemacht
                 entities2 = group.entities
                begin
                  model.start_operation( 'LineA' )
                  @width_small = 55 # 55
                  @depth_small = 45 # 45
                  @height_small = 30 # 30
                  @width_big = 70 # 70
                  @depth_big = 60 # 60
                  @height_big = 70 # 40
                  @height_line = (4/3) * @height_small
                  @radius = 1
                  @arcradius = 3
                  @mat_linie=model.materials.add("Material_Linie")
                  @mat_linie.color=Sketchup;;Color.new(124,252,0)  # => LawnGreen
                  @anzahl_arcs = ((@depth_small-6)/6).to_i
                  @pts =[]
                  @helpvar_depth = 3
                  @helpvar_pts = 1
                  @helpvar_baseline = 1
                  @helpvar_basearc = 1
                 1.upto(@anzahl_arcs) do |x|
                  @helpvar2_pts = @helpvar_pts +1
                 if (x%2 > 0)
                  @pts[@helpvar_pts] = [((@width_big-@width_small)/2)+5.35, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
                  @pts[@helpvar_pts+1] = [@width_small+((@width_big-@width_small)/2)-5.3, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
                  # arc_point
                  @pts[@helpvar_pts+2] = [@width_small+((@width_big-@width_small)/2)-5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+3), @height_line]
                  arc_circle_odd = entities2.add_circle @pts[@helpvar_pts+1], X_AXIS, @radius, 42
                  arc_circle_face_odd = entities2.add_face arc_circle_odd
                  arc_circle_face_odd.material = @mat_linie
                  arc_circle_face_odd.back_material = @mat_linie
                  line_circle_odd = entities2.add_circle @pts[@helpvar_pts], X_AXIS, @radius, 42
                  line_circle_face_odd = entities2.add_face line_circle_odd
                  line_circle_face_odd.material = @mat_linie
                  line_circle_face_odd.back_material = @mat_linie
                  @helpvar_baseline_odd = entities2.add_line @pts[@helpvar_pts], @pts[@helpvar_pts+1]
                  @helpvar_basearc_odd = entities2.add_arc @pts[@helpvar_pts+2],[0,-1,0],[0,0,1],@arcradius,-5.degrees,185.degrees
                  arc_circle_face_odd.followme @helpvar_basearc_odd
                  line_circle_face_odd.followme @helpvar_baseline_odd
                elsif (x%2 == 0)
                  @pts[@helpvar2_pts-1] = [((@width_big-@width_small)/2)+5.3, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
                  @pts[@helpvar2_pts] = [@width_small+((@width_big-@width_small)/2)-5.35, ((@depth_big-@depth_small)/2)+@helpvar_depth, @height_line]
                  # arc_point
                  @pts[@helpvar2_pts+1] = [((@width_big-@width_small)/2)+5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+3), @height_line]
                  arc_circle_even = entities2.add_circle @pts[@helpvar2_pts-1], X_AXIS, @radius, 42
                  arc_circle_face_even = entities2.add_face arc_circle_even
                  arc_circle_face_even.material = @mat_linie
                  arc_circle_face_even.back_material = @mat_linie
                  line_circle_even = entities2.add_circle @pts[@helpvar2_pts], X_AXIS, @radius, 42
                  line_circle_face_even = entities2.add_face line_circle_even
                  line_circle_face_even.material = @mat_linie
                  line_circle_face_even.back_material = @mat_linie
                  @helpvar_baseline_even = entities2.add_line @pts[@helpvar2_pts], @pts[@helpvar2_pts-1]
                  @helpvar_basearc_even = entities2.add_arc @pts[@helpvar2_pts+1],[0,1,0],[0,0,1],@arcradius,-5.degrees,185.degrees
                  arc_circle_face_even.followme @helpvar_basearc_even
                  line_circle_face_even.followme @helpvar_baseline_even
                end # if
                if (x == @anzahl_arcs)
                  @pts[@helpvar_pts] = [((@width_big-@width_small)/2)+5.35, ((@depth_big-@depth_small)/2)+(@helpvar_depth+6), @height_line]
                  @pts[@helpvar_pts+1] = [@width_small+((@width_big-@width_small)/2)-5, ((@depth_big-@depth_small)/2)+(@helpvar_depth+6), @height_line]
                  @helpvar_baseline_ende = entities2.add_line @pts[@helpvar_pts], @pts[@helpvar_pts+1]
                  line_circle_face_odd.followme @helpvar_baseline_ende
                end # if
                @helpvar_depth = @helpvar_depth + 6
                @helpvar_pts = @helpvar_pts + 3
              end # upto - do
                rescue => e
                  model.abort_operation
                  puts("#{Module.nesting[0].name} Error #<#{e.class.name}; #{e.message}>")
                  puts(e.backtrace)
                else
                  model.commit_operation
              end # def
            end # module LineA
              LineA.create_line
            else
                  LineA.create_line
                end #if
          end # module Chris88
          Is this what do you mean?
