    [Plugin]T2H_BuildingStructureTools2.2.4 in20141207
    337 Posts 108 Posters 525.4k Views 108 Watching
      lukestar
      The Building Structure Tool does not load properly. I go to WEBDIALOG and I do not get any icons???
      What's the GO?
      Lukestar
        tak2hata
        @lukestar said:
        What's the GO?
        Lukestar
        Hi lukesatr.
        I'm sorry.I see that on mac.
        I will recover it to work on mac.
        Please wait.
        I update files.
        It will show webdialog with icons on mac.
        But can not restore size of webdialog.
        I will improve it.
        Thanks.
        by TAK2HATA
          lukestar
          I cannot get this Pluggin to work in that there are no tools displayed. I have to install it again, but the same result. Yes went to WEBDIALOG to load the tools but I get a blank panel.
          Help?
          Luke
            He already said he's working on the problem and asked you to wait. I'm sure he'll announce when he has it fixed.
              lukestar
              @lukestar said:
              Help?
              Luke
              Thanks very much, now the icons show and work.
                tak2hata
                Hi Lukestar.
                The news was heard good for me and you.
                by TAK2HATA
                  cadmunkey
                  Just found this, I asked about a steel frame plugin but no-one suggested this. I detail building structures mainly so this will be very useful thanks!
                    tak2hata
                    Hi,cadmunkey.
                    You are welcome. πŸ˜‰
                    My goal is detail building modeling,too.
                    Thanks for using this.
                    by TAK2HATA
                      davecoopstl
                      I think there's a problem with your "bst_zip051.zip" file.
                      When I Extract the .zip file in Windows into my Plugins folder for SketchUp, it places a "bst_zip" folder in the Plugins folder. The "building_structure_tool" folder and the"building_structure_tool.rb" needed to run the script are inside of the "bst_zip" folder...they need to sit directly in the Plugins folder to work.
                      You have one too many sub-folders in your .zip file. It just doesn't extract correctly.
                        davecoopstl
                        One other thing:
                        Is there any way to get the Toolbar back, WITHOUT using the Web Dialogue? I'd much rather have the toolbar up in my set of toolbars, than having to click to call up the web dialogue every time I want to use it. Just seems more cumbersome.
                        Just a thought.
                          tak2hata
                          @davecoopstl said:
                          One other thing:
                          Just a thought.
                          Hi,davecoopstl.
                          I correct the toolbar as before.
                          Thanks.
                          by TAK2HATA
                          • kenK Offline
                            ken
                            Sir
                            I have a single icon that will show a building tool toolbar. I also have a building tool toolbar. These appear to be loaded by differ plugins. Does the program really need to means of showing the toolbar or have I installed the program incorrectly?
                            Another question, you give a PDF document to showing how to modify the CVS files showing the profiles. However, I haven't been able to get the program to read the new profiles. Also, there doesn't appear to be an icon for the circle shapes, L shapes. I must be missing something.
                            Thanks for you help and this plugin.
                            Ken
                              davecoopstl
                              Thanks for bringing back the regular toolbar!
                              However, the new version still has the same Unzipping problem. If you Unzip the files into the Plugins folder, it puts them in a "bst_zip052" sub-folder in the Plugins folder, and SketchUp cannot find the files. You need to create the .zip file so that they get Unzipped directly into the root Plugins folder, not a "bst_zip052" sub-folder.
                              Thanks again!
                                tak2hata
                                Hi,Ken.
                                Your install is correctly.
                                If you not need toolbar,please show off.or delete "bst_toolbar.rb" from plugins folder.
                                Hi,davecoopstl.
                                I will remove folder in zipped file.
                                Thanks.
                                by TAK2HATA
                                  tak2hata
                                  HI,
                                  I update this to v0.5.3 with small bug fix.
                                  Hi,Ken...
                                  I add new youtube video about Profile list csv.
                                  http://youtu.be/oSVrbJMSSB0
                                  [flash=420,315:biq7w64j]http://www.youtube.com/v/oSVrbJMSSB0[/flash:biq7w64j]
                                  I am not good for english.so I can not expression customize profile list csv well.
                                  Please watch video.
                                  Thanks.
                                  by TAK2HATA
                                    d_e_x
                                    Hi Tak,
                                    I am excited to see that I am not alone in developing a BIM plugin πŸ˜„ Great work!
                                    My plugin (SketchUpBIM) is focused on Building Modeling, and follows a similar methodology as the commercial BIM softwares. I would be very happy if you check it out and provide your feedback and comments: http://forums.sketchucation.com/viewtopic.php?f=323&t=41840
                                    other BIM gurus on this forum, please feel free to provide feedback as well!
                                    dex
                                      tak2hata
                                      @d_e_x said:
                                      Hi Tak,
                                      dex
                                      Hi,d_e_x.
                                      Your project is very exciting to me ,too.
                                      I wish BIM being free and open.
                                      Sketchup is one of best application for that goal.
                                      I will check your project out.
                                      Thanks.
                                      by TAK2HATA
                                      • guanjinG Offline
                                        guanjin
                                        Hello: I edited the language file, change the language in the environment, selection, or display the original language!
                                        Please enlighten me
                                          tak2hata
                                          I update to v0.5.4 in Dec 18 , 2011.
                                          Small Improve:Multi wall work on sketchup v6 ,too.
                                          Hi,XIAOLONG.
                                          Thanks to your reply.
                                          I do not consider language setting enough.
                                          I will improve lang setting after updating this plugin to v1.0.
                                          Please wait small long time.
                                          by TAK2HATA
                                          • guanjinG Offline
                                            guanjin
                                            Hi,XIAOLONG.
                                            Most of the language can not change, 1.0 a long time oh
                                            • 16
                                            • 17
                                            • 5 / 17
