    Maxwell for SU VS Twilight
    extensions
    121 Posts 25 Posters 31.9k Views 25 Watching
    • andybotA Offline
      andybot
      Thanks Jason. I suppose I'll just have to see for myself when I have a chance to play with it and compare some scenes. This has been a helpful thread to get a general idea of where the strengths are of Maxwell.
      • majidM Offline
        majid
        off topic but maybe interesting: motiva colimo+ Thea render is almost a miracle, has anyone tested it? (Thea as a hybrid engine and motiva as a time saver!!)
        I also like the relight system of Thea:1-relight.jpg
        fymoro models are good for almost every render engine (maybe not good for hypershot that has a weak interior render result)
        • arail1A Offline
          arail1
          I also like the relight system of Thea:[attachment=0:ofhpbqth]<!-- ia0 -->1-relight.jpg<!-- ia0 -->[/attachment:ofhpbqth]
          I'm curious about this. I couldn't find a page to download a demo from motiva colimo but I'd like to try it out.
          Maybe you could post some more thoughts, insights about it's usefulness?
          Edit: I just found the demo download link.
          • majidM Offline
            majid
            I tried again the free maxwell plugin version, still too noisy for interior. I got a reasonable result out of twilight with biased 0unbiased settings...on my old crappy machine
            • jason_marantoJ Offline
              jason_maranto
              Hardly surprising since I just spent pages of posts telling you that it will not work -- and why, and what the solution is (pay the $95).
              • irwanwrI Offline
                irwanwr
                @jason_maranto said:
                ... and why, and what the solution is (pay the $95).
                that seems quite obvious πŸ˜›
                • majidM Offline
                  majid
                  @majid said:
                  I tried again the free maxwell plugin version, still too noisy for interior. I got a reasonable result out of twilight with biased , unbiased settings...on my old crappy machine
                  I see I see, I am comparing both demo versions of maxwell and twilight(IMO twilight has a good demo, fully functioning, biased + unbiased engine, more light options..., with a watermark and size limitation, while maxwell has no watermark, but not good quality, etc...)99$- 95$
                    jason_maranto
                    There is no watermark because it is not a demo -- there is no demo for Maxwell except for the full Maxwell Render Suite. It is a fully functioning render engine unlimited in both time of use and of watermark and very capable of producing excellent (and relatively fast) results for what it designed to do... all for free.
                    However it was not made to do what you are trying to do. which is stated clearly on their webpage and I have said over and over again on these forums -- but the good news in not everybody needs to do what you are trying to do... for those users it may be a perfectly usable piece of free software.
                    I get the sense you are trying to prove a point, but what you seem to fail to grasp is that it is not a comparable software -- it was never designed to be. The Twilight demo (and all other demos) are demoing the full software -- this is only a small subset of Maxwells capabilities.
                    The $95 version of the Stand-alone plugin is more comparable in quality for the types of renders you want to produce, but it too is simply a subset of the full Maxwell Render Suite.
                    If you cannot understand it's designed function then you cannot prove it fails -- your conception of what it should do is totally flawed. I've proved elsewhere on these forums that the free version of the stand-alone plugin can render exterior (daylight or IBL envirnments) shots with extremely large and detailed geometry to a very high quality level very rapidly (see below for an example).
                    One of the Eye Candy (from silver_shadow) models rendered with IBL environment to SL 12 which took 4 minutes.
                    Best,
                    Jason.
                      sonder
                      The best and most straight forward free ware I have tried has been Kerkythea without exception. I was rendering within a couple hours of playing around - that was without using any tutorials or watching any videos. The output and ease of use with sketchup is amazing. I have just started looking into Thea which looks incredible. I will be ordering that as soon as I get back in my office early next week. My hats off to the developers of both those programs.
                        And probably not incidentally, that's basically the same person.
                          sonder
                          Excellent! I guess my transition should be that much easier.
                          • irwanwrI Offline
                            irwanwr
                            in my opinion too. KT is the best freeware available ever there for rendering.
                            i spent less than 48 hours from learning both SketchUp and Kerkythea to send 3 models rendered to a friend. who ask for a favour to give an idea for a quite small building to develop.