          However it doesn't solve the bug.
          @thomthom: Thanks, that could help me. I know this, what you wrote in your sidenode, but it didn't work: When i draw a circle and a path, which starts at the central point of the cricle, Sketchup draw only the lines, but not the curves. This is why i decided alternatively to draw the lines and the curves seperately. Do you think the gaps could be the reason for the bug?
            Chris88
            Dan, i have to correct myself: It works, when i load the script from the Ruby Console = step forward! πŸ˜„ [Edit:] i just noticed, this is what thomthom meant. 😒 [/Edit]
            But it doesn't work yet, when i want to load the script from the plugin-folder by starting SU normally and the script is located in the plugin-folder.
              Don't think so. Just a sidenote. It is possible to create that shape in one operation.
                Dan Rathbun
                Alright replace the load loop with this ...
                  prevdir = Dir.getwd
                  Dir.chdir Sketchup.find_support_file("Tools")
                  tools = Dir["*.rb"]
                  Dir.chdir(prevdir)
                  if ( tools & $LOADED_FEATURES == tools ) &&
                    UI.start_timer(2.0, false){ LineA.create_line }
                  else
                    timer_LineA = UI.start_timer(2.0, true){
                        UI.stop_timer(timer_LineA)
                        LineA.create_line
                      end #if
                  tools = nil
                  Dan Rathbun
                  And here's a version that makes sure the Tool Stack is ready ...
                    prevdir = Dir.getwd
                    tools = Dir["*.rb"]
                    Dir.chdir(prevdir)
                    Sketchup.active_model.active_entities &&
                    Sketchup.active_model.tools.active_tool_id != 0
                    else
                          LineA.create_line
                        end #if
                    tools = nil
                    Let's step back to the very beginning...
                    Do you need this script to run automatically EVERY time EVERY SKP opens?
                    A. Yes.
                    Why for goodness sake ???
                    A. No.
                    Then what's the problem?
                    If it runs from a menu/toolbar then everything will be loaded by the time you think about using it anyway. Just do NOT include the code that runs it as it loads and everything is cushty!
                    πŸ˜•
                      Dan Rathbun
                      Because he's generating ruby scripts (that build geometry,) from a C# program, which reads XML data.
                      A batch mode use of Sketchup.
                      He's not that good with Ruby, or else he could use Ruby's XML libraries directly.
                      And I do have an API request in for an AppObserver "onReadyState" callback method.
                        Well, I tried the snippet - installed in my Plugins folder - now executing the command. It splatted. But wrapping the command in a timer that delay the operation with two seconds - no splat.
                          Dan Rathbun
                          The processing of the Tools dir must complete, so that the menus and toolbars can all be built and displayed.
                            Isn't he doing it arse-before-face as we say in the UK ?
                            Open Sketchup.
                            Start_operation.
                            Run the external 'tool'...
                            Load the objects in turn, each one as an individual component.
                            When all objects are done Export those objects in turn as separate SKPs.
                            Abort_operation.
                            Close Sketchup [no save].
                            That way nothing relies on something else 'opening in time' ?
                              Dan Rathbun
                              We'll, he knows C#, and not much of Ruby.
                              Instead of using Sketchup in a hacked batchmode... he or someone needs to wrap the C++ Interfaces for SKPWriter.DLL for C#. (Likely someone has already done it.) Any way it would be better to directly create skps.
                                Chris88
                                THANKS to all for your efforts!
                                Now it works!!! it's slower than before, but it runs and that's the main thing!
                                @Dan: Thank you, you're the best! ^^
                                  Dan Rathbun
                                  No problem...
                                  Just a note that the disposal of the tools filename array needs to be inside the conditional true blocks. (Otherwise we might get an error with the & method if tools gets set to nil, prematurely.)
                                    prevdir = Dir.getwd
                                    tools = Dir["*.rb"]
                                    Dir.chdir(prevdir)
                                    prevdir = nil
                                      tools = nil
                                    else
                                          tools = nil
                                          LineA.create_line
                                        end #if
                                  • 2 / 2
