    [Plugin] SectionCutFace
    569 Posts 171 Posters 478.0k Views 170 Watching
      If you make your section-cuts inside groups the cuts-faces are only applied to the cut objects only in the context. So you need to have matching section-panes inside different groups and 'face' them individually ?
      I can't see a way to do it otherwise... πŸ˜•
      • utilerU Offline
        utiler
        No worries, TIG. I don't see that working efficiently as there could be many groups requiring cut so multiple section plans requiring individual actions makes it too long a process...
        Thought it was worth a try... πŸ‘
        Just Curious...
          a.danielli
          I just downloaded this exciting plugin but I don't know how to use it.
          to try it..
          I made a cube, selected the section cut and created a section.
          I right-clicked on the section cut said "Add Section-Cut Face"
          I don't know what parameters to select so I used the default and clicked ok.
          Nothing happened. I just got a new layer called "CUT-06737377"
          I'd like to use it to Poche architecture plans/ sections.
          Can someone please help?
          Adam
          Sketchup Pro 8
          Mac OS x 10.6.8
            Did you move the section cut into the cube at all? i just ran it on my Mac doing what you said you did and I got the section cut face as expected. Could you post your non-working example?
            Here's a shot of my example.
              As Dave said you need to cut a section for it to add a face to, placing the section-plane on an object's face won't produce a SectionCutFace - move the cutting-plane into the object even if it's only 1mm...
                toddbg
                Great plugin! I was able to use it for one portion of my model, however in another section plane I run the plugin and get no face fills.
                Any suggestions on what to change?
                I can post a link to the model if that would be helpful.
                Todd
                  Todd
                  If you have non-solids, with overlapping 'volumes' sometimes it can't decide which is solid and which is void, so no faces get made.
                  Repeat - this time 'keeping all edges' [option].
                  Then you can see what's the complexity you've generated...
                  and then manually face/color the required parts that you want as solids...
                    toddbg
                    I'm still having no luck.
                    I've posted my model to my dropbox.
                    http://dl.dropbox.com/u/199646/CB_connector_final.skp
                    The currently active scene is the one I am having a hard time with. The last scene is the one that seemed to work correctly.
                    NOTE: I've told the section plane to hide.
                    If you have any insights I would appreciate it.
                    Thank you.
                    Todd
                      Right!
                      One look at your SKP showed the issue.
                      It's tiny ! 😲
                      Sketchup/OpenGL have problems coping with tiny faces [<~1mm/0.001sq"] - and also enormous faces.
                      Sketchup is designed as a tool to model objects within a range of 'normal sizes' - doorhandles/doors/walls/buildings/blocks etc [but not tiny screws or giant cities].
                      Your SKP is at the level of something like the parts of a wristwatch !
                      There are some faces/edges <0.4mm across in the part that has the issues - the one that succeeded is just large enough to exist.
                      So all tools like this will fail to make the desired geometry, because Sketchup itself simply can't create it. I'm surprised you haven't had problems with the geometry before...
                      However, a workaround is to group the object, edit the group, select-all and scale your groups' entities by say x10 or x100, and then make the faces using this tool [or others like it] and then scale everything [including the section-cut-face] back down by 0.1 or 0.01 - the tiny faces can 'exist' it's just the 'making' of them that fails...
                      πŸ€“
                        toddbg
                        @tig said:
                        Right!
                        It's tiny ! 😲
                        πŸ€“
                        That worked! Thanks TIG.
                        I'm still learning the limits of what Sketchup can do and find myself modeling what would be real world parts for projects I am working on.
                        Unfortunately these do tend to be screws that are 0-80 in size or in this case, walls that are ~1/16" thick. (model train and steam engine parts...)
                        I'll have to keep the scaling trick in mind and work at a larger scale and then back down to real size for production documents.
                        Thanks again!
                          If you work in decimal inches why not switch Model Info > Units, displayed units = 'off', change to 'meters' and work as if you are in inches.
                          If you want to display units on dims etc later [at the end after small face modeling is done] - change the units back to inches etc as desired, and then draw a line typing in 1m+enter in the model-context [you add the 'm' so whatever the units it will be 1 'meter' long], use the Tapemeasure tool and pick the two ends of that 1m long line and type in 1"+enter, when prompted answer Yes to rescale the model. The model shrinks to be in inches, with dims etc now displaying in inches etc as set...
                          • N Offline
                            nickdk
                            Thank you for this great tool!! πŸ˜„
                            Sometimes when I use it it's very slow, it can take 10mins on a large model, is there any tips on speeding things up?
                            I have a current model with many round shapes and circles with 500 sides and so on, it takes forever.
                            I'm not trying to sound non-thankful, I just wondering if I can do something to make it go faster πŸ˜„
                              I think the answer is in your question. Circles with 500 sides? Whatever for? Surely you don't need that many.
                              • N Offline
                                nickdk
                                Hehe πŸ˜„ yeah 500 sides might be a lot, the reason for the many sides is that I just recently found out how to make smooth circles in SU and I didn't really think to much about the amount of sides I entered when model ling, I assumed that it would take a lot of sides to get a really smooth result? I need to import the SU model in 3Ds max when it's done and I wanted all circular shapes to be perfect. It might be overkill though, it is making my life hard with this complex geometry that's for sure! πŸ˜•
                                thank you for the insight!
                                  It's surely overkill and you've kind of shot yourself in the foot, metaphorically speaking. You can get smooth curves with far fewer sides and increase performance.
                                  • N Offline
                                    nickdk
                                    how many sides do you think I'll need? I have attached WIP to give an idea of the shapes involved and the detailing πŸ˜„
                                    I did a test with 100 sides and the polygons were visible so I guess it does require quite a lot :S
                                      I don't know. It's kind of dark so it's hard to see.
                                      Does this look like it is smooth enough?
                                      http://farm7.staticflickr.com/6223/6318648290_530026a3b2_z.jpg
                                      That's 50 segments going around the long way.
                                      • N Offline
                                        nickdk
                                        yes it looks perfect:) My problem is that the circular shapes I'm using in my design are differently scaled - some of them are 20meters in diameter so the 'jagged' faces are much more visible.
                                          That ring is drawn at a bit over 5 meters in diameter but I doubt it would look any different at 20m or 200m.
                                            ayik37
                                            thanks sir,that plugin working very well in my sketchup πŸ‘
                                            • 28
                                            • 29
                                            • 6 / 29
