    Dimension between point and edge
    5 Posts 5 Posters 1.9k Views 5 Watching
      sgbotsford
      Planning a kitchen. Want to know how much space between the end of a cabinet and the end of the wall.
      Dimension tool. Click on back corner of cabinet. Click on edge of wall. Shows distance, but it doesn't stick. Do I have to put an extra line in there so that Dimension has an endpoint to stick to? Seems kludgey
        SUp dimensions use an 'edge' length or a distance between two 'vertices', so you DO need to add a line and dimension it or its ends [or something equivalent like a cpoint].
        You can erase that temp line/cpoint afterwards and leave the dimension...
        OR use Layout ?
        • pbacotP Offline
          I imagine you are beginning from the top corner of the cabinet (thus a point) and going to the corner of the wall directly opposite (only an edge). SU looks for another point. Can you click a point at the top or bottom of the wall corner and pull the dimension back down to level?
          • Rich O BrienR Online
            Using the Tape Measure tool, click and drag from the start point to the end point to create a construction point. Use this construction point to dimension the space
            • Jean LemireJ Offline
              Jean Lemire
              Hi Sgbotsford, hi folks.
              See this SU file for ideas.
              Dimension between end of cabinet and end of wall.skp
