    [Plugin] AreaTextTag
    97 Posts 27 Posters 83.8k Views 27 Watching
      baldaman
      Finally you finished it!!!
      Two question:
      would it be difficult to have the possibility to tag an ensemble of selected faces without having to pick them?
      would it be difficult to have the possibility to update an ensemble of selected tags without having to pick them?
      Aera checking and reporting without leaving Sketchup: I dreamed of it for so long!
      • srxS Offline
        srx
        Fantastic. Thank you TIG! I'm now thinking of using SU more than Autocad ๐Ÿ˜„
        www.saurus.rs
          Two question:
          Area checking and reporting without leaving Sketchup: I dreamed of it for so long!
          In an early draft I had a mass tagger BUT it put the tag at each face's center and there was no opportunity to have additional text - so I shelved it.
          As you would need to initially select these faces to tag them en mass then picking the face and adding a tag at the point, and then adding some additional text [or press enter to add 'none'] is little extra work and allows you more control over what you get - you'd need to go round relocating and Editing the extra text anyway ?.
          You Edit ONE preselected tag at a time because you are changing its 'text' part, BUT you can select multiple tags and Update them en mass - since only the 'current-settings' and the face's area are changed in each tag. You don't need to pick tags individually to do this Update - you can select by picking using +Ctrl to add to the selection... OR even easier use a 'fence' to select them - because any non-tags are ignored you can have other objects in this selection so you don't need to be too careful, just make sure you've included what you want [non-tags are skipped anyway]...
            baldaman
            Thank you for your response
            I think I understanded 90% (my english is not perfect)
            My thought: I think majority of people will use it to check and report surfaces of different rooms in a building.
            I mean if it is not for presentation purpose you don't really care about changing text but being able to select a bunch of rooms and tag them with a click could be really amazing!
            Anazing, once again you bring Sketchup a step forward! ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
              Here's v1.1 http://forums.sketchucation.com/viewtopic.php?p=373717#p373717
              Please re-read the instructions as there are some major changes...
              Now made as an Extension and a Toolbar has been added.
              Now comes as a .rbz installer or a .zip file to suit Sketchup v8M2 and earlier users...
              UK friendly 'm2(ft2)' units option added to Settings.
              Edit/Update now ensures each Tag is a unique instance.
              Update ALL active tags option added if there is NO initial Selection.
              Update highlights unglued/duplicated tags, for manual deletion.
              Update is now done automatically before making a CSV export.
              CSV report now ignores unglued/duplicated tags [highlighted for manual deletion].
              CSV report includes two extra columns if units are 'm2(ft2)'.
              New 'Tag Selected Faces' tool added for 'batch tagging' of Selected OR ALL active Faces.Enjoy... ๐Ÿ˜„
                Here's v1.2 http://forums.sketchucation.com/viewtopic.php?p=373717#p373717
                Please re-read the instructions as there are some changes...
                The Update Tool now has an option to update 'area only' OR 'everything' [Yes|No] - i.e. 'area AND text formating to current-settings'.
                The auto-update that runs before the CSV report is made now will only updates the areas and leaves the formating alone.Enjoy... ๐Ÿ˜„
                  baldaman
                  Thank you SANTIG CLAUS
                  โ˜€
                  • jim smithJ Offline
                    jim smith
                    A HEARTY THANK YOU TIG! ๐Ÿ‘ ๐Ÿ‘
                    A very usefull and time saving tool
                    "Out of clutter find simplicity,
                    from discord find harmony,
                    In the middle of difficulty lies opportunity"
                    Albert Einstein
                      lexmonteiro
                      Thank you so much!
                      share the knowledge magnifies the world!
                      Happy new year!
                      • guanjinG Offline
                        guanjin
                        Can not correctly display units, display units to meters. I can not upload pictures, thank you! !
                        • guanjinG Offline
                          guanjin
                          Unit shows that correct? ? I have a problem or operation! Thank you!
