    Can I use su to produce this , plugin ?
    13 Posts 6 Posters 711 Views 6 Watching
      bejoo
      Hello
      This was done using 3D Max ... could it be done with SU .. is there plugins ?
      Bejoo
      • numbthumbN Offline
        numbthumb
        What was done with 3ds Max?
        Comfortably numb...
          bejoo
            Yes
              numbthumb
              No plugins needed. Except maybe for that tapered curved part: http://www.drawmetal.com/
              Comfortably numb...
                But the profile is twisting just as if it had bee made with the tool πŸ˜„
                  Not exactly the same spiral but would it be something like this?
                  There were three plugins involved here:
                  1. Made a helix (there are lots of helix or spiral plugins)
                  2. Used SketchyFFD (Free Form Deformation) plugin to make the middle "fatter" a bit - this was only to "prove" the concept that the spiral/path can be nicely deformed
                  3. Finally used taper maker plugin to do the tapered "follow me". This could also be done in more steps (in the original image, the extrusion seems to be equally fat for a while and only the end tapers visibly)
                  taper.skp
                  • irwanwrI Offline
                    irwanwr
                    i don't get it.
                      tspco
                      Must be a secret, I can't see it.
                      SU make 2017, /Twilight Render Hobby
                      Windows 10,64 bit,16GB ram, quad core Athlon 3.6 gHz proc. Anything else you want to know, ask me.
                        @irwanwr said:
                        i don't get it.
                        What don't you get? The steps?
                        What can't you see? The file? The resulted taper?
                          numbthumb
                          Probably the file that was attached in the first post. Because I donΒ΄t see it anymore, either πŸ˜•
                          Comfortably numb...
                            Ah, you are right. It was edited later by the poster I see.
                            • irwanwrI Offline
                              irwanwr
                              well, he probably work for CIA, old KGB and Mossad at the same time πŸ˜›
