    [Plugin] CleanUp
    974 Posts 217 Posters 833.6k Views 217 Watching
      Yes, TT_Lib2, which is linked from the description in the first post. Above the download link.
      • opalO Offline
        opal
        hmmm.. I have that one in there
        I'll take it out and download fresh
        thank you πŸ˜„
          Check how you extracted the files. For each plugin there is a description on how and where the files should be installed. Or even better, if you have SketchUp 8 and updated to the recent M2 update, go to Window > Preferences > Extensions > Install Extension and install the plugins from there. Just select the zip files from the file dialog that appears.
          • opalO Offline
            opal
            Got it working this morning ty
            the M2 install from within the program feature doesn't seem to see anything besides file folders and .rbs files. I went to my backup plugins folder to start getting some of the missing most used plugins back after the update from within sketchup and don't see zip or rb files with that tool.
              The 'button-installer' only works on .RBZ files [which are compressed archives just like .ZIP files]. By default you will only see folders or .RBZ files in the browser that is opened by the button... BUT you can trick it into showing you all file types: type *+<enter> in the file field and all files will now show... find the tool's .ZIP file and install it, it will work just like a .RBZ file... NOTE: it will install any .ZIP file... so ensure that it is a proper tool-set ZIP and not one of your holiday-photos, as they will could be copied into Plugins folder too πŸ˜‰ Also note that picking any other non-compressed archive file type will generate an error...
              • opalO Offline
                opal
                cool.. ty again
                • kingsiK Offline
                  kingsi
                  I am very new to Sketchup (1st week) and also one of those annoying people that never says thanks on forums. I plan on being neither from now on. So on that note many thanks for the cleanup script
                  kingsi
                  Noobtastic
                    πŸ‘
                      Boumbastique
                      Zip file don't want to unpack, it says - "unknown format or an error in archive" tt_cleanup.zip 😒 (other zip files works correct on my pc)
                        Try downloading again
                          Boumbastique
                          I tried many times, it didn't work, unfortunately.
                            Boumbastique
                            I have found it on other resource. Work's great. thomthom thank you very much, you're cool man πŸ‘
                              And where exactly is this other resource?
                              • john2J Offline
                                john2
                                i cant load cleanup properly. however if i create a separate folder with required ttlib, this plugin works perfectly.
                                http://i.imgur.com/9af9A.jpg
                                my plugins list is here
                                http://www.sendspace.com/file/jwyz90
                                Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                • sumasterS Offline
                                  sumaster
                                  CHK it out your Internet Explorer Version
                                  I think you have old internet explorer
                                  Install New internet explorer this problem is sold
                                  Thank you,
                                  SUmaster
                                    Can you open the Ruby Console and try to use CleanUp? See if you get any error messages.
                                    • john2J Offline
                                      john2
                                      clean with last settings works
                                      the first option in which the menu should come "clean..." doesnt work. no error messages. iget the same blank box
                                      http://i.imgur.com/hHE4i.jpg
                                      all the options accessed via the drop down menu are taking my command. the first one in which the black menu comes isn't working. what is the conflict?
                                      http://i.imgur.com/mJjmt.jpg
                                      • john2J Offline
                                        john2
                                        i have version 8. and this cleanup plugin works perfectly when kept in isolation in a separate folder. πŸ˜•
                                          What do you mean by this? Can I see a screenshot of the plugins folder?
                                          • john2J Offline
                                            john2
                                            check the html file in the previous post that i made
                                            • 22
                                            • 23
                                            • 24
                                            • 25
                                            • 26
                                            • 48
                                            • 49
                                            • 24 / 49