                          • guanjinG Offline
                            guanjin
                            Unit shows that correct? ? I have a problem or operation! Thank you!ๆœชๅ‘ฝๅ.jpg
                              Guanjin
                              Because you have a Chinese OS I suspect that the character-mapping is preventing the 'm2' >>> 'mยฒ' etc.
                              However, it might be that the font you chosen doesn't have a 'ยฒ' character ??
                              Try using 'Arial' to see this - as that should have all needed characters...
                              The code in the ' TIG-AreaTextTag.rb' file inside the ' TIG-AreaTextTag' subfolder can be adjusted to leave it as 'm2'. The dialogs use 'm2' etc BUT it then translates it into 'mยฒ' for the text in the SKP...
                              To edit the code, open that TIG-AreaTextTag.rb file using ***Notepad.exe*** or a similar plain-text editor [NOT a wordprocessor]...
                              On lines #352, #532, #799 AND #951 you'll see this text
                              atxtu=atxt+" "+(@units.tr("2","**ยฒ**"))
                              edit them to read
                              atxtu=atxt+" "+(@units.tr("2","**2**"))
                              Also just below on lines #355, #535, #802 AND #954 it reads
                              atxtu=atxt+" mยฒ"
                              change them to
                              atxtu=atxt+" m**2**"
                              and just below on lines #357, #537, #804 AND #956 it reads
                              atxtu2=atxt2+" ftยฒ"
                              change them to
                              atxtu2=atxt2+" ft**2**"
                              OR you can simply use 'find/replace' for the text 'ยฒ' replacing it with '2' ๐Ÿ˜’
                              Save and restart Sketchup, the areas should now report as 'm2' etc...
                              • guanjinG Offline
                                guanjin
                                @tig said:
                                Guanjin
                                edit them to read
                                atxtu=atxt+" mยฒ"
                                change them to
                                change them to
                                OR you could try to use 'find/replace' for the text 'ยฒ', replacing it with '2'... ๐Ÿ˜’
                                Thank you for your reply, I went to give it a try! Thank you!
                                • guanjinG Offline
                                  guanjin
                                  The first problem to solve, but the button 2 to select or m
                                  Demo map
                                    You must change the 'ยฒ' in several places in the file... looks like you missed some of them... 'find' every 'ยฒ' and make it into a '2'... it clearly works for the lines that you have adjusted successfully... One last try ๐Ÿ˜„
                                    • guanjinG Offline
                                      guanjin
                                      Problem solved, thank you again! Master ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘ ๐Ÿ‘
                                        Jorgensen
                                        Hi TIG
                                        I think this plugin could become very usefull for me ๐Ÿ˜„
                                        But I have some problems, but it might just be me that use it wrong.
                                        My workflow would be, create some rectangles and add the tag e.g.:
                                        office (30)\n<> where 30 is the size the client would like.
                                        But the problem is that the different rooms can't be grouped, so when they get close to one another the 'glue' together.
                                        Could it be an idea that the tags glues to groups ?
                                        Just an idea ๐Ÿ˜„
                                        some other future features could be:
                                        import excel / csv files and automatic create the rooms
                                        room_name room_size
                                        office 20
                                        Scheme
                                        Generate a scheme that calculates the actual room size vs the size client wishes.
                                        I really admire the hard work you (and others) do to improve SU.
                                        ps. SU7 seems to crash when using this plugin.
                                          Bo
                                          You can group faces and still apply Tags.
                                          You simply need to edit that group and then apply an AreaTextTag onto a face within that group: the only 'rule' is that the face and its Tag must be in the the same 'context' - i.e. active_entities set.
                                          I have already written a commercial toolset for a US Space-Planning/Architects company which imports/exports data from/to XLS/XLSX files and creates/writes rooms to match... however, it's not publicly available - but it is quite do-able...
                                          It should work OK in v7... what error messages do you get ?
                                            Jorgensen
                                            Hi TIG
                                            Thanks for your reply.
                                            Su7 crashes when I select "add.... to selected faces" SU quits and a splashscreen pops up.
                                            I was not awere of the "inside the group" feature.
                                            You write that You have made a 'pro' version. Do you consider releasing a commerciel Pro version ?
                                            • 1 / 5
