    [Plugin] CleanUp
    974 Posts 217 Posters 788.7k Views 217 Watching
    • F Offline
      finnishXchange
      Thom,
      I am excited to try your program for cleaning up lines in a file imported from autocad. Would you mind explaining how to install the plug-in, or direct me to where I might find a tutorial for that? I'm a new member of this site and the only other plug-in I have used is Kerkythea, so pretty clueless what to do with the rb file after saving it to the desktop. I am using SU version 8 with mac OS x 10.6.8.
      Thanks a lot!
      Troy
        Here are some instructions how to install zipped plugins:
        http://forums.sketchucation.com/viewtopic.php?f=323&t=35746
        Note that for this plugin to work, you will also need to install another plugin library (linked from the first post). That's also zipped so the procedure is the same.
        • opalO Offline
          opal
          Hello,
          So.. after the installation of M2, I put tt_cleanup.rb in the brand new plugins folder.. I think the shiny new empty folder confused it.. it's lonesome in there and I'm getting the messages on startup
          tt?cleanup.rb
          Error: No such file to load - TT_lib2/core.rb
          So.. instead of using the copy/paste of the file from the old plugins folder, I came back to this thread and downloaded it again.. same error message.
          Is there a companion file I'm supposed to download with it?
            Yes, TT_Lib2, which is linked from the description in the first post. Above the download link.
            • opalO Offline
              opal
              hmmm.. I have that one in there
              I'll take it out and download fresh
              thank you πŸ˜„
                Check how you extracted the files. For each plugin there is a description on how and where the files should be installed. Or even better, if you have SketchUp 8 and updated to the recent M2 update, go to Window > Preferences > Extensions > Install Extension and install the plugins from there. Just select the zip files from the file dialog that appears.
                • opalO Offline
                  opal
                  Got it working this morning ty
                  the M2 install from within the program feature doesn't seem to see anything besides file folders and .rbs files. I went to my backup plugins folder to start getting some of the missing most used plugins back after the update from within sketchup and don't see zip or rb files with that tool.
                    The 'button-installer' only works on .RBZ files [which are compressed archives just like .ZIP files]. By default you will only see folders or .RBZ files in the browser that is opened by the button... BUT you can trick it into showing you all file types: type *+<enter> in the file field and all files will now show... find the tool's .ZIP file and install it, it will work just like a .RBZ file... NOTE: it will install any .ZIP file... so ensure that it is a proper tool-set ZIP and not one of your holiday-photos, as they will could be copied into Plugins folder too πŸ˜‰ Also note that picking any other non-compressed archive file type will generate an error...
                    • opalO Offline
                      opal
                      cool.. ty again
                      • kingsiK Offline
                        kingsi
                        I am very new to Sketchup (1st week) and also one of those annoying people that never says thanks on forums. I plan on being neither from now on. So on that note many thanks for the cleanup script
                        kingsi
                        Noobtastic
                          πŸ‘
                            Boumbastique
                            Zip file don't want to unpack, it says - "unknown format or an error in archive" tt_cleanup.zip 😒 (other zip files works correct on my pc)
                            • Rich O BrienR Online
                              Try downloading again
                                Boumbastique
                                I tried many times, it didn't work, unfortunately.
                                  Boumbastique
                                  I have found it on other resource. Work's great. thomthom thank you very much, you're cool man πŸ‘
                                    And where exactly is this other resource?
                                    • john2J Offline
                                      john2
                                      i cant load cleanup properly. however if i create a separate folder with required ttlib, this plugin works perfectly.
                                      http://i.imgur.com/9af9A.jpg
                                      my plugins list is here
                                      http://www.sendspace.com/file/jwyz90
                                      Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
                                      • sumasterS Offline
                                        sumaster
                                        CHK it out your Internet Explorer Version
                                        I think you have old internet explorer
                                        Install New internet explorer this problem is sold
                                        Thank you,
                                        SUmaster
                                          Can you open the Ruby Console and try to use CleanUp? See if you get any error messages.
                                          • john2J Offline
                                            john2
                                            clean with last settings works
                                            the first option in which the menu should come "clean..." doesnt work. no error messages. iget the same blank box
                                            http://i.imgur.com/hHE4i.jpg
                                            all the options accessed via the drop down menu are taking my command. the first one in which the black menu comes isn't working. what is the conflict?
                                            http://i.imgur.com/mJjmt.jpg
                                            • 41
                                            • 42
                                            • 43
                                            • 44
                                            • 45
                                            • 48
                                            • 49
                                            • 43 / 49
