    Construction & Working Drawings - Discussion
    layout
    453 Posts 114 Posters 519.1k Views 114 Watching
      Stevo
      I submitted some stuff to Google a few years ago. They used some as examples of what you can do with Layout. Ironically these images were not made in Layout; however many others were. I can't seem to find the others right now.
      I found them. There located in the same picassa portfolio they use.
      Images:
      1,5,6,7,29,30, and 45
      Error 404 (Not Found)!!1
      (sketchup.google.com)
      OS/Hardware:
      Win7 64
      Sager NP7280
      i7 980x
      SLI 460M
      12gb
        sonder
        Nice work Stevo.
        I'm new to this forum, but was part of the old google forum a couple years back. I've been using sketchup since it was owned by ATLAST - i think since 2003. I have used it in conjunction with ACAD for several years. ACAD finally got me so frustrated (I've been using it since version 2.3!). I don't understand why Autodesk insists on maintaining their cumbersome path. At any rate, I completely dropped ACAD last summer and I have dedicated myself to making Layout work for complete construction documents for all my work. I primarily do custom homes in the Tahoe area. I am 3 projects deep in the process and so far, I have no regrets at all. I have structured all my scrap books and standard layout sheets to the point that I am now far faster than ACAD format and the graphic output is far superior. Every contractor that looks at my documents has been very complimentary. I also provide fairly in depth drawings - usually 30 sheets plus. It is great to see so many going down this path as I would love to see some improvements and development of Layout for my use.
        Cheers!
        • pbacotP
          Sonder,
          Welcome! Any tips you have on the CD process with LO would be great to hear.
          Peter
          • K
            Klog
            To Sonder: I second Pbacot's request for some examples of detail and Tell me, do you experience any glacially slow periods at the Laying-out stage with Layout? I have found that with very large files I need to break them into parts to keep from bogging down in Layout ...
            Klog http://www.tetontimberframe.com
            Win 7 Pro Dell Precision M4500 4Gig 4 threads @ 2.9 GB/S
            Skp 7 Pro & 8
              sonder
              Thanks for the welcom.
              I would post an image, but I have never done so online like this. How do I keep the quaility like those posted above - are those hosted somewhere? Sorry for the ignorance on this, but when I convert a pdf to an image, the quality is awful.
              As for the LO speed, I have found more ram helps, but the key is management of the model. Always set the file so the references do not update or render automatically. Always work in Raster format. Purge all SU models prior to updating (components first, then materials). Utilize groups, components and layers to only show specifically what you want in a particular scene. I have found that this helps the workflow move nicely. The biggest time hog is updating the reference and rendering in Vector. I only do that at the end of the day or at night when home. It is the number one aspect of LO that needs improvement. Updating of the references, especially large ones takes time. My home designs are typically around 30Mb for the home alone and 40mb for the home on the site. Separating the two is a huge help in working with building specific drawings opposed to site specific.
              Now all that said, I have only been really exploring Layout since this past summer. I am now finding that until LO deals with the reference update time crunch, I may temporarily switch to one page per file. This would certainly speed things up opposed to how I am working now. I have 6 page documents for floor plans. When you update that reference, Layout takes 6 times longer than if it were 1 page. It appears that each viewport updates and renders separately timewise.
              • jolranJ
                jolran
                Interresting topic.
                I noticed something perculiar last week.
                I got the impression LO is slow when number of objects increase, regardless of meshdensity.
                Had this model of a rock-climbingwall. When I added climbinggrips(many instances of them), update was dramaticaly slower in LO.
                Off course if you add stuff, you will pay the price. But the grips where instances and not "very" dense. At least I don't think they where. No noted lag in SU.
                • bmikeB
                  bmike
                  Some recent permit drawings:
                  https://lh5.googleusercontent.com/-O30ID-fB6ZQ/TvH4E1QAPJI/AAAAAAAARe0/AgwSn-zkTmE/s800/ft-roundbarn-11-21-11a_Page_02.jpg
                  https://lh6.googleusercontent.com/-DqlsRw57uXE/TvH4D3xJ13I/AAAAAAAARes/g9wGFHUBPzM/s800/ft-roundbarn-11-21-11a_Page_07.jpg
                  https://lh6.googleusercontent.com/-J9KROm-V4Ww/TvH4Dsr63BI/AAAAAAAAReo/jD2eYVJoGI0/s800/ft-roundbarn-11-21-11a_Page_08.jpg
                  https://lh5.googleusercontent.com/-h6UwOvue3yI/TvH4DKWfzgI/AAAAAAAARek/QNjkdMRoaOg/s800/ft-roundbarn-11-21-11a_Page_09.jpg
                  https://lh3.googleusercontent.com/-oVnmEWEop8o/TvH4CsAfbrI/AAAAAAAAReg/W4MxW4CbxqA/s800/ft-roundbarn-11-21-11a_Page_10.jpg
                  • jolranJ
                    jolran
                    Ok, nuff said..
                    I reckon there are a fair amount of components in your model Bmike πŸ˜„
                    Beauty BTW
                    • bmikeB
                      bmike
                      @jolran said:
                      Ok, nuff said..
                      Beauty BTW
                      thanks.
                      collaboration between an engineer i work with and his client.
                      we did about 4 iterations in sketchup. showed to client via walk through and jpg.
                      he eventually nixed some of our more creative approaches (curved braces, some mirrored and tapered elements, etc.)
                      i worked on each sheet in vector, but would keep them from auto-updating, and switched them back to raster when i was done.
                      it sucks, but otherwise it gets really slow switching from page to page.
                      11 pages (i've worked on sets with 26 and 30 pages - i had to break those into 2)
                      • pbacotP
                        In SU the users (and Ruby makers) are the developers! Google just has to Catch-UP!
