    Dimensioning in inches
    7 Posts 5 Posters 542 Views 5 Watching
      mwm5053
      Hi all I'm glad to find this forum. Really had trouble with SU in the past till I ran into http://www.srww.com/blog/?p=13355 and has been going pretty good however I'm drawing furniture and using the template called Product Design for woodworkers in inches I guess they (SU) mean feet and inches because I have to edit text of dimension if it's more than 12". Any way to force dimension to read inches only.
      Thanks in advance
      2011 iMac
      SU 2015 Pro, 2017 Make
      V2 Twilight
      macOS Sierra 10.12.5
        Model Info > Units...
        • jeff hammondJ
          and more specifically, once you go to units as tig described, switch the format from architectural to fractional.
          (and you can do this after all the dimensions are done in feet/inches.. the dimensions will update to reflect changes made in the units dialog.. you can switch between metric and imperial as well and the dimensions will update accordingly)
          • mitcorbM
            mitcorb
            Hey, Jeff:
            Can you get that thing to stick his tongue out?
            • jeff hammondJ
              ha.. yeah, i could do a little animated gif of it..
              i got that avatar from rich (or the idea for it) a few months ago.. something about star wars and him calling me hammerhead (hammond)..
                mwm5053
                Hey thanks that was to easy
                2011 iMac
                V2 Twilight
                • jgbJ
                  jgb
                  This is a SketchUp forum, not Staples. 😆
                  jgb