                            back then there was only SketchUp 6 available to download and learn πŸ˜„
                            here's one of them that still left
                            [attachment=0:2d336y5i]<!-- ia0 -->3 x 11 C lights.jpg<!-- ia0 -->[/attachment:2d336y5i]
                            if there's any other 3D modelling and a render application that would allow you to download-learn-modelling-render and send 3 models in less than 48 hours, please let me know (not to mention they are the freeware ones). i might give it a thought to try them πŸ˜›
                            • andybotA Offline
                              andybot
                              Well, I finally had a chance to try the Maxwell free plugin. I like it! The user interface is great, and I like the preset material types. The adjustments that I want to make are all there - environment settings, material reflections, etc. In a few tests, it is actually not as slow as I feared compared to vray. I did try some interior daylit scenes, and while the speed is not too far off, the output quality is significantly more noisy with Maxwell. Overall, I like the lighting quality better than twilight, but I didn't see a whole lot of difference compared to vray. Of course, with vray, it is much more complicated to control material qualities, so it would be more difficult for a newbie to use out of the box.
                              In any case, it was nice to try, and I can certainly recommend it to those looking. For me though, Maxwell doesn't appear to offer anything that I can't get with vray.
                                jason_maranto
                                No doubt, the standalone plugin was never meant to compete with VRay -- for that you would want the full Maxwell Render Suite.
                                BTW did you try the new pre-release version from the Maxwell forums or just the older download from the Maxwell website?
                                Also if you care to share your test scenes I can show you the difference between the "Draft" engine and the "Production" engine (since you can only test the draft engine with the free version).
                                Best,
                                Jason.
                                • andybotA Offline
                                  andybot
                                  I will post a test scene and some examples of renders from the scene as soon as I get a chance.
                                  Thanks for the interest!
                                  Andy
                                    ledisnomad
                                    Which render plugin to use is a constant debate around here. I tried to start a spreadsheet for collaboration here: http://forums.sketchucation.com/viewtopic.php?f=81&t=3220&start=45. We could keep updating it and anybody is interested...
                                    There is one really big thing I see missing from this conversation, though:
                                    zoom123, what do you want to render and for what purpose?!
                                    Even if you are only doing this for fun, it can make a big difference in your choice.
                                    For example, I'm an architect and 99% of my renderings are for quick design studies. Somebody said that Maxwell allowed for quicker scene setup and that they didn't care how long it took, because they could run the rendering overnight. That may be true for some types of presentation images, but for me, I often need it ASAP, setup and all, exterior or interior. I don't have time to let a rendering bake long enough to remove noise in Maxwell or any unbiased engine (that said, Maxwell would probably be OK for many of my exterior renderings, but since I need it for both exterior or interior, I don't want to deal with two renderers). So for me it's biased all the way, V-Ray specifically. Now with V-Ray RT like Maxwell Fire, I have even faster setup times.
                                    So, zoom123, what are you rendering and why?
                                    • irwanwrI Offline
                                      irwanwr
                                      hi there,
                                      sorry for interrupting your discussion on Maxwell vs Twilight.
                                      i've tried to remove my post, but cannot find the erase button.
                                      anyway, if you already have v-ray with that kind of results,
                                      what is the point discussing Maxwell vs Twilight?
                                      have a good time people.
                                      • massimoM Offline
                                        massimo Moderator
                                        Sorry, but comparing Twilight or Maxwell unbiased render (at least from what I can see) with Vray biased render is pointless. Try the same with a Twilight biased preset.
                                        • andybotA Offline
                                          andybot
                                          I hear your point, and I added the biased setting as well. PDQ! I just think the output for interiors is relatively lousy.
                                          I think the usefulness of this comparison is that there are choices based not just on quality and speed but in price and ease of use that distinguishes these render engines. The maxwell GUI and the way the settings are done just feels much more modern and intuitive, props to the developers in the effort that went into it.
                                          Andy
                                          • andybotA Offline
                                            andybot
                                            Here are two interior scenes rendered from the attached model.
                                            I am using the Maxwell free rendering plugin from the downloads (not any latest build. May look into that later on.) Vray is the current 1.49.01 with a combination skylight and GI and slightly higher irradiance map settings. Since the topic is maxwell vs. twilight, I also rendered the scenes at interior+ settings, letting it run for 30 mins. The maxwell scenes ran for about 30 minutes each.
                                            Edit: added biased renders from Twilight on Medium+ setting, first scene 50 seconds, second scene 110 seconds. Thanks for the suggestion Massimo
                                            comparison scene 1
                                            maxwell scene 1
                                            twilight scene 1
                                            vray scene 1
                                            twilight scene 1 biased
                                            comparison scene 2
                                            maxwell scene 2
                                            twilight scene 2
                                            vray scene 2
                                            twilight scene 2 biased
                                            and the file is here:
                                            http://www.mediafire.com/?yiujl1c94y1wlf9
                                            • 4 / 7
