    Obj Exporter
    12 Posts 5 Posters 1.3k Views 5 Watching
    • Didier BurD Offline
      Didier Bur
      If it doesnt work, try this one by TIG: http://rhin.crai.archi.fr/rld/plugin_details.php?id=591
      Cheers,
      DB
      • iichiversiiI Offline
        iichiversii
        Neither of these worked for me, can you give a tutorial πŸ˜„
        Bring on the Rain...
          How didn't they work? - help us help you...
            iichiversii
            I really dont know but when i clocked on the converter plugin nothing happened
              πŸ˜•
              What 'converter plugin'?
              You clicked [sic] on what exactly?
              Have you 'installed' it properly in the Plugins folder?
              Are you sure you know how to install plugins?
              Is there a menu item in Sketchup from which to run the tool?
              Have you carefully followed the instructions supplier with the tool?
              Was your model [SKP file] saved first?
              You are not helping us to help you very much πŸ˜•
              Please give a bit more information so we can sort this for you...
                tak2hata
                This "su2objmtl" plugin did not work on sketchup v8.
                Causing code is line 306 in su2objmtl.rb
                t = Geom;;Transformation.axes (Geom;;Point3d.new 0,0,0),(Geom;;Vector3d.new 1,0,0),(Geom;;Vector3d.new 0,1,0),(Geom;;Vector3d.new 0,0,1)
                It changes to code like this.It will work.
                t = Geom;;Transformation.axes( Geom;;Point3d.new( 0,0,0),Geom;;Vector3d.new( 1,0,0),Geom;;Vector3d.new( 0,1,0),Geom;;Vector3d.new( 0,0,1) )
                And This plugin did not work on mac.because difference of file separator between windows and mac.
                I am sorry for without updating this plugin.
                I could not change my homepage because I changed my computer.
                I will create new homepage with same adress in neary future.
                Thanks.
                by TAK2HATA
                  stagelight
                  Thank you very much for this, tak2hata.
                    iichiversii
                    Hey Tig sorry for the lack of info, i got it working, great plugin, thanks
                      stagelight
                      tak2hata... Could you please update this to work with SU8.
                      Thank you.
                        tak2hata
                        Thank you.
                        Hi,stagelight.
                        I update su2objmtl.
                        Upload here.
                        su2objmtl jan 15,2012
                        It will upload in my homepage soon.
                        Thanks.
                        by TAK2HATA
                          stagelight
                          Thank you.