                        BMike Thanks for this. Can I work for you? Love your projects!
                        Sonder, you might check out this page RE attachments. Would love to see some of your examples:
                        http://forums.sketchucation.com/viewtopic.php?f=81&t=25217
                        • bmikeB
                          bmike
                          Thanks all.
                          Here's another recent project:
                          https://lh3.googleusercontent.com/-1KXEV6PmuHk/TvNFLGBzN_I/AAAAAAAARfY/lTVF4efuCdc/s800/pavilion-9-29-11_Page_01.jpg
                          Engineer (who took my Intro to SketchUp course...) sketched this up on paper and as a first go in SketchUp.
                          I cleaned up his overall model and added all the details, joinery, steel.
                          https://lh4.googleusercontent.com/-Ob8XVHmROmA/TvNFKlTykgI/AAAAAAAARfU/D5zcPTWyQZM/s800/pavilion-9-29-11_Page_04.jpg
                          https://lh4.googleusercontent.com/-nQktEE3g7hA/TvNFKfyf-pI/AAAAAAAARfQ/xxuCvEfuHzo/s800/pavilion-9-29-11_Page_05.jpg
                          https://lh5.googleusercontent.com/-rKZcE_4WYlw/TvNFKDmdRpI/AAAAAAAARfM/_nS1qTKJJYM/s800/pavilion-9-29-11_Page_06.jpg
                          https://lh3.googleusercontent.com/-8xBLPtbLECg/TvNFJmbZjAI/AAAAAAAARfI/ZYJsLI_zfY8/s800/pavilion-9-29-11_Page_07.jpg
                          https://lh6.googleusercontent.com/-_KYg_Jzjxyw/TvNFJuMAooI/AAAAAAAARfE/SYeu5ijkpWo/s800/pavilion-9-29-11_Page_10.jpg
                          https://lh6.googleusercontent.com/-HO0Z6ujnzfQ/TvNFJJJutoI/AAAAAAAARfA/LJum-7r9Xp4/s800/pavilion-9-29-11_Page_11.jpg
                            You get such cool projects.
                            • K
                              Klog
                              x-ray viewvector view[quote="jolran"]Interresting topic.
                              quote]
                              I have found the same result ... when I delete multiple copies of the model (or duplicate portions of it that were set up separately just for clarity or convience) Layout speed increases, but as Sonder has noted going to 1 page per file really speeds up the processing and updating.
                              Also the clearest results are definitely with vector graphics, but I have to use raster if x-ray is a part of the scene (i.e., joinery within a timber). I will see if I can find some examples and attach to a following email. See also this topic for other examples of my recreational work: http://forums.sketchucation.com/viewtopic.php?f=81&t=39961.
                              Skp 7 Pro & 8
                              • bmikeB
                                bmike
                                klog, nice work.!
                                • pbacotP
                                  Klog,
                                  VERY impressive isometric of the overall frame! If I were the contractor I'd want the SU model to be able to orbit and zoom. Thanks for posting those.
                                  Peter
                                    sonder
                                    Definitely going with single page layout docs makes a huge difference in speed. Obviously you lose the benefit of repeated items on each page, but honestly that is generally limited to title blocks for me. Bear with me an upload quality as these are my first attempts. The details are boring site details for storm water management, but it will be the format of my architectural details except they will be 12 per page. I have my detail library at over 250 details so far - all perspective extrusions. I used to do a combination of ACAD and sketchup imagery, which worked really well. I just got so frustrated with how ACAD has been developed that I finally dropped it completely.
                                      jsl
                                      Sonder,
                                      These drawings are an inspiration. Our head office insists on using a complex BIM package to do all documention (SD, DD, CD) when we mostly do only small and medium projects. Unfortunately Sketchup is still viewed by a few (influential) people here as 'just a toy', never having spent much time to learn its potential.
                                      Having completed a couple of smaller side jobs with sketchup / layout, I find the workflow so much more enjoyable.
                                      Jacob
                                      • bmikeB
                                        bmike
                                        that is some nice work sonder!
                                          sonder
                                          Thanks for the compliments. @JSL: people get stuck in their ways unfortunately. I see many architects utilizing sketchup for purely design purposes. Then they switch to ACAD and redraw everything. Seems crazy to me to double the work load and introduce inaccuracy in the process. Most of my competion uses Revit and I constantly hear their frustrations as well as the contractors.
                                          Here are a couple more samples - Maybe show your office you are not alone in your thoughts. To me this was a no brainer and I have been using ACAD for more than 20 years.
                                            sonder
                                            Thanks Pbacot.
                                            I used ACAD for many years and multiple .lsp routines in place as well as massive standards that were developed over the years. My biggest issue with ACAD is the indirect output. What I love about layout is WYSIWYG. The inaccuracies that result from switching between software is that more often than not, architects are reconstructing the SU work in ACAD to meet their standards. That gap creates issues, especially if the modeler from SU is not the drafter in ACAD. With LO that issue doesn't exist.
                                            Yes there are several items in LO I would love to see improved - like dimensions and such. Regarding the leader text, I don't use it which is why you see it graphically as I have it. I create all my notes as text and then draw a leader to it. It makes for much easier manipulation of the text graphic. The text works just like Mtext in AutoCad this way, ao you can adjust it to fit as needed. To me this is far better in manipulating and moving notes. The only thing you lose is the leader link. This is resolved by grouping the note and the leader.
                                            I made the jump as I used to combine ACAD with SU. I really love it so far. Yes there is a lot of room for improvement; but I am hopeful this will happen in the near future with Google behind this software. While certain aspects are slow, the intuitive nature of both programs is exactly what has been lacking from AutoDesk.
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 22
                                            • 23
                                            • 12 / 23
