    Best way of modeling a column capital ...
    14 Posts 6 Posters 3.0k Views 6 Watching
    • leedeeteeL
      leedeetee
      That'd be cheating though πŸ˜‰
      Hehe, it sure would. 😎
      • andybotA
        andybot
        I've yet to find a halfway decent corinthian capital in any 3D repository. If you find one let me know. I like the suggestion to do a photo-textured low-poly version.
        • Alan FraserA
          Alan Fraser
          Rich is right; use a texture. I have modelled a corinthian column in geometry, but even the low poly version was nearly 4000 faces. If you've got a lot of them, that's not good news.
          The capital below, however, is image based and only has 423 faces...just enough to provide decent looking corners.
          Obviously it requires a column, but that's not going to amount to much.
          Sorry I can't share, as it's commercial...but it at least shows what can be done with ultra low poly and a map.
          http://www.formfonts.com/requestFile.php?type=1&id=4931&img=FF_Model_ID4931_1_pedestal_classical.jpg
          3D Figures
            Just for info because it's make with ZBrush πŸ˜‰
            But the construction can maybe be help you on your project! πŸ˜‰
            http://forum.zbrush.fr/index.php?action=dlattach;topic=8210.0;attach=19204;image
            By Nicolas
            http://forum.zbrush.fr/index.php?action=dlattach;topic=8210.0;attach=19541;image
            • andybotA
              andybot
              of course! I should have checked formfonts!
              The columns there look pretty nice Alan!
              for example:
              http://www.formfonts.com/viewModel.php?id=4699&config=3&action=&sub_action=&type=&active=
              • leedeeteeL
                leedeetee
                Hi all,
                Thanks so much for the input. I definitely think a texture is the way forward, will post up the finished article in the WIP thread when it's done.
                Thanks again.
                Lee
                • leedeeteeL
                  leedeetee
                  Came up with this. Get's found out with a close up but doesn't look too bad from further away.
                  Thanks again for all your help. πŸ‘
                  • GaieusG
                    That's more than sufficient IMO. Pilou's solution is obviously an overkill unless you are examining it from a couple of centimetres (but still an overkill as far as invested time is concerned - ZBrush or not, you only spend days on a capital like that if you want to show of with that detail only).
                    Can you show a real close-up so we can see where the "cheat" with textures begin?
                    • leedeeteeL
                      leedeetee
                      Here it is. Think the geometry could be reduced a bit more but going to run with this at the moment anyway.
                      • GaieusG
                        πŸ‘ Thanks.
                        Indeed, as you are there to represent geometry much with textures, there could be some place of further reduction but still better than modelling every part.
