    Best way of modeling a column capital ...
    14 Posts 6 Posters 2.9k Views 6 Watching
      That will kill SU. But good challenge. Though they are plentiful on Archive3D. I'd use a texture in place if possible. Properly projected or mapped on lo-poly version would look great.
      • leedeeteeL Offline
        leedeetee
        Thanks Rich, the thought of a photo-texture never even entered my head. 😳
        I don't intend doing any close ups of the columns so this should be great, just need some jiggerypokery in PS first then.
        Thanks again.
          You could bastadize this....
          http://storage3d.com/storage/2010.12/b69600465c9f817fc5e427f24628bc94.jpg
          http://www.archive3d.net/?a=download&id=e8ccefe6
          That'd be cheating though πŸ˜‰
            leedeetee
            Hehe, it sure would. 😎
            • andybotA Offline
              andybot
              I've yet to find a halfway decent corinthian capital in any 3D repository. If you find one let me know. I like the suggestion to do a photo-textured low-poly version.
              • Alan FraserA Offline
                Alan Fraser
                Rich is right; use a texture. I have modelled a corinthian column in geometry, but even the low poly version was nearly 4000 faces. If you've got a lot of them, that's not good news.
                The capital below, however, is image based and only has 423 faces...just enough to provide decent looking corners.
                Obviously it requires a column, but that's not going to amount to much.
                Sorry I can't share, as it's commercial...but it at least shows what can be done with ultra low poly and a map.
                http://www.formfonts.com/requestFile.php?type=1&id=4931&img=FF_Model_ID4931_1_pedestal_classical.jpg
                3D Figures
                  Just for info because it's make with ZBrush πŸ˜‰
                  But the construction can maybe be help you on your project! πŸ˜‰
                  http://forum.zbrush.fr/index.php?action=dlattach;topic=8210.0;attach=19204;image
                  By Nicolas
                  http://forum.zbrush.fr/index.php?action=dlattach;topic=8210.0;attach=19541;image
                  • andybotA Offline
                    andybot
                    of course! I should have checked formfonts!
                    The columns there look pretty nice Alan!
                    for example:
                    http://www.formfonts.com/viewModel.php?id=4699&config=3&action=&sub_action=&type=&active=
                      leedeetee
                      Hi all,
                      Thanks so much for the input. I definitely think a texture is the way forward, will post up the finished article in the WIP thread when it's done.
                      Thanks again.
                      Lee
                        leedeetee
                        Came up with this. Get's found out with a close up but doesn't look too bad from further away.
                        Thanks again for all your help. πŸ‘
                          That's more than sufficient IMO. Pilou's solution is obviously an overkill unless you are examining it from a couple of centimetres (but still an overkill as far as invested time is concerned - ZBrush or not, you only spend days on a capital like that if you want to show of with that detail only).
                          Can you show a real close-up so we can see where the "cheat" with textures begin?
                            leedeetee
                            Here it is. Think the geometry could be reduced a bit more but going to run with this at the moment anyway.
                              πŸ‘ Thanks.
                              Indeed, as you are there to represent geometry much with textures, there could be some place of further reduction but still better than modelling every part.
