    Obj Exporter
    12 Posts 5 Posters 1.6k Views 5 Watching
      stagelight
      I found a great Obj exporter last night.
      The site is in Japanese, but just download the su2objmtl2.zip file.
      The only file you need in the zip, is su2objmtl.rb
      http://onigiriburning.so.land.to/
      My apologies if this is well known, but I hadn't seen this before, so I made my first post on here.
      I can verify that it works in Sketchup 7.1. It exports to an obj, with the textures.
      I tried it in Sketchup 8, but the textures were not exported.
      Thanks.
      Mark
      • Didier BurD
        Didier Bur
        If it doesnt work, try this one by TIG: http://rhin.crai.archi.fr/rld/plugin_details.php?id=591
        Cheers,
        DB
        • iichiversiiI
          iichiversii
          Neither of these worked for me, can you give a tutorial πŸ˜„
          Bring on the Rain...
            How didn't they work? - help us help you...
            • iichiversiiI
              iichiversii
              I really dont know but when i clocked on the converter plugin nothing happened
                πŸ˜•
                What 'converter plugin'?
                You clicked [sic] on what exactly?
                Have you 'installed' it properly in the Plugins folder?
                Are you sure you know how to install plugins?
                Is there a menu item in Sketchup from which to run the tool?
                Have you carefully followed the instructions supplier with the tool?
                Was your model [SKP file] saved first?
                You are not helping us to help you very much πŸ˜•
                Please give a bit more information so we can sort this for you...
                • T
                  tak2hata
                  This "su2objmtl" plugin did not work on sketchup v8.
                  Causing code is line 306 in su2objmtl.rb
                  t = Geom;;Transformation.axes (Geom;;Point3d.new 0,0,0),(Geom;;Vector3d.new 1,0,0),(Geom;;Vector3d.new 0,1,0),(Geom;;Vector3d.new 0,0,1)
                  It changes to code like this.It will work.
                  t = Geom;;Transformation.axes( Geom;;Point3d.new( 0,0,0),Geom;;Vector3d.new( 1,0,0),Geom;;Vector3d.new( 0,1,0),Geom;;Vector3d.new( 0,0,1) )
                  And This plugin did not work on mac.because difference of file separator between windows and mac.
                  I am sorry for without updating this plugin.
                  I could not change my homepage because I changed my computer.
                  I will create new homepage with same adress in neary future.
                  Thanks.
                  by TAK2HATA
                    stagelight
                    Thank you very much for this, tak2hata.
                    • iichiversiiI
                      iichiversii
                      Hey Tig sorry for the lack of info, i got it working, great plugin, thanks
                        stagelight
                        tak2hata... Could you please update this to work with SU8.
                        Thank you.
                        • T
                          tak2hata
                          Thank you.
                          Hi,stagelight.
                          I update su2objmtl.
                          Upload here.
                          su2objmtl jan 15,2012
                          It will upload in my homepage soon.
                          Thanks.
                          by TAK2HATA
                            stagelight
                            Thank you.
