    Obj Exporter
    12 Posts 5 Posters 1.6k Views 5 Watching
    • iichiversiiI
      iichiversii
      Neither of these worked for me, can you give a tutorial πŸ˜„
      Bring on the Rain...
        How didn't they work? - help us help you...
        • iichiversiiI
          iichiversii
          I really dont know but when i clocked on the converter plugin nothing happened
            πŸ˜•
            What 'converter plugin'?
            You clicked [sic] on what exactly?
            Have you 'installed' it properly in the Plugins folder?
            Are you sure you know how to install plugins?
            Is there a menu item in Sketchup from which to run the tool?
            Have you carefully followed the instructions supplier with the tool?
            Was your model [SKP file] saved first?
            You are not helping us to help you very much πŸ˜•
            Please give a bit more information so we can sort this for you...
            • T
              tak2hata
              This "su2objmtl" plugin did not work on sketchup v8.
              Causing code is line 306 in su2objmtl.rb
              t = Geom;;Transformation.axes (Geom;;Point3d.new 0,0,0),(Geom;;Vector3d.new 1,0,0),(Geom;;Vector3d.new 0,1,0),(Geom;;Vector3d.new 0,0,1)
              It changes to code like this.It will work.
              t = Geom;;Transformation.axes( Geom;;Point3d.new( 0,0,0),Geom;;Vector3d.new( 1,0,0),Geom;;Vector3d.new( 0,1,0),Geom;;Vector3d.new( 0,0,1) )
              And This plugin did not work on mac.because difference of file separator between windows and mac.
              I am sorry for without updating this plugin.
              I could not change my homepage because I changed my computer.
              I will create new homepage with same adress in neary future.
              Thanks.
              by TAK2HATA
                stagelight
                Thank you very much for this, tak2hata.
                • iichiversiiI
                  iichiversii
                  Hey Tig sorry for the lack of info, i got it working, great plugin, thanks
                    stagelight
                    tak2hata... Could you please update this to work with SU8.
                    Thank you.
                    • T
                      tak2hata
                      Thank you.
                      Hi,stagelight.
                      I update su2objmtl.
                      Upload here.
                      su2objmtl jan 15,2012
                      It will upload in my homepage soon.
                      Thanks.
                      by TAK2HATA
                        stagelight
                        Thank you.
